Eagle Eye X5R Review
52 posts / 0 new
ReManG
Last seen: 1 hour 21 min ago
This X5R was sent to me by Gearbest for review. They contacted me and I agreed to do a review in exchange for this light. Now that the formalities are over, on to the review.
X5R models on Gearbest
I like tube lights for their portability and ease of storage. The same width tube and fairly slim proportions make an easy to carry light compared to something like a C8 which has a larger head than body. This is a tube light and after about 10 days of using this, I would rate it a light to buy. I have come to like e-switch lights as well during my time here on BLF, but originally did not... This light has a tail switch for on and off, as well as the side e-switch for changing modes.
I feel this is a good, but somewhat clunky interface for a slim light with a side switch. The good: The rear switch is a forward clicky, so you can blink it on and off like you want to search for stuff. The bad: whatever level you were on is what the rear switch blinks on for you. To change modes, you have to click fully or hold the rear switch down and cycle the side e-switch. So the clunky part is really just my opinion about the having to use both switches to change modes. In use, it is not really an issue and the software in our heads can adapt to most anything if we get out of the way and let it… The great thing about having the rear switch is the light will not come on from the e-switch accidentally and there are no 8 clicks to lock out/open the light or some other funky UI tricks that e-switch only lights have to prevent accidental operation.
Speaking of UI, this one is simple. On via tail switch, then four modes going up in power. Low, medium, high and turbo. All done from the e-switch to change modes. There is a hidden strobe, press and hold the e-switch from any level for about 1 second. The strobe is a two mode about 10hz and 3hz or so, scrolling between the levels when on. The good thing here is mode memory, NOT including strobe. If you turn off the light with the tail switch, the mode is remembered. When you turn the light on again, that level is the one that starts, then cycle up through the modes again to change levels if you want. I am ok with a well hidden strobe, and this one is that. The dual level strobe is also an attention getter. So, all in all, a well executed strobe mode that cannot be activated accidentally when changing modes. I think this simple and efficient UI is a nice change from so many modes you have to keep a cheat sheet wrapped around the light to remember them all.
The built in charger in this light seems to be less than the advertised 2A. I could not get more than 850ma when testing with a clamp on meter at work, but did not have a 2A capable wall wart… At home with the Blitzwolf wall charger, I got 1.3A charging with skinny multimeter leads, so it is a fast charger, I just could not verify 2A... The level after charging for a while settled at around 500ma, so count on 3+ hours of charging from a depleted 2000ma battery and a 1A wall charger. Less time with a better wall charger, maybe 1.5 hours, not too bad at all if you need the light... I am impressed and would not mind even a 1A charger, but this 2A is fast… My sample did not have an instruction manual and so I exchanged some emails with the Gearbest Rep and found that to charge the light, you plug it in, then turn it on with the tail switch. This turns on the LED, and starts the charging, indicated by the e-switch red charging light. Then you can turn the light off with the side switch or use It, should you need to, while charging. This could be handy if you were needing the light and it was charging at the same time… The charging port cover is a silicone deal that fits tightly into the charging port, but you have to make sure it is fully in to ensure the water resistance is met. It lies flat against the body and once fully in, takes some fingernail work to get open, this is good. My sample did not come with an extra port cover, but it looks easy to replace and the Gearbest rep said she would ask Eagle Eye about including another one for a spare. Stuff happens, without a port cover, the light is subject to water intrusion fairly easily, though a good bit of duct tape would work in a pinch…
The built in charging kind of makes this light for me. First off, no need to carry a charger when traveling, and it can charge pretty fast if neede. I have a Manker U11 that is my go to light for travel right now due to the built in charger, I think the Eagle Eye X5R will give it a run for my next trip... The driver/charger board seems very strong and well set up, so that helps alieve any hesitation to fragility of this system. The charger board presses down onto a wide and fully supported PCB, opposite of the e switch. This means that should you push the charger in too far, or drop the light while the cable is attached, you would be aware of any damage as the switch would also not be aligned and you should be able to feel the difference.
The stoutness of the PCB inside makes me think you would have to be Hulk angry to push in the tiny USB too hard with this light…. This seems well built and should hold up well over time.
The switch is better centered, the angle makes it look out of alignment.
The body of this light is well done, typical Eagle Eye quality for anodizing and fit and finish. Very good overall. The front bezel is stainless steel and crenulated. The crenulations could be removed by filing, I believe this is called a "Foy" bezel when done well. They could use some toning down in my opinion (I would Foy the heck out of it), but are well finished enough to not eat a hole in your pocket for the first ten or twenty times you wear it…. Not really sharp in actuality, but if you needed to use it to strike something, I would not want to be the something. If I was, there would be a DNA transfer from me to the bezel for sure….
Nice threads and plenty of lube at both ends...
The light is longer than a Convoy S2 or equivalent, so a good amount of it will stick out of your fist should you need to jab something, an advantage to a longer tube light like this. The body is slightly longer than an equivalent Convoy S2 or A6 tube style light, as I said. While remaining about the same width, this gives a nice slim look to the light. The slight recess behind the head (fits the new Convoy clip for those that like bezel up carry), and in front of the switch lends to this as well. I suppose it would be a good point to tie off a lanyard or something, but otherwise it seems to be for aesthetics. The clip is a very good one, while not deep carry, it holds well to the light body and typical pockets from work and dress pants to jeans and cargo shorts. This is a nice thing to have a decent clip from the factory, and Eagle Eye has done it well. The one on this model is blacked out, and I imagine will show some wear, but the other models also show silver finish clips, so I am not sure if this is a preproduction test sample clip or what. Regardless, it is a good clip no matter the color. The light carries well and has enough stick out that you will be able to grab it out of a pocket easily. The down side is it will have some stick out and not be as low profile as some will want… Other 18650 clips will fit this if you need a deeper one, I tried the new convoy clip and it seemed to be good enough if you want this option…
This sample light has a 1A XPL HI emitter, and the light has 1A and 3B XPL HI options as well as 1A and 3C XM-L2 options. I like a more neutral tint for general purpose, so this tint would not be my favorite, but is a good Cool White, not too blue. Being an XPL HI means when white wall hunting, you can see some yellowish discoloration in the center of the hot spot. Outdoors, totally unnoticeable. This throws a nice tight beam from the reflector coupled with the XPL HI. Tighter than my BLF A6 with an XPL HI, but the OP reflector in this gives some good spill too. I think the XM-L2 in this light would be an awesome amount of flood to spot ratio. It is easy to change out if you want a different emitter.
The front bezel comes off easily with the crenulations and desolder the wires to remove the old emitter. There is a screw, but it is only there to keep the star from turning when screwing the bezel/reflector back in. The bezel presses the 20mm star onto the solid shelf, so the spacing may need to be checked if you use another centering ring on the XM-L2. Just buy the emitter you want on a 20mm star and two solders later, you have the new emitter installed.
The rest of the light is easily gotten into, but will take an advanced modder to keep the charger and change the driver… I have no idea how to do that, but it does seem possible to do something with a 10mm fet driver as a piggyback into the available space. The amps on the stock version were as follows on a 2000mah Efest 18650: 90ma Low, 280ma Medium, 850ma High and 2.2A on turbo.
These are respectable levels and if you check out the spacing, they are almost evenly spaced with 3x the ma at each level from the previous level. What does this mean, you ask? Well, the levels are roughly double the brightness of the previous level for all the levels. Medium is twice as bright as Low, High is twice as bright as Medium and Turbo is almost twice as bright as High… Low is pretty kick butt, as it is infinitely brighter than pure darkness... Pretty good levels, even with no Moon level, this is about right for good using levels, very well done in my opinion.
This is not a crazy driven light, but is a very usable light that will have plenty of run time if needed. The max amps stuff that members do here is awesome and awe inspiring, but I have come to the conclusion that 800-900 lumen is all I want from a "normal" stock light. Think about the fact that in order to seem twice as bright visually, you need almost three times the output, as the eye does not perceive light in a fully linear fashion. This means about 2400-2700 lumen is visually twice as bright as the 800-900 lumen "typical" light I am talking about, like this X5R. This theoretical next level is a bear, so the 2.2A turbo is fine by me… I for one would not limit anyone, by any means, and say we only "need" 900 lumen in a light, but I think it is a good area to look for an upper limit and have decent run times too.
As shown above, the levels here are well spaced and all of them are useful. The levels are about comparable to my Manker U11's top four levels, except for turbo, the U11 beats it with almost 70% more amps, but visually not by a lot. There is no moonlight level on this light, and for some that is a drawback. I like a moonlight level myself, but this would not stop me from buying the X5R if I wanted a very well priced light with built in charging… The indicator light behind the button works on low voltage for warning and stepdown. It does indeed blink red at around 3.1V and the light shuts off at 2.6V on the battery (old laptop pull) I was using to find this out. Turbo goes away below about 3.5V on my model when I was running the battery down, at least visibly, you can still click to a fourth level, but there is no real apparent change. I kept the light tail standing and bumping turbo up when the step down occurred. It got hot, but not threateningly hot during this LVP testing. The turbo quit sometime around 3.5V, like I said, and I kept it on the rather cool running high for another hour or so to get the indicator light to blink. Very good run times if needed, and this is "only" a 2000mah battery…
Overall, this light is a good value in my opinion. Two choices of tint and two kinds of emitters available, as well as fairly easy to swap the emitter for those that like other tints. The built in charger makes this a convenient light for travel or even work. The charger is fast and seems to do a good job without any issues… It is slim and easy to carry, if you do not like the stock clip, other ones fit, or attach a lanyard. I would rate it a solid buy… Thanks for reading!
jescereal
jescereal's picture
Last seen: 3 months 16 hours ago
Great light and review! Interesting that the turbo is lower than the 2.8 amps of the non rechargeable X5. I’m curious as to how far it throws with that XP-L HI. Also great that the modes are better spaced on the X5R. Turbo looked like it was 20-30% brighter than high on my regular X5.
NikolaS
NikolaS's picture
Last seen: 1 month 1 day ago
Thanks ReManG really good review, and I agree with you 2.2A is just fine for every day use.
Also is there 3 min turbo limitation like on others EE lights?
ReManG
@jescereal- I think for a light with a built in recharging circuit, something had to be sacrificed. The 2.2A is what I was reading and it seems that the turbo is not as regulated as the other levels, it gets dimmer as the voltage drops, below 3.5V there is no real difference between high and turbo. Still plenty of light at 2.2A in my opinion.
The XPL HI in a tube light seems to be a good combo to me if you want some better beam intensity. It is a good balance of throw to flood on a tube light. I use an XPL HI in my work A6 so I can see deep dark areas if I need something more than a headlamp…
@NikolaS- yes I forgot to add, the turbo timer is three minutes on the X5R, like all Eagle Eye lights…
jescereal
jescereal's picture
Good insight, thanks for the information! I agree that 2.2 amps is plenty bright.
pilotdog68
pilotdog68's picture
Last seen: 1 month 1 week ago
I’m glad you were able to do your review. Now I don’t feel obligated to return mine to stock form before modding it Smile
I think the X5R is a fantastic value
NikolaS
NikolaS's picture
How about group buy maybe we could get price down to 18-19 $ for 100+ pcs.
Should I contact GearBest?
Tell me what you think?
ReManG
NikolaS wrote:
How about group buy maybe we could get price down to 18-19 $ for 100+ pcs. Should I contact GearBest? Tell me what you think?
My plate is full, but feel free to put me down for one more XML2 3C version if you do start a Group Buy….
I think it would be a good GB…
@PilotDog68- can’t wait to see your mod…. MTG2?
firedome
great review !
thanks for sharing
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
upbeat
Last seen: 4 months 1 day ago
I have 2 on their way in the post…Cant wait to see the throw ? I was expecting a 100 meter extra with the new XP-L HI, like the Nitecore MH12 manages, 320 meter they say and only 300 in test, but still out throws competitors. – Has anyone measured the throw length ? – thanks §;-)
daninho
daninho's picture
Last seen: 3 years 4 months ago
Can you use the light for a long time in high mode? I think it says 2,5 hours on high but what batteries they used, was that with 3400mah 18650?
Is the internal charge function safe? Will it stop at 4,2V ? This looks like a really good light for the money, i also considered the X6R with sideswitch because it has a larger head for better cooling but couldnt find it, its sold out currently. It doesnt offer copper for cooling, right? Do you think the cooling was enough because im not a modder at all?
Altema22
Last seen: 3 years 9 months ago
Thanks for the review! Well done. I just bought two of these; one for me, and one for a buddy so we have a matched pair. Very nice lights, but I had problems at first with the light going in and out. Turns out the body was not screwed tightly into the head, and the lip of the body is what provides the electrical path. The batteries I ordered for them did not arrive yet, so I had to use protected 18650’s to test them out. The fit was so tight that it dented the negative end of my Nitecore batteries, and the positive button on my Eastshine 3500 cells. Not happy with that, but if it’s cell that you plan on keeping with just this light, then I would not mind. One of the lights also had a black spec of debris right on the emitter, which I had to remove by taking off the lens and touching it with a Q-Tip. I could see the debris causing damage, especially since this emitter has no dome. Speaking of hot, it does indeed turn down from turbo to high after 3 minutes (3:07 to be exact), and the temperature of the head was 106 degrees fahrenheit. Not a problem, as already mentioned in the review, and it seems to heat up very slowly in the high mode. I don’t see me using it in a way that would trigger a warning in high, and I would probably be using one of my other lights when doing long searches. It cools off fairly quickly anyway. The lanyard attachment points allow you to install it so the lanyard itself does not interfere with tail standing (like it does on the Nitecore EC4). BUT, the raised portions of the tail cap are so narrow that you need a smooth and level surface to stand it on. When tail standing on my desk with other lights from Nitecore and Nebo, the Eagle Eye is the first to fall when the desk is bumped. Of course, it’s not really a fair comparison with the Nebo Twyst, as that one is almost impossible to knock over Wink
For color temperature, I got the XPL HI 3A in the middle, and it’s a nice warm white… very pleasant, and even warmer than my Energizer 185L EDC, which I think just became my former EDC. I also keep a Nitecore EC4S with me most of the time because it has a beautiful beam pattern (to me!), and can rock 1000L without getting warm.
But, I can comfortably keep the X5R in my bag or pocket, while the EC4S is not quite as comfortable in the pocket.
All in all, I think the X5R was a very good purchase, and I’m sure my buddy will like his (once the batteries finally get here!).
daninho
daninho's picture
I have this light since several months and its really good. I would say the best cigar shaped 18650 light for the money. It offers just more features compared to other similar priced lights. I bought it for 23 dollar in the flash deal with XPL HI NW.
Altema22
I’ve had no problems using the light on high (450L) for extended times. This morning I put it in a holder, aimed it at the ceiling of a large auditorium, and left it on for about an hour with no problems. The entire flashlight heated up, but it was not uncomfortable to hold afterwards. I’m not sure what battery was used for calculating the 2.5 hour runtime on high, but I can test it in a couple days when the batteries arrive (still waiting!). I’m using a 3400 mAh Nitecore battery until the batteries I ordered for this light arrive. The charging stops at 4.11 volts, even if you leave it plugged in for a couple hours after the full indicator comes on. I’ll let the more experienced users chime in on the cooling. I do have a thermal scanner and can do tests in a few days, but the experience I’ve had so far is below.
10 lumens: No detectable heat.
180 lumens: Slight warming of just the head after several minutes. Body stays cool.
450 lumens: Head gets warm, and the body eventually gets warm as well. No risk of damage to the light, but you may want to give it a rest after an hour when using it in situations where your hand might get sweaty (warm environments or tense situations). Of course, I would consider this wonderful for cold environments!
1000 lumens: Head heats up almost immediately, but this mode was meant for short term use only, and the heat is expected. You can only dissipate so much energy into a body with limited surface area and thermal mass, which is why they have a 3 minute time out. It’s all good and working as expected, and I don’t regard it as a problem.
Altema22
I went through a thermal test with the Eagle Eye X5R today. All tests were logged after the light was brought back down to a static temperature, and were run with the light in the same position, which was horizontal on a desk. Temperatures were taken from the side of the head, and from the middle of the body. Temperature was taken with a Fluke 62 Mini IR thermometer, at point blank range to eliminate the background surface from affecting the temperature. In the trial runs with this method, the temperature of any object behind the flashlight had no effect on the readings. For turbo mode, there is a three minute timeout on this model, so the setting was bumped back up to high whenever this occurred. When I pasted a table, it looked ugly, so below is a screen image of the data log. Let me know if you have any questions!
JasonWW
JasonWW's picture
Last seen: 7 hours 47 min ago
I have the xml2 version of this light and it should be noted the the OP texture on the reflector is extremely light. It’s almost a smooth reflector. I get a very defined circular hotspot with this light compared to the X2R and Convoy S2+.
The X5R has a slightly deeper reflector than those 2 lights as well so it’s less floody, but the tradeoff is more distance. It’s got enough spill light to walk around with easily compared to a C8 light which is too hot in the center and not enough spill.
JasonWW
JasonWW's picture
I find my light manages the heat very well due to the way I use it in short bursts. Has anyone figured out a way to modify the stock driver to get a little extra power from it?
I think 3 to 3.5 amp would work well for this light.
Altema22
The X5R does have a decent spill. One thing I strongly dislike is an overly intense hotspot combined with a too-dim spill. The hotspot blows things out and makes the side spill useless. I don’t use the Rayovac Beast someone gifted me because of that, and it was so bad on the Nebo Twyst that I returned it. I still think the features of the Twyst were cool, but it was a disappointment in actual use. Shining it across a dark auditorium and being to ONLY see the podium on stage kinda killed it for me, lol…
Altema22
JasonWW wrote:
I find my light manages the heat very well due to way I use it in short bursts. Has anyone figured out a way to modify the stock driver to get a little extra power from it?
I mostly use mine in bursts as well, though it’s probably moderate-length bursts of a minute or so. That’s one of the reason’s I shy away from Olight, as a few seconds of turbo is often not enough for the way I use my lights. The step down on the X5R gives you a reasonable amount of time on turbo, and even my Nitecore penlight (MT06) stays on max for 3 minutes. I have not looked at stepping up the power of the X5R, as the highest sustainable output is 450 lumens, and even that gets a bit hot after 10 minutes. There are occasions when I will have the light on for extended times, like tunnel exploring, but when I need more light I usually just grab one of the bigger units.
JasonWW
JasonWW's picture
One thing worth noting was that the clip ends do stick out quite a bit on the X5R and became a real issue with me. I had to cut them off and round the edges real nice so as to prevent scratches installing or removing it. Now it feels great in the hand.
How do we do attachments here?
JasonWW
JasonWW's picture
Maybe this forum doesn’t allow attachements? Anyway, here are my mods. I just used an angle grinder to cut and shape it, then used a file to get the edges soft.
pilotdog68
Looks good Thumbs Up
Altema22
I am SO doing this! Those ends annoy me as well.
Rusty Joe
Rusty Joe's picture
Last seen: 21 hours 50 min ago
I love lights with UIs like this. No ridiculous coming on in other modes.
Very tempting little torch! Thanks for examining it!
noob
Last seen: 3 years 3 months ago
Thank you for the review! How does the X5R compare to the Manker U11, which do you prefer?
O.s.k
great review! Thanks!
avpx1
Last seen: 11 months 2 weeks ago
Hi All,
Just purchased and am ecited – first real flashlight as opposed to supermarket flashlights.
Can you recommend a battery I could get to maximize it’s performance. I have Samsung 25R batteries that I use for vaping.
Are they good or should I look for something else?
Thanks
JasonWW
JasonWW's picture
avpx1 wrote:
Hi All,
Thanks
That battery should be fine. This is not a high amp flashlight, only 2.8 2.2 amp at most, so no need for a high drain.
avpx1
Good to know.
Thanks Smile
Tangra
Last seen: 10 hours 31 min ago
I ordered this one:
Eagle Eye X5R CREE XPL HI 3A 1000LM Tactical LED Flashlight – 3A 5200-5600K BLACK
http://www.gearbest.com/led-flashlights/pp_345598.html?wid=21
A friend of mine went to get it from custom and report me this morning that there is a problem.
My Eagle Eye X5R can not change the modes and stay only in one. The button is clicking but nothing happened.
After few hours I will get the light and write what I saw.
Actually do not bеlieve in miracles, so probably there is a problem.
I am very disappointed about that.
Post info
The site is not Gearbest. It is Everbuying.
Althou I told to my friend to order from GB, but he choose another site and did not told me.
JasonWW
JasonWW's picture
Tangra wrote:
I ordered this one:
Is he clicking the rear button? That one is only on and off. The side button changes modes and it does not click.
Worst case scenario, the driver might be bad.
I bought 3 of the X2R’s and one had a driver issue where it wouldn’t go to high. It went low, med, med. Gearbest refunded me half the cost ($7) and I went to Jin Lang and they sold me a new driver for it for ($5).
The only bad part was waiting 2 weeks for the new driver. Swapping it was easy. I just had to solder the 2 wires to the emitter.
So I wouldn’t worry too much. When you get it, check the tightness of the parts. See if the side button feels right or not.
