I have a UltraFire 7XML SRK clone that puts out more then 3000 lumen stock - guestimate from ceiling bounce with a lux meter. It is 5-8% dimmer then the massive TR-S700 that has been reviewed here at 3500 lumen.
I would love this BLF SRK to go up to more then 5k lumen on turbo and 3k+ on high. More then that would require 6V/12V and a more complicated battery setup which will raise the cost. That would be for a future 12V edition you can start your car withā¦
Well, 4x XP-L V6 @3A each will make ~5000 lumens at start. I think Iād be happy enough with that output. It would be ~41.5 watts to the four emitters. Can the host take that? I donāt know. Iāve never owned a SRK. I seriously donāt want it pushed so hard that reliability becomes an issue. And I donāt want any ~6V or ~12V emitters in this light! Maybe we can work out ~6V emitters in V2.
Yes I think maybe you guys are right, the 10k+ lumens obviously needs the series cell setup and so is out of the scope of this.
Maybe a different thread for a totally separate light with series cells and XHP, obviously we would be looking at a $150+ light. Maybe not so much interest on BLF
Iām still looking forward to this light, shaping up well for the original design plan :sunglasses:
I might re-sub to the thread in 6 months or so and let the wizards do their thing, no way we will have this for Christmas is my guess
No point getting excited at the ideas just yet, just torturing myself!!!
The answer is simple: direct drive it to as many lumens as we can economically do. Implement thermal control instead of turbo timeout so it remains holdable at any ambient temperature.
I donāt care if it wonāt do max output for more than 30-60 seconds before going back to lower output. There are many cases where thatās all I need it for.
Wouldnāt know, thermal control is still on my list of things to experiment with. Ideally, it could be user configured to either a timer or a max temperature. One nice thing about the timer is that you can easily override it manually (eg. maybe youāre wearing gloves and can handle the heat for a while longer).
Agree, that's the sort of the direction I would go. Also I kind of like the idea where temp control backs up the turbo timer, so the temp control is the fall-back, set to trip a bit higher than normal. Of course turbo timers have some major faults, cell level for example. With DD FET drivers, fresh cells produce a lot more amps/heat than cells down to 3.6-3.8v for example - I've felt this.
For FET+1 drivers, the optimal most efficient setting I would think would be running the 7135 full out (0.35A or 0.38A), and the FET off. Think I measured this on a 5X modded light and was in the neighborhood of 160-185 lumens. Single LED lights are like in the 130-150 lumens range. It should bump higher the more LED's in parallel, but not drastically, so this result is expected. Most of my mode sets use the 7135 at 100% with the FET off. I call it 10%, but that's a pure estimate based on 1300-1500 is 100% on the 100% FET.
I've found my nice spread out mode sets for a single LED are not so evenly spread on multiple LED lights - the big jump is going from the 7135 to the FET, which of course makes sense. TK's mode sets she's calculated out spread the FET usage more evenly so work better in maintaining the output spread, as well as tint transitions. I preferred utilizing the 7135 exclusively in the lower modes, assuming better efficiency and better tint in the low modes.
This 2 different methods of defining mode sets both have advantages, which is why I include both methods - General Rule:if there's a choice of goin one way or the other for usability, let the user decide .
While weāre on the subject, Iād like the high which the turbo or temp timer drops to to be as high as the light can run continuously without toasting anything. Thus if you need max light you simply turn on turbo and forget about it till LV occurs.
Still loose with the rest, just want a useful ālumens bombā that will impress the peanut gallery :smiling_imp:
That all sounds good, and probably can only be achieved with temp monitoring. But of course depends what you donāt want to toast. My modded M6 ran for like 30-35 mins on max FET, fresh cells, got way too hot to handle but no internal damage whatsoever.
