I have some 20mm boards also, i am lazy/reluctant to start filing on them, not sure how much I can remove without hitting a trace that I don’t want to file away.
I’m hoping someplace sells Rebels mounted. Or even any appropriate bases I can learn hot air work on, in 12-16mm intermediate sizes.
I have filed a few 16 mm. stars to 12 mm. I have to scrape the top layer off the traces to expose copper to solder the wires to.
I think I have bought them on 16 mm. stars, but I can’t find where. Perhaps that was not in the description.
I tried a Luxeon Z a while ago, but making a copper board for them was a pain. I still have the little cyan luxeon z flashlight, gives a ton of light :-)
Wow.
Somewhere out there in the world is a 4xD M@g modded with four Cyan emitters, that I had years ago, til someone stole my car (sigh).
It was wonderful.
Nowadays I can probably get the same amount of light out of a single celled host …. time to try it again.
But I’m sure not going to work at the scale djozz does. That’s really beautifully done. Love the stereo images!
I just ordered a triple Luxeon deep red mounted on a direct thermal path SinkPad II.
Deep Red Rebel
It says max current 700mA, but also states that “Higher drive currents may be possible, but will require careful design of a suitable cooling system.”
I plan to run this DTP triple in an S2+ with a copper heatsink, and was wondering how high in current I can take it.
I have one of these leds and did a quick output test on a Rebel Sinkpad before doing the mod at the time. I never documented it but I think I remember that just like most colour leds 1.5A is a sweetspot, over 2A the output already drops.
I have three from rapid led on aluminium stars but only two are in lights. One is mounted in a 502b @ 1400ma and the other is in a JacobA60 at either 1750 or 2100ma. They have held up fine but can’t see lumen benefit from a ceiling bounce test. Both of mine are single mode lights with 7135 based drivers.
Hmmmm. After pretty much only using DD FET drivers for a while, it will seem weird going back to a 7135 driver. Like having an Amish flashlight.
So how many color emitters — in serial, and how many in parallel — would work and be enough to avoid blowing them up, feeding power through with a single li-ion and FET?
I probably need to just start blowing a few up to get this into my dense head, but any forewarnings would help.
I guess it depends on the cell you use. For three emitters to n parallel, you’d wan 4,5-5A max, so would need a real crappy 18650 with a protection circuit. I’m not sure what an 18350 would put out on DD, it could be the answer. Make my light an S2+ shorty.
Lifepo4 might be your answer. I used one to DD a PT54 red at about 8A. Don’t know about now but Tenergy did offer 3 different capicity/output cells. Typically high capacity Lifepo4 cells offer lower amperage output. Find some spec info. HTH
I posted my build for a Rebel deep red triple in the mod thread, but figured I should add the beam shots to rollinstone’s thread on coloured rebel emitters for thread integrity. It’s running at 4.5A.
Z
Z
Roxanne. ….don’t turn on the red light!
The deep red rebels are a bright cherry red as compared to the orange red of the XP-E2. These are nice emitters and pack a lot of light. I don’t know why everyone is a afraid to try a non Cree LED.
Bravo. And for cross-references, several others along this line fairly recently
WTB Deep Red LED Flashlight or build one for me …
http://budgetlightforum.com/node/43330
EDC flashlight with red light | BudgetLightForum.com
EDC flashlight with red light - 18650 Flashlights - BudgetLightForum.com
Thrower for Hunting - Any Opinions? | BudgetLightForum.com
Thrower for Hunting - Any Opinions? - LED Flashlights – General Info - BudgetLightForum.com
Joat’s build thread not for the contest. Color mixing Red Orange …
http://budgetlightforum.com/node/40551
OK. But are there any convenient places to get them not in bulk quantities and with shipping price not through the roof?
> convenient places
Depends mostly on where you live.
’oogled: "luxeon rebel" "deep red" - Google Search
Aside I went looking for little tiny Rebel mounting boards — wanting to try them in 1xAAA lights.
Does anyone know of a 9mm board that would fit into the BLF348?
(There are some 10 or 11mm boards that might be possible to file down)
This isn’t what I was looking for, it’s an old CPF thread, but it’s an interesting approach I don’t recall seeing, insulating the bottom and soldering to the top.
