We did alot of field testing and David (Robo) did heaps of side by side photography assessing CRI and object picture clarity at 200m plus. CRI defined as: the ability of a light source to reveal the colors of various objects faithfully in comparison with an ideal or natural light source.
Three main candidate leds - the XPL-HI, XML2 U4 1A, and XML2 U4 1C. We rejected the domeless XPL-HI quickly - cooler white tint in our led supply which as Here and Again notes blued and washed out colors down range. After alot of testing we chose XML2 U4 1A - much more natural picture down range and far better clarity. XPL-HI also less efficient - in comprehensive testing its lux output is approx that of an XML2 U2, but U3 and U4 alot better. Tested various leds in same torch for exact reference.
We had new 2X running at 370k with XPL HI but to get this it had to run at 6 amps - not stable and requiring step down after 2-3 minutes. Stepdown no good for hunting. With more efficient XM-L2 U4 we could use 4.5 amp boards with no stepdown for about same 360-370k output - plus better picture.
Acebeam too big for our purposes at around 800gms or 1.8lbs with batts, 50mm tube and big 88mm head. Slightly higher output than new 2X, but not weapon mountable, twice the weight, uses twice as many batteries, and more than twice the price. New lightweight 2X could be round $90…we’ll see.
As good as the BLF M24 was, this is going to be another must-have light even for those of us who don’t regularly hunt. The price makes me cringe but you don’t get what you don’t pay for and this will be an awesome value- count me in
I did the dedome on this particular emitter as well as the ones I put in my M24’s. Have not received the factory built light yet , but I did receive the driver (furnished by Maxtoch) and used the same emitter and MCPCB that will be in the lights from the factory. As stated in the OP I will do a full review and teardown (also post beamshots from the factory light) as soon as I get it.
As Mudgripz stated, after a lot of testing and side by side comparing , the Dedomed U4 is much better than the HI emitter for clarity and CRI downrange. This holds true in the M24 or the 2X lights , as I have both and have tested both LED’s for comparison in the 2 lights.
Here is a comparison of the two emitters. The XP-L HI and XM-L2 U4 1A dedomed with 4.5 amps.
Although taken about 3 weeks apart, the pictures give a fairly accurate account of the difference you see between the 2 side by side , as the XP-L HI always looks more hazy and has more glare to my eyes , and does not show the colors as well at distance.
Actually SawMaster this 2X with the dedomed U4 on medium setting , puts out slightly more light than the M24 from the GB does on high with the XP-L HI in the M24.
I am 95% sure the price will STILL be LESS than the Olight M3XS UT and the 2X has 120K lux more output too, with NO step down and better run times.
Very nice to see the further development.
Thx robo819 and mudgripz (and all that work with you).
Maxtoch really hits the sweet spot for me when it comes to affordable high quality.
I will in all probability skip on this one, as I already have a 2X (v1) and the Sniper M24. But all I can say is that these are 2 of my finest quality torches and they were worth every penny.
Interesting. I still remember when the XP-L HI was first released we are all amazed by its better tint compare to our DIY dedomed XM-L2 U2 1A or 1C which sometimes produces greenish tint. So now the dedomed XM-L2 U4 1A is even better.
Nice, i would like to subscribe.
Had tree 2x, dedomed and over 6 amp. all sold. Was sad to see they were not available any more…
Love that big reflector.
The only greenish tint I have had from any of the newer dedomed 1A U4’s so far is not the emitter , but one of the fields I do beamshots in is so green right now, it makes even a really cool light look greenish in the beamshots.
Was very excited when I read about this. I was ready to say “I’m in”, but then i saw $90 approx. and, out loud, said CRAP. This ones going to be too expensive for me. Not saying its not worth it, as my m24 is a stellar light, but just too much for me.
If I could afford it, I would prefer 6 amps and a step down to 4.5. I’m not a hunter, so its just for fun and the ooo,s and ahhhs.
Hunters could simply select the 4.5 amp setting and be good to go.
Thank you Robo for making this happen just the same.
Steve
