Olight S15R. Great moonlight mode which is what it is set to turn on to with a single click. It steps up to higher levels if needed but that seldom / never happens when it’s dark enough to need a light during the night.
JetBeam WL-S1 with a 16500 lithium manganese oxide battery, 1 lumen moonlight, ~900 lumen max. It’s a great all-round light.
My wife has a dollar store 9 led flashlight that puts out about 20 bluish lumens and I have a 1xAAA Utilitech key chain light that has a small aspheric and puts out about 50 lumens at max. I've had the utilitech for a couple years and it works good enough to keep from stubbing my toes on stuff. She has great night vision and never turns on a light, which irritates the heck out of me. I can't see anything in the dark, never could. Even moonlight is never enough.
My (shorty 18350) Blf A6 , with 15degree optical lens :cowboy_hat_face:
SmallSun ZY T08, UF-2100, NiteEye 10.
I generally have several on the nightstand, but the usual culprits are:
1. Walk-through-the-house-at-night: gently-driven SK-68 (my Gearbest Digital-Sand camo) with pencil-modded driver and LB emitter replaced with a more neutral XP-E2
2. Bump-in-the-night light is my FastTech C20 18650 EDC-style light, with always-start-on-high 3A driver, CW XM-L2, and 25-degree TIR.
BLF A6 5A bare and Olight sr mini
Olight S1 in moonlight memory, Convoy S2+ in lowest mode memory and BLF D80SE in turbo memory
Olight S1 Raw Cu with wand attached in moonlight mode. Turns out my wife likes having a nightlight so we turn it on each night before sleeping. Plus it makes for a decorative and secure light on our metal nightstand.
A rather flakey old Lumens Factory SP-6 w/ a XML 5C 3 mode drop-in + a trit vial lanyard.
I have my X6 SE under the bed. On the table at the end of my bed has my whole collection LOL
Stubby Eagle Eye X6 with a BLF A6 driver, starts on moonlight, GITD tailcap, and a red filter.
I think it’s a great size, and a bit harder to knock over than a 18650 tube light.
Nitecore EA21 - has red light for super low lumens, can start in 1 lumen low mode or turbo from off, side switch so it doesn’t wake up the wife
Also have the DQG Tiny AA stuck to the bed frame as a nice little reading light.
Trying out the BLF A01 Copper but I will probably go back to my Nitecore T0.
Long live 5mm LEDs!
I have 2 by the bed… I have a Thorfire VG10 with stock driver, XM-L2 4C and a GITD with red and orange LED’s, I find them good for sleeping and the ML mode on the VG10 is wonderful. I also have an S2 with triple XP-G2 3C with a very dim GITD tailcap with green LED’s. This is the one I grab if I think I need a lot of light!
Copper BLF A01.
A Thorfire tg06 as my “doing a quick scout of the house light”, and my sunwayman d40a as my “the power is out” candle substitute, with a diffuser on.
amber modded SK68 or amber modded #3 zoomie, and amber modded headlight — for getting around in the dark without waking the household with bright white light.
Something stunning if I need that as backup.
Nitecore sr3
For the same reasons many people mentioned above ……It is very stable face down because of the large wide SS bezel . I never liked knocking stuff over when reaching for a light in the dark .
forward clicky/ variable ring .
Rock solid
LED LENSER A3
