A Thorfire tg06 as my “doing a quick scout of the house light”, and my sunwayman d40a as my “the power is out” candle substitute, with a diffuser on.
amber modded SK68 or amber modded #3 zoomie, and amber modded headlight — for getting around in the dark without waking the household with bright white light.
Something stunning if I need that as backup.
Nitecore sr3
For the same reasons many people mentioned above ……It is very stable face down because of the large wide SS bezel . I never liked knocking stuff over when reaching for a light in the dark .
forward clicky/ variable ring .
Rock solid
LED LENSER A3
Convoy S2+ 18350 blue host w/ Moonlight Special 1+3*7135 driver and Nichia 219b emitter. Low moonlight is perfect to leave running on the nightstand, great tint, 18350 is plenty to run it for awhile and doesn’t need to get super bright.
A big crowbar.
Will make someone see the stars, even if it’s not a light.
Convoy C8, all purpose doing everything light. defaults to moonlight but FET/DD if needed………………
Olight S1
Fenix LD50
Spring bypassed Nitecore SRT7 for my left hand and a heavily modified Glock 22 for my right hand.
Armytek wizard Hi Cri
I don’t have a flashlight on the bedside table, just an RGB nightlight set to red only, behind a chair, and an amber one in the hall. If I need to find something without waking my wife up, I can take the red Inova Microlight out of my shirt pocket which hangs near.
Solraforce L2N with an intl-outdoor P60 (4 mode moon-low-med-high) drop-in from back in the day when I thought that cool-white is cool. With a Keeppower 3400mAh cell.
Olight S15ti on Eneloop. My loo light. The first couple of times I used it I managed to double click -> STROBE
That’s disco fever!
I have a little Xtar WK41 that I put a diffusor on.
On the lowest mode it works just fine :innocent: when getting up in the middle of the night.
Currently have a 47’s X3VN , a modified convoy c8(xml-hi, spring bypass and fet driver)
and my big light is a TK75VNQ Fiat Lux to blind someone with,lol.
Olight S10R Baton
Streamlight TLR-1 HL and an Armytek Doberman.
Maglite 4D nuff said.
502B single mode on a Saiga 12. Its good for light house keeping.
I gave up on putting a light out on the nightstand. Every time I do, the Wife puts it away.
Every now and then I get mad at her cause a coon gets after the Chickens and I can’t find a light.
She stashes handguns to but the shotgun is to big to fit in a drawer. :smiling_imp:
