Without wishing to create controversy. Out of those who want a particular led tint. I do not understand the much excitement with this flashlight. In my opinion the Thorfire S70 is better for some reasons…
Built-in voltage indicator on the mode button
Big head, throw more.
More accessories included.
Cheaper.
S0S mode. It is always better to have it than not having it, and with more reason when it is hidden.
Well the S70 is the biggest competitor for sure. Let´s be honest both lights will be very similar (and look very similar). Maybe the L6 will probably have a few more lumens out of the box but I don´t expect to be a huge (visible) difference, since many reviewers have reported the S70 goes way beyond the claimed 3000 lumens. it´s also easily moddable (as the L6 will be too of course).
The S70 is more on the floody side, maybe the L6 is more of a thrower. So everyone can pick his prefered torch. Win/Win
I´m sure as soon as the light is available comparison reviews will surface quickly!
K.
Andrew that’s Simon holding the light, not Freeme. The light isn’t listed for sale yet but it will be any time now. It’s a pretty safe bet that one of the first reviews will be coming from a photographer friend of mine.
Thanks for bringing this up! Right now I’m pretty much trying to decide between these two lights. I sure don’t want to argue with you, but I’m interested in discussing some of the points you brought up, if you don’t mind. Re. tint, I know it’s a big deal to some people, and not a big deal to others. Personally, I’ve found I really like using lights with neutral-to-warm tints, and I tend to avoid lights with cool tints. The cool/blue color is less pleasant for me to look at, generally less accurate at showing true colors, and it also seems to glare more off slightly shiny surfaces, making the light less useful IMO. Definitely an opinion, but it seems to be a common opinion around here, so I’d argue that tint is a pretty big deal when considering excitement about a new light.
Good point, and a potentially valuable feature! Maybe the biggest objective feature in favor of the S70. (Other features, at least those we know so far, seem to be matters of subjective preference.) Point to S70.
Probably, but we haven’t seen side-by-side beamshots AFAIK. Also a matter of preference, depending on your intended use of the light, so not an objective “better/worse” issue. Bigger head might be a downside for some, when considering storage or portability (not that either of these are pocketable lights…) Neutral, no points awarded.
Do we know that for sure yet? Thorfire is definitely great about including useful spare parts, but we’re usually talking about a few dollars worth of extras, so not a huge deal on the scale of purchasing these lights. Potential small point to Thorfire, depending on final offerings included with L6? (Maybe I missed where this was finalized; definitely haven’t seen a side-by-side of included accessories.)
Yes, but only by about $5 after respective coupons. ~9% discount (IIRC) is notable, but for most people a $5 discount isn’t a deal-changer on a >$50 light, if there are other subjective preferences pushing one way or the other. Still, this point clearly goes to the S70.
Eeesh - here we disagree! I’ve accidentally found “hidden” strobe/SOS modes on other lights, and find them useless and distracting. If a mode is so well-hidden such that it won’t be accidentally tripped, I can tell you I won’t remember how to intentionally activate it in some potential emergency situation. Point to the L6 IMO. (Actually neutral, another matter of preference.)
Conclusion: for someone looking only at objective differences, the S70 seems to be a winner, and for many it might be the obvious choice. But there are some smaller subjective differences that are swaying the decision for me, and I suspect for others as well. For instance: I like the size and shape of the L6 head vs. the bigger/blockier look of the S70, I don’t mind a slightly floodier beam (if that’s actually the case), I’d strongly prefer a neutral tint, and I don’t like strobe/SOS modes. I’m willing to pay an extra ~$5 for those features. I’m waiting to find out more about the neutral emitter, and to hopefully see side-by-side beamshots of these lights, but that’s the way I’m leaning. (Again, not trying to argue or defend one “side”, just explaining my thought process!)
A couple s70’s have indeed a voltage indicator but iirc it was never listed as a feature. And the s70 now comes with a dark grey switch cover which makes the voltage indicator useless.
I have to admit, it’s a nice feature.
For start they have already confirmed they will not include adapters to 18650. In addition, now that I’ve noticed, does the convoy l6 head support for a belt? Seems not, Can any confirm this?. That would be another point for Thorfire, which has the hook, and includes the belt.
SOS is hidden, but it’s easy to find XD. Just need a sustained pulsation. I not like in general this type of modes. But you never know when you will need. So, for many excuses you can put, it’s definitely an advantage to have SOS, being that is hidden of course.
All S70 have voltage indicator. And for those that come with gray button, you can buy a translucent button for 1 dollar.
I think you’re wrong with the dimensions of the reflectors. The OP says that the head diameter of the Convoy L6 is 72mm and the reflector diameter is 65.8mm. You are comparing the 65.8mm of EXTERIOR diameter of the Convoy Reflector with the INTERIOR diameter reflector of the S70. I think the 65.8mm measure is for EXTERIOR diameter of the Convoy.
The diameter of the head of the Thorfire S70 is 74mm, the exterior diameter of the reflector is 67.42mm, and the interior diameter is 62 mm.
So what you have to compare is the same measures for both headlights:
