I âmoddedâ the new Trustfire TR-J20 and gained 1000 lumens plus a few. Easy peasy mod, as it were. My Trustfire 32650âs came in from Richard, they bested the BASEN 26650âs by that 1000 lumens. Sometimes the right cell choice is HUGE, taking this one from 17.64A to 21.71A at the tail.
The UCLp lens gained me just shy of 400 lumens as well. So for a lens swap and the right cells Iâm up 1400 lumens. Iâm taking it!
Must admit Iâm really liking that yellow gold tailcap. Todays mod was another s2+. This one with A6 driver, triple CU spacer and triple V2 1A. This was a first in that the triple was huge. I tried the carclo and multiple hosts all nogo. First glass only triple. A little too cool for my liking but it certainly fills a room. Heading outside now. Also finished one that did nothing but cause problems.
Yesterday was an all out blitz on the lathe to complete 7 lights with heat sinks for a friend. 7 hours on the lathe, then I came in and re-assembled the lights. Each light had cooling fins cut and some additions to aid grip on the tube. Even made my first cutting tool from an old (some 70 years) High Speed Steel planer blade.
I wanted to increase the current transit, but I also wanted that the change was fully reversible; so I removed the spring at the base of the tail and replaced with a spacer, realized by compressing the aluminum foil. The compactness of the spacer is such that even the front spring is compressed up to touch, between them, all the coils.
I got a good increase in current flow, I think a good 25% (When I can I will make the instrumental comparisons).
And now I can use the protected battery, both 26650 (test with protected Soshine 4200) and 18650 (test with different protected batteries).
The spacer for unprotected batteries is 10mm thick; for protected is 6mm thick.
i also have a red flashlight! and i even know why i built it! :student:
I havenât used it much neither. but since the host was called torpedo, and looks like one, i thought about submarines and red light, so i put a red xp-e in itâŚ
yesterday and today i made my first triple! A red convoy s2+ with xm-l2 4c that lacked the UI of a nice BLF fet+1 driver that my A6s haveâŚ
I didnât have any spacer, so i made one from cheap copper boards and copper pieces probably salvaged from somewhere⌠not sure if the heat transfer will be optimal, but hopefully good enough!
I used one of the blf fet+1 drivers from banggood, so i guess turbo timer is somewhere around 90 sec, probably too long for this 35 W flashlight.
The leds i used was a mix of 3x XP-L: v6 0d, v5 2a and u5 7a (at least according to fasttech)
when i compared the tint to xp-l 5A and 3D, it was less ârosyâ than 5A, and less green than 3D.
Bypassed springs, and ~11A with HE2/HG2
Made an extension tube, pretty little thing! Danged square threads were just about the death of me!
Polished it to a mirror finish after taking that shot, man does it look sweet!
And while I was at it, I scrutinized the details. The devil lurks there, donât ya know! I removed the ano under the driver for better ground contact, and removed ano on the end of the battery tube as well as bottom of the head for a clean al to al contact between the battery tube and head. Paid off!
Amperage is up from 21.71 to 23.03, Lumens is up from 12,765 to 13, 524!
Thatâs probably where it stops, but folks, look for the little things, enough of those addressed can make big differences!
Yes. Itâs the little things. Iâm not in a rush anymore, and like paying attention to the small details that can all add up. Good going Dale! Be a resistance miser.
Thrunite T10T triple XP-G2.
Out of Nichiaâs & Noctigons for the moment , can swap some in later.
This was just doable taking the optic down to around 16mm.
Still has stock driver so i used an aluminium MCPCB and a couple of 1mm layers of copper soldered together for the heatsink.
