Astrolux M01
It’s very hard for me to say no to a Nichia flashlight. I was wondering, should we make a list of Nichia high CRI flashlights? Or would that cause some of us to spend even more than we need to???
M01 seems to be very popular. Already 130 preorders at bangoods. :beer:
Is it a bad assumption to think that all nichia 219B’s are all high cri .?
Yes.
Wait, then should I be concerned that this Astrolux M01 did NOT advertise the Nichia’s CRI value?
Since the battery is not protected and the flashlight does not cut off below a certain voltage, is there any cue as to when the battery is due to be charged? A noticeable dimming? Or do you take your chances on running the battery down too far and damaging it?
While it is possible that they used one of the lower binned lower CRI versions, I doubt they used it because the main draw of having the 219B is the high CRI version. But without knowing exactly what 219B they used, it is technically possible they used the lower CRI version.
Other lights in this style are pretty dim at about 2.8 volts. This is a good voltage and you will definitely notice when it’s time to recharge… but in case you forget to turn it off, you will probably damage the battery.
Is the dimming noticeable in low mode as well? If it isn’t it will be quite easy to kill the cell…
M01 specs list low mode as being 8lm so even when it drops 50% it could be hard to see the difference due to eyesight accomodation.
I personally like the idea of 10180 light with internal charging but eagerly wait for good execution because as of now there is none.
Maybe Astrolux M01 enhanced…
There’s simply too many drawbacks:
- no low voltage protection
- low quality unprotected cell
- too high charging current (it would appear all brands use same driver and advertise 1h charge time which is essentially killing cell with ~2C charge current)
- no knurling on the head (being a twisty it would be desired)
  • no tailstand/ugly tail attachment
IMHO M01 is the ugliest of this class of flashlights - mostly due to its tail design. Jetbeam/Niteye MINI - 1 looks better and cost ~$17. CooYoo Quantum SS/Mecarmy have best head design - ie. many axial grooves (more than Blackwater kite) and it looks very good as well. Both Cooyoo and Black Water Kite SS have better looking tail part than M01. Kite even have tritium slot but have ugly head - to me brand logo and font are simply hideous and are the reason alone not to buy. Kite is really bad name for a flashlight as well. Best tail design is present in titanium Coyoo/Mecarmy.
The only advantage M01 have is the Nichia LED but you could always change LED in other brand…
For me to even consider buying ugly M01 it would have to cost 10$.
I would really want something looking like DQG Spy (knurling) but with secondary optics. DQG Hobi Plus is close but lacks knurling and tail standing.
There was a report about some measurements/ observations in the TLF from member light-wolff about the CoYoo quantum Ti;
I believe all of this lights behave the same
http://www.taschenlampen-forum.de/threads/kurzreview-cooyoo-quantum-cr.43503/#post-582930
In summary:
On Low there is under 2,2V less then 1µA and under 2,0V current stops totally (< 0,1µA); Then the battery remains on 2,0V; That may be not so good for the battery life, but it´s not that dangerous;
On High there is a bit more current: 130µA on 2V, 65µA on 1,0V. That means that could exhaustive discharge the battery. But that should be a matter of days, not hours;
I´ve had one of these batteries which died, not in the light, I carried it in an battery container, I don´t know why this battery died but that´s not that loss;
You can get a replacement on GearBest for under 2$
http://www.gearbest.com/diy-parts-and-tools/pp_136125.html
Im ready to buy this,is there a discount code?
The BG site is showing 19.99.
Thanks guys
There is no code. The first 100 preorders were 15.99$, second 100 were 17.99$, …
Unfortunately, you’re a bit late. But it’s still not a bad price if you want one of these.
Ok thank you….im still going to buy it…
Hey chooma, see also this Jetbeam mini-1 for $17.15:
http://www.gearbest.com/led-flashlights/pp_279764.html
There’s also CooYoo Quantum SS deal for $21,59:
http://www.gearbest.com/led-flashlights/pp_228097.html
Both lights differ from M01 in external look and used LED (it’s XP-G2 so lower CRI but higher lumen output), but inside electronics seems to be identical.
Personally I’m waiting to see titanium M01, maybe it will have better tail design as other 10180 titanium counterparts.
My units are shipped :partying_face:
So funny! We are hopeless. This is a terrible light with so many faults…but if it is only $10, I’m in!
How many lights have I bought like that, lol!
Mine is shipped too! :smiley:
So true… Besides - I like the name :sunglasses:
Yep, shipping notification here as well :smiley:
Mine is on it’s way, too. With a couple of spare 10180’s in tow. :sunglasses:
