18650 TrustFire Flames 2400 mAh Battery Test
Tail Cap Current Draw Comparisons
Test 1 Ultrafire Cree T6 3-Mode Memory LED Drop-in Module
solarforce 2400 mAh (A) 1.67 amps
solarforce 2400 mAh (B) 1.67 amps
Ultrafire (grey) 2400 mAh (A) 1.23 amps (from buyincoins they only take 900 mAh)
Ultrafire (grey) 2400 mAh (B) 0.7 amps (from buyincoins they only take 900 mAh)
Trustfire Flames 2400 mAh (A) 1.51 amps
Trustfire Flames 2400 mAh (B) 1.50 amps
Redilast 2600 mAh (A) 1.70 amps
Redilast 2600 mAh (B) 1.71 amps
Hi-max 2600 mAh (A) 1.44 amps
Hi-max 2600 mAh (B) 1.45 amps
Panasonic NCR18650A (A) 1.69 amps
Panasonic NCR18650A (A) 1.72 amps
Test 2 TrustFire TR-3T6 Triple XM-L T6 5-Modes Memory LED Flashlight (3x18650)
tested with 2 x 18650,s
solarforce 2400 mAh 2.46 amps
Trustfire Flames 2400 mAh 2.51 amps
Ultrafire (grey) 2400 mAh 0.00 amps as they just tripped on high.
Redilast 2600 mAh 2.5 amps
Hi-max 2600 mAh 2.51 amps
Panasonic NCR18650A 2.38 amps
Test 3 TR-1200
solarforce 2400 mAh 1.66 amps
Trustfire Flames 2400 mAh 1.72 amps
Ultrafire (grey) 2400 mAh (A) 0.00 amps as they just tripped on high
Redilast 2600 mAh 1.74 amps
Hi-max 2600 mAh 1.81 amps
Panasonic NCR18650A 1.61 amps
I can not recommend the ultrafire grey's from buyincoins as only 2 out of 4 worked they only take around 900 mAh, one was reading 1 volt when put under load and with the plastic cover removed they looked like they had spot weld marks on them so i asume they are recycled laptop batteries.
So i give the flames the thumb up sofar for best bang for buck and it looks like my drop-in,s and my C8 are under driven even though the Trustfire C8 has the same driver as the KD C8 from the factory.
I will update the current draw tests and the new batteries ive ordered come in and i will swap a driver out for some thing with some more grunt to do some higher amp testing, hope this helps.
I think you really need some different leads for your DMM (or a different DMM). No way all three have that low of a draw. Those p60s should definitely be 3A+.
The current draw was check with two DMM's a Fluke and a cheapie they both are with in 0.01 of each other, i do not believe in changing DMM leads to give fase high readings (just my opinion).
The trustfire C8 has a 2 amp driver in it the same as the KD C8 and ive just swaped the driver in the Trustfire C8 to another 2 amp driver and im getting 1.97 amp,s at the tail cap Wink every thing else test out on par.
The drop-ins and the C8 (before driver change) are putting out around 500 OTF lumens there is not 3 + amps hiding in there drivers, they are under driven and if you check early pictures of the P60 drop-ins the drivers have changed.
Im still buying more of these drop-ins as they have a nice tint and only 3 modes (H,M,L) 1.5 amps is enough there is not much more throw if you double the amps just a brighter hot spot IMO and the drop-ins get way to bloody hot running 3 amps or more as at 1.5 amps they get hot enough.
The drivers have to be faulty and going into direct drive to get more then 3 amps IMO from 3 amps to 5 amps an XM-L does not make much more light at all it just makes a lot more heat.
I have rechecked the internal resistance of new Trustfire flames i tested in post number 75 of this thread on another battery holder from post number 11 on this thread without the rare earth magnets and im getting aprox 50 milliohms less.
So i think i was right the rare earth magnets are giving me higher internal resistance readings, you could say some/most of my readings are 20 to 80 milliohms higher then the tested batteries realy are.
Also the IC,s (pcb protection) have a TR part number on them, like some of the trustfire drivers and torches.
As an example of the diffrence in milliohms, i tested my new solarforce 2400 mAh batteries with the rare earth magnets on the set up i posted on post number 67 my solarforce batteries read 140 to 160 milliohms but if i use the battery holder from post number 11 on this thread i get readings a hair under 100 milliohms.
I thought i would mention this as so people could take this into account and the lower the internal resistance the better, it makes the Trustfire flames batteries look even better.
Re-tested of the internal resistance of the new trustfire flames from post # 75
Cell A 137 milliohms
Cell B 112 milliohms
for all other internal resistance test i will use the battery holder from post number 11 ok.
Picked-up 4 TF 2400 mah protected from DD for just over 14 bucks delivered, with xmas discount.
Going to give them/charger/FryRay 818 to my elderly dad for the holidays.
Hope they are up to the task. The 818 pulls just over 1.75 amps on high, so it is one neutered, purple output fuster-cluck from MF. Luckily, the low output will work in the batteries' favor. He should be thrilled with the light.
I ordered a TF-1200 Q5X5, to replace it.
I hope it fares better than the FryRay junk I've purchased from MF!
r1derbiker have you not read all the crap about DD with there fake flames and sending out unportected batteries when you order protected ? not all flames are equal here is the linik for you.
https://budgetlightforum.com/t/-/4453
Why do you think i bothered with this thread, there is to many fake or junk flames being sold giving the good ones a bad rep. Some times cheaper is not always better.
The genuine TR-1200 is a great light but there is some fakes been offered cheap that are unregulated and have plastic lens with only 2 x 18650 battery tubes.
The geniune TR-3T6 is a much better light then the Fry ray 818
Didn't see that, Benckie. Uh-oh.
The tr-1200 I ordered has the extension for 3 batteries, and a glass lens. I should be OK there.
I'll know quickly about the batteries. Have several hobby chargers from flying RC for years.
I don't do business with MF any more, after getting screwed with their customer service on a 3800 and 818.
It does seem that with most all vendors we deal with on BLF; buyer beware!
Yes pick and choose products carefully that have been tryed and tested with replacement parts if you can, a seller is only as good as there supplier.
I personally like manafontand Jim has looked after me but I'm fussy with what I order. I would order from manafont before I will order from DX, DD, Focal point and so on, I don't order any thing electrical from eBay that is flashlight related cause I've been screwed more times then I've won.
The reasons for reviews and me doing 70 + hours of dishcaharge and charging is to show people what is ok and not ok to order as there is alot of yeah this is good and cheap but they turn out to be fake some times or the sellers are painful with incorrect orders and most people with out hobby chargers would not even know if a battery is ok or not.
Every one here wants to save money and get the best bang for there bucks but my short time on here I see the same people suggesting the same sites or untested products, people can say that about me and that's fine, but I see so many fellow torch freaks getting caught out.
Maybe I'm looking at it wrong or over thinking it as some times the deals are great and some times they are not, people talk about china being a lucky dip and this can be true, I might be crazy thinking it does not have to be this way and we don't need to spend big $$, maybe peoples expectations are to high from this cheap stuff and it's cheap for a reason.
So buy what you want from we're you want just becareful and never spend any more then your willing to loose on the net, that's the way I look at it.
a link to my redilast 2600 mAh battery test.
https://budgetlightforum.com/t/-/5025
a link to my solarforce 2400 mAh nattery test
https://budgetlightforum.com/t/-/4958
a link to my hi-max 2600 mAh battery test.
https://budgetlightforum.com/t/-/5082
3 amp discharge test from fully charged (these are the new cells from post number 75, not the used cells i was testing before post number 75)
Cell A
Cell B
These performed well for bang VS buck
Thats the proof i need to say they are good for single cell lights aswell as multi cell lights
very nice job ty
you are testing also your iCharger right? xD
My Icharge 106B+ has had the firmware updated and has been calibrated by me and i check it now and then so its pretty spot on. ive had it for about 12 months or so, I use it to charge my remote controll li-po batteries for my truck, xbox 360 controller batteries, batteries for my daughters kid toy,s and digital camera batteries plus my torch batteries (mainly 18650,s).
It has proven to be a good reliable charger, it has payed for its self and it gets used every couple of days and some times its left on charging or discharging for a couple of days at a time, doing these Trustfire Flame 2400 mAh battery test,s i had it running none stop for 4 days over the long weekend.
The P350 power supply has been very good as well it has not skipped a beat in the same amout of time ive had the charger, its a bit of an over kill 15 volt 23 amps or 350 watt power supply as my charger is only 10 amps or 250 watt charge and 7 amps or 20 watt discharge, but it give,s me room to upgrade later on down the track and i use it for other things aswell.
You dont need such a big power supply for the Icharger 106B+ it will run off a 12v car battery or a 6 amp 15 to 18 volt power supply like a laptop power supply (minium 6 amps) or a computer power supply if you know what your doing, the higher the voltage the more efficient the charger is, 18 volt max.
I think the amount of use my charger gets and the time its left on charging or discharging i would of killed a few laptop 6 amp power supply,s by now, im glad i got the P350 power supply and for the record you must keep an eye on all chargers and batteries while being charged or discharged !
If your intrested here is a post about other uses for hobby chargers like the Icharger
https://budgetlightforum.com/t/-/1621
And one about balance charging li-on batteries like 18650,s
https://budgetlightforum.com/t/-/3118
Benckie,
As I said in the other thread I scored some of the TF batts against my principles from MF and just included them in with other stuff I was after from them.
Have read the above here and like you say for the money it's a good deal, what I want to do with them is 2s in parallel with xm-l using a 2a driver at 4.2v.
I'll do a post of my findings of them and it might help with info on MF supply consistency.
One thing I'm concerned with is the cut-off protection regulation on them though which appears iffy? Can you confirm.
I use Multiplex chargers.
For anyone interested in PSU supply a simple ATX computer type needs no wiring or resistor mods for voltage increase etc. Just use the double socket 12v output cable supply fitted to them. Cheapest most reliable switched PSU choice.
I've modded many a PSU and the ATX type has the ability to hold voltage and doesn't need anything doing for the lower wattage hobby chargers you are using and cost's peanuts on the bay.
M.
ANL, I've got 8 supplies in use (4 in parallel, for some high current testing), all salvaged from computers over the years. They work dandily, for my +5 and + 12 volt needs. Just switch (connect) the green to ground on the 20 or 24 pin plug, and you have 12 on yellow leads, and 5 on red leads volts.
Good tip.
I has a couple that didnt work well with the cut off but i crushed them in my TR-1200 all the rest have been fine including the new ones i tested they are no worse then solarforce, hi-max, redilast, the trustfire flames will go down to 2.75 volt.
Coooooool.
Yeah,
For heavy current/wattage chargers I use Rack Server PSU's but an ATX 3-500W (£7 or so delivered or 'free' if hustled locally s/h) is good to go with smaller hobby stuff and the +5v red to black earth is used on them for R/C rx bench running, 3.3v handy for led testing/power on indication etc.
A 5A wall plug switching psu is fine too on 50w ones.
Almost forgot! The 4 in parallel are identical supplies, to keep things balanced.
Way to go, must be an E-Biker on li-po?
Are they ATX standard or upped with resistors?
If people are wondering how i come up with the above data table's i posted on this battery test, i data log using my icharger 106b+ connected to my computer for my battery tests, i use a program logVeiw V2.7.4* with icharger 106B+ with firmware v3.14 upgrade and then recalibrated the charger.
I use this program for my data log,s and for the data charts i post
http://www.logview.info/vBulletin/content.php?47-screenshots_1
I use the data tables instead of graphs becuse i find it simple and think it would be easy for other people to read and the data tables includes charge time updated every 2 seconds, voltage, watts, engery, mAh, plus induvidual cell voltage for upto 6 cells, internal temp of my charger, battery temperture, the chargers imput voltage from the power supply and so on and i can not get all that infomation on one graph.
I usualy only include the end of the charge cycle then hit the print screan button on the key board while the logVeiw program is running and opean on the screan of my computer, save the image in paint, then crop the image down with microsoft picture it! then up load the image to photobucket then post the image on the thread.
I cut out things like battery and charger tempture and induvidual cell voltage if im only doing one cell at a time to test.
