Sure, won’t be tonight though, the desktop just got shut down.
Can you measure what size the hole needs to be, and how big the base of the switch is? (to see where I need to put the pos/neg terminals and resistors)
I think you mean the normal 5.1 then. (5.1x is the crazy individually-addressable version). The nomenclature is a bit out of hand, but I don’t know what to do about it
The one I really like has 6 led pads on the top and 3 resistor pads on the bottom and 2 wire vias. If I had the pots, I would maybe go that route since they can be adjusted…
Pots are pretty nice, just so you don’t have to constantly be soldering/desoldering to dial in the brightness. If you want I can try to do the pads for pots and then you can bridge resistors on the pot pads. Or I can do the three-resistor setup and if you want to upgrade to pots later you can just pair these boards with the Rev4 pcb at that point.
It would be fine if they were 2 sets of 3 leds that could be pots or normal 0805’s. I may try to find the pots. I do like the option of having 3 different colors.
Really, just the standard ring with 3 resistors would be more than fine. I tried to ream the centers, but that did not go well. I would be after the 17mm ring, maybe a set of 19mm’s as well.
Have not received the clear gaskets for the S2+ yet, and I do not know how many Simon has sent to me. When they arrive I will report, and also will put one in a red S2+ that already has six nice red leds that for now are illuminating just the inside of the tail.
Here it is. Unfortunately I couldn’t make a 17mm version, as the base of the switch is too big. Even on the 19mm diameter the resistors are pushed almost all the way to the edge. Interior ring is spec’d at 8.4mm, probably will be 8.1mm when you get it from Osh.
I will try it… the resistors on the 17mm that I have used so far have set on the switch but it seems to work fine. Will try to get a pic this weekend for you…
So far the hole size has been the only problem. When I sand the stem housing down, they seem to work ok. Those resistors are so thin… a tiny bit of plastic would hold it level if needed.
Is the following the timing issue seen with too high a bleeder resistor value or is it something else altogether?
I have a FET+7135 driver with OTC and a bleeder resistor (470 ohm), however, it now has a strange issue where if the light gets hot, the switch timings shorten considerably so that short-click is impossibly fast so that I do a medium-click instead. The timings become normal again when cooled down. The lighted tailcap works perfectly.
This issue occurs even when just a wire is used instead of a tailcap.
I have seen that a few times. The worst one I have is an S2 triple, when she gets to hot the modes are really unpredictable. I am going to change it the the H17F driver and see if that settles it down. I should since it ramps on temperature, from what I have read it does the ramping very smoothly and with a fair amount of intelligence.
