Another caution - not sure if noted yet. Don't over tighten the bezel. The outer edge of my lens cracked and splintered. I removed the broken chard's of glass, and it is totally hidden when assembled. I can't be sure if it came like that or I did it the first time re-assembling.
I think there's something wrong, or bad tolerances up in the inside top of the bezel, because I don't think the Z1 had this problem. There is an o-ring there, like the Z1, but this stuff is probably very sensitive to tolerances and design.
Since mine is all tweaked up, greased up the zoom threads (better but not near as good as the Z1), and really thought I could gift it or sell it, but that bezel concerns me, if all someone has to do is give it a good CW crank.
Huh? Wut do you mean? My Cometa has a Noctigon, painted white, but a Noctigon.
Bistro uses thermal regulation for step down, you have to configure it by running the light on Turbo in level 7 until it is the amount of heat you’re willing to live with, then turn it off. It will then use this reading as it’s base for stepping down (or stepping back up when it cools down)
Enter configuration mode by clicking 16 times, the light will stop responding to your clics, each level will blink softly once for the level than “stutter”. (Yes, it takes a while to wait out all the levels blinks and stutters)
At Thermal configuration (level 7) bump (short press) to enter this level…the light will then come on in a medium level. If you turn it off here step down will be disabled. Leave it on in this med mode for a couple of seconds and the light will step up to Turbo. Do this with fresh charged cell, run it till it’s as hot as you wish. Turn it off. You’ve just configured the thermal step down.
Most Bistro drivers come in with the Thermal regulation activating at virtually ambient temperatures. Set it once like above, then forget it. This will solve your step down issues.
Hot is hot, regardless of what level causes it. If the setting is too low, then the ATTiny25 attempts to reduce power to alleviate the low temperature setting.
I guess it would take an individual setting each and every light before shipping them out to have that working properly upon arrival, so of course it’s left to the end user only they don’t mention it.
I just made my Cometa safe with 2 insulators. And I bypassed the driver spring (which was single in my light) and I changed the emitter wires to 18AWG.
Now I read 4.9 AMPERES at the tailcap on turbo! Using one of the “lightweight” BASEN 26650 from the GB.
Wow!
I read some 4.15 before the mod. But I’m doing Ampere measurements with the DMM using short bare wires.
Or maybe there’s some other variation! As I don’t have other 26650ies I’ll try with some high drain 18650 and report back if I get significantly different readings.
The UNI-T cheap meters have outstanding quality, believe it or not, for high amps measuring. I work with a "super tech" here who swears by them, has several all over the lab, and the amps measuring circuitry he says is as good as his high end Flukes. $15 is what I paid for mine from eBay. It's this one at FT:
If the wire loop is repeated, does the ensuing readout need to be divided by the number of loops?
IE: If 3 loops are used and the readout shows 12A, would that indeed be 12A or 4A?
Noctigon Copy. Shaped like a Nocti but look at the cut outs for the leads, 2 lead holes, 2 narrow hold down holes. My 20mm Noctigons measure 20.5mm this copy measure’s 19.8mm. Probably why you have a bigger clearance around the Cometa pill mcpcb pocket, board can move around more?
Ahhh, you know I didn't look close, but not surprising! Thought the X6/X5 threads said they were painted over. Maybe that was in the early phases? Hhmm - ok, good to know... So does that mean the X6/X5's were these same copies?
Yep, your welcome Tom! I used a real Noctigon and the emitter is centered and less chance of clipping the emitter pad corner when you put the cover on, probably help with the leads touching the cover too, since you won’t have all that slop!! Check out the driver pocket 18mm O.D. 16mm I.D. not the same as my JAX X6 pill, probably the X6 pill is the same as the Z1 ? Not the cometa pill when it comes to driver component clearance??
