Thanks Dale, my bad, should have known that!
When you say different leads, do you mean thicker? I.e. 10 or 12 awg leads?
If you just used a different pair of thin leads that won’t aid in seeing higher numbers.
I just made my Cometa safe with 2 insulators. And I bypassed the driver spring (which was single in my light) and I changed the emitter wires to 18AWG.
Now I read 4.9 AMPERES at the tailcap on turbo! Using one of the “lightweight” BASEN 26650 from the GB.
I got 5.79A tail on a clamp meter (UNI-T 210E) with the stock 24 AWG LED wires and stock driver spring, on a BASEN cell at 4.22v.
With the tail spring bypassed, and NO-OX-ID treatments and Nyogel on the o-ring/threads in the tail, I got:
Lumens: ~1,139 @start, ~1,071 @30 secs, 146.5 kcd taken at 5m (765 meters), all on a V0 3B stock XP-L HI
Wow!
I read some 4.15 before the mod. But I’m doing Ampere measurements with the DMM using short bare wires.
Or maybe there’s some other variation! As I don’t have other 26650ies I’ll try with some high drain 18650 and report back if I get significantly different readings.
The UNI-T cheap meters have outstanding quality, believe it or not, for high amps measuring. I work with a "super tech" here who swears by them, has several all over the lab, and the amps measuring circuitry he says is as good as his high end Flukes. $15 is what I paid for mine from eBay. It's this one at FT:
I also bought from FT this one, because of better features like auto power savings:
https://www.fasttech.com/products/0/10002748/1204400-uni-t-ut50b-25-lcd-handheld-digital-multimeter
Of course you still have to use short heavy leads... And, a clamp meter will still read higher, more significantly at higher amps.
If the wire loop is repeated, does the ensuing readout need to be divided by the number of loops?
IE: If 3 loops are used and the readout shows 12A, would that indeed be 12A or 4A?
Thanks, thought I’d heard that but with my memory it pays to double check.
When is this practical? A light with like 2.3A and a 20A setting on the meter? Something like that? Or say a 500mA UV light?
Yeah, uh, NO. I just added up my expenditures at 3 stores and figure I’ve spent my coffin money on flashlights. :confounded:
(there has to be a joke or pun here somewhere)
My wife would kill me and scatter my ashes in the beams of my lights if she saw the totals on what I’ve spent in the last couple of years.
Noctigon Copy. Shaped like a Nocti but look at the cut outs for the leads, 2 lead holes, 2 narrow hold down holes. My 20mm Noctigons measure 20.5mm this copy measure’s 19.8mm. Probably why you have a bigger clearance around the Cometa pill mcpcb pocket, board can move around more?
Ahhh, you know I didn't look close, but not surprising! Thought the X6/X5 threads said they were painted over. Maybe that was in the early phases? Hhmm - ok, good to know... So does that mean the X6/X5's were these same copies?
Thanx KB1428!
Yep, your welcome Tom! I used a real Noctigon and the emitter is centered and less chance of clipping the emitter pad corner when you put the cover on, probably help with the leads touching the cover too, since you won’t have all that slop!! Check out the driver pocket 18mm O.D. 16mm I.D. not the same as my JAX X6 pill, probably the X6 pill is the same as the Z1 ? Not the cometa pill when it comes to driver component clearance??
Take a look at the solder pads on the Noctigon compared to the BLF Kronos? See a difference? Look at the difference in the DTP pads too???
Oh boy, gotta take a better look for sure now. Your pics really tell the story of basic differences - another case of apparent cloning. Dunno, must have missed this if it was discussed and noted before. Sooo many risks I'd think with a new MCPCB, different manufacturer, but really, Hank's were not so perfect and consistent over time - it's been detailed here on BLF, and emailing with Hank, he's had some stories of bad batch's, and bad pieces, etc.. But I always liked Hank's own QC with his knowledge and concerns, and good designs.
I'm gonna swap out the LED anyways, probably de-domed XP-L V6, so yep - go with a true Noctigon then to get it well centered, like you said. Could really reflow the noctigon in there, specially if it's a snug nice fit, then screw the cover (not screw actually) if I want to, black it all out.
The one that Melted Down, I direct solder bonded a 20mm Noctigon XP board to the pill, and reflowed a 5700k HI at the same time. Surface tension keeps it lined up to the pill holes for the leads, but I still use the round tooth pics to keep it located. Same if I ever want to reflow another emitter? I’ll do the same to the other (Cometa ) one if it gives me any trouble!! But so far the Kapton Tap is holding the emitter board in place, and I had it apart a couple times so far?? :innocent:
I've often screwed down MCPCB's in zoomies, like this ZeusRay:
or this UF-T20:
Normally I don't care much about artifacts - they really aren't typically very bright anyways, but if you are fussy bout the beam, then blacking out the top surface area helps.
Tom while your in there, check for the High spot on the pill…. Ha! Theres my Cometa driver pocket and driver Measurements /dimensions!!
Thanks for the feed back guys i tried to fix the temp problems but i couldn’t lol clicked her so many times! I added a video with beam shots!
