My COMETA is a POS - does not connect with tailcap spring - burned my finger [Hobby Ending - Enough is Enough]
Jeansy made a breakdown/fix video if you’re having difficulty.
Thanks for the feedback. Looks like I’m going to have to go down the replace or refund route sadly. Unless the 2 fundamental safety flaws of the Cometa will be fixed in an updated version, I’ll probably be the latter option. :frowning:
(BTW Banggood did kindly send me an insulating disk in request, but that is now irrelevant.)
What was the third again?
[quote=stephenk]
I’m confused here. As I look at my light, and that cover thing in my hand, it looks like when I screw it down that the solder points will miss landing on the top portion of that covering ring, but would instead be in that deeper middle area. Is that where they should be, so as not to cause any issues?
thank you.
patrick
Patrick, don’t trust it never to cause any issues.
You might shake it, or drop it.
“Do you feel lucky?” isn’t the right question to ask for li-ion cells.
Put some tape or other insulator under the black thing so the solder blobs on the end of the black and red wires can’t contact the black parabolic screwin thing, even if the board with the LED floats up out of place. The LED board is not held down by anything except pressure from the black thing as it screws down, and the black anodizing can scrape off.
And add a homemade insulator around the battery spring contact on the other side of the pill too.
And check the tightness of the retaining ring that holds the driver in place.
And look through the retaining ring and see if the driver looks centered, not off to one side.
Wear safety glasses. Work outdoors… Don’t inhale if it smokes. Your luck may vary.
No advice here is a promise that you will be safe from anything.
Be wary of grues.
Yeah I tried screwing it off and It wouldn’t budge, looking at it one side was flush the other side had a small gap. So I thought maybe it doesn’t screw in and it’s just wedged.
Once you all confirmed it was in deed threaded, I put a shop towel on it and used channel locks to get it off. No clue how they got it so damn tight.
It was rubbing on both solder blobs, I think it only wore trough the anno on the negative tho.
Good , ya’ got it off. :slight_smile:
Insulate them both, do not trust the “anno” to do it… :wink:
thank you for your comments. I have a couple of questions:
In this picture, is the outer brass colored ring with the 2 holes in it, is that the retaining ring that holds the driver in place? I guess it isn’t cu I can’t see thru it as u asked me to do. How do you see the driver?
arrrggggg!
The outer brass ring is the head of the pill - a big heavy chunk of brass. Use needlenose in those 2 holes, and you can unscrew the pill, CCW. When the pill is removed, it's easy to get to the driver on the underside of the removed pill.
Two different ways, right?
— if you use a wide-button cell, a short from spring to pill across the button, curable with a homemade gasket
— mismatch between width of hole and width of driver, so driver can slip sideways under the retaining ring, and if it happens to slip toward the positive wire connection, a short there, curable — how?
I’ve been looking for a little half-millimeter or thinner insulator I could drop in around the edge of the driver to keep it centered. Meanwhile I’ve been lucky …
All the furthest most outside SMD's on the driver are batt- ends anyway, like the 7135, C1 cap and bleeder resistor for example. I looked it over carefully and find it hard to understand how a ground out could occur, maybe though. But they clearly did some sloppy design/measurements work there, leaving all that wiggle room.
It's so depressing seeing slop work where it's done better in <$10 budget lights.
On other lights I’ve had driver retaining rings that had an inverted-L cross section — so the threaded part was somewhat thinner and a wider part overlapped the ground ring of the driver.
Got those on the Convoy lights and I think I also bought some from somewhere, maybe FT.
(I was able to notch the wide part of those to avoid pressing on Qlite chips, without filing into the threaded part.
Hhere’s a picture of that in the MtnE thread:
The retaining ring in my Cometa is equally thick all the way through, so it doesn’t have overlap and the thin threaded bit fitting down around the outside of the driver board at all, just presses on top of it.
Maybe replacing the retaining ring would keep the driver centered.
I notice the driver has the rough fiberglass (?) teeth on both sides where it was broken off from the rest of the board and not filed down. Maybe they were counting on those for centering, but they’re not long or even enough to do that.
Hello, I was really excited about this light… But now I am concerned…
Im wondering if when I get the package… should I refuse it so that the mail man sends it back to the sender so that I can get my Money back?
I really want a powerful thrower that can zoom out to flood aswell… :confused:
I wouldnt do that if I were you. That might work ordering something from the US, but coming from china, you’re likely to end up with neither your light or your money back.
Another approach worth a few minutes’ time: write a review of the light at the page.
Anyone who’s bought one can write a review.
Look for mine.
I got a quick email reply after I submitted the review:
I answered that I’d taken care of mine with the high-temperature 3M insulating sheets, gave a pointer to this thread, and said I wanted to see the warning posted in the reviews for anyone who hasn’t bought the light, and hoped to see a version 2 with the problems fixed.
It’s not a demand for attention, it’s telling them they need to post the warning and take care of others before they buy this.
I will be interested to see if my review shows up. They do post critical reviews, I’ve written others in the past that did appear.
This may be a possible solution…
This example is a mod in progress for adapt the BLF A6 driver to D80. Next step is solder the wire to the driver (two or three solder blobs), for keep all in its site.
Robert B… That’s what I was thinking…
1.Would it be worth shipping back? how much would it be to do so?
2.And what would be a better option of zooming 26650 led light?
Here’s a quick safety fix for the battery spring at the head of the light.
This should only be used TEMPORARILY without further modifications.
I offer it because many may be too impatient to cut an insulating washer before first firing up the light.
There is a white foam gasket inside a Windex glass cleaner sprayer which might be used as an approximate reference for making a gasket.
It would actually work if it fit tighter but as is it will fall out during a battery swap (too much risk with that).
Needle nose pliers in those holes and twist loosen, the entire brass pill including the white led mcpcb, brass pill and driver on the other side will come out. The actual retainer for the driver is on the other side so look there to see if it’s centered. If not, remove the retainer and add either a thin wire hoop shim around the driver, ~2’ of insulation stripped from thin guage wire, or few tiny dabs of Fujik or AA before replacing the ring to keep things in place.
A few inches from one of the wires in a phone cord would probably do the trick too.
What’s the verdict on this light on the Italian light forums? Are they getting crappy quality as well?
