First new 2Xs now arriving in NZ - interesting comments from buyers:
“Been using a led lenser m14 for last few years. The maxtoch just leaves it for dead!! Honestly Im just stunned as to how bright it is….Hoping to get out shortly and take this ”electric dog” for a big walk.”
Are those 365k tested allready? BLF m24 claimed to be 250k yet it was arround 200k…wonder what an old s4 will give in that reflector, i am quite impatient to try it out
Yes we’ve tested 2-3 at just under 360k at 6m, so 365k at 10 meters is realistic.
Maxtoch’s output claims are usually right on the money. The BLF light I got tested at about 248k from memory, so it would be very surprising to get just 200k from one of those.
Keep an eye on your meter - I’ve had to throw out two lux meters which began to read low over the years - no idea why.
Well i could be wrong about BFL M24 if i ordered just one, but i odered 4 from the original GB and 3 afterthat.
Latest samples were arround 205-210k but the first ones barely touched 200k, there was one at 185k
The price/usefulness ratio was awesom though
I will appreciate any info about the hotspot at 300 meters, and especialy its hotspot effective cover area agains M3X at 300 - 400m…i use M3X since i presume its well knows and owned in NZ
Is this confirmed for the final product? Is the driver/output regulated and the lumens output is constantly maintained and the light will go out suddenly or is there a constant decline of output over time like other unregulated lights?
A name is a name, where does anyone get the name they use? Easier to not question it and just accept it’s what they chose to call themselves. “SURE FIRE” sounds like something is guaranteed to catch on fire! But it’s popular enough with certain groups…
Really interesting to see this thread. 360kcd with XM-L2 U4 1A, with 70 minutes of run-time on high?(parallel connection?) Seems very optimistic.
I have 68mm od reflector thrower flashlight with 64mm reflector inside that does 340 kcd with fet driver, old xp-g2 s4 2b, 4.4a current draw.
I have witnessed to many pumped up numbers in flashlights. Hope this will not be the case… If everything will be like claimed expect at least 20 flashlights from me.
While I don’t have any of the Maxtoch lights, I would just like to point out the batteries are in a serious arraignment. I know it was corrected earlier but people still seem to be misunderstanding.
From everything I saw on the M24 , other than what Mitko is claiming , the test showed the M24 at or around the claimed 250K lux. mudgripz and gadgetman tested those lights around that number as well as did Maxtoch.
I have never known Maxtoch to have inflated numbers on the output either as mudgripz also stated in an earlier post.
I can tell you also from the testing of this prototype and the factory model I have now , with what should be the final specs , or pretty darn close, it is absolutely the longest throwing light I have seen to date (out of the box and that I have used) with good useable spill right out of the box and NO mods or tweaks needed.
The 2X Hunter has 2 Series 18650’s and a regulated Buck circuitry. This is what allows the 4.5A current with lower draw from the 8.4V supply. And this is also responsible for the apparent long run times, high capacity cells can be used and high discharge cells won’t have any advantage.
So 3400mAh cells with about a 2.5A draw on em would indeed give over an hour of run time. It’s all in the math. lol
Mine should be here today or tomorrow, it left Chicago last week but tracking is not being precise through the USPS. I’ll get lumens output, tail cap current, and actual emitter current and forward voltage numbers, as well as some pics, weather allowing.
You probably know that Cree changed production process(“upgrade” which brings lowers lux performance) for XP-G2 emitters? But new production process could also affect even XM-L2 emitters:
