Its sad that they would execute such an attempt and then fall short, just to save a few pennies. Id advise people to avoid this charger unless Enova resolved the problem. I wonder if the supplied PSU is also contributing to the problem?
Im sorry but this is unacceptable. Why would I want to live with such a voltage imbalanced in my cells and pay more for your charger? Especially when there are several inexpensive chargers that terminate with far higher precision. For instance, a typical scenario is that I can charge 50 x 18650’s while using xtar or soshine brand chargers. After resting, 47 cells will show 4.18V, 2 will show 4.17V, 1 will show 4.19. This has been a typical scenario for many years and does not deviate unless I am testing old used cells.
It sounds like your charger isnt performing as you had intended. Please take a look at HKJ’s graphs entitled “Charging 4.20V LiIon cells” and take note of the termination voltage imbalances between charging stations. Good luck, and I hope you can resolve this issue before this charger comes to market.
Yes, I am serious. I sell DOZENS of chargers and test each and every one before they go out the door. Do yourself a favor and read my post again, then you can learn from my experience, not your false conjecture.
I rated the charger based on my opinion and experience, other people may have other requirements and give it a different rating. One reason I publish my raw tests is because it allows (Technical) people to do their own evaluation.
If FlashPilot want chargers with better matching charge voltage, he is welcome to that. In a few cases it might be a good idea, but mostly it is not required.
Sounds like a very flexible charger, one that could meet the ordinary needs of most users with a few (minor) issues.
And I’d feel a lot more comfortable with the results from a random pick of the regular production. I guess I just don’t trust manufacturers to “not fiddle around with” their production models. But I guess that it is a good thing … to be given the opportunity to review a product in advance, isn’t it?
P.S. I also appreciate the participation in this discussion by the manufacturer’s representative (enova18650.com).
Thanks FlashPilot for your criticism; Thanks gauss163 and HKJ for your professional opinion; And thanks 1dash1 for your sincere comments. Because the user’s comments are very important for us,It can help us to develop products more effectively. So I have great respect for your opinions,suggestions and criticisms.
Hello BLF members,
Does anybody could help us to make some smaller language reviews?
Such as French, German, Korean, Japanese, Arabic, Portuguese, Italian and so on.
Either you can make a video or write a soft-text.
And then sent them on better-known websites or forums that is related to the flashlights or electronic cigarettes.
If someone will help us, please send me a private letter.
My email address is info@igyrfalcon.com
Thanks.
I’ve distributed around 600 of the cheap DX 2 station chargers and recently swapped to the 2 station Meritline chargers for their superior build quality and slightly higher termination voltage (4.24V) for 4.30V cells. Ive also sold literally hundreds of xstar chargers (all non USB) with external PSU, as well as dozens of the large 4 station 4 amp soshine brand with eternal PSU. Except for the odd ball (perhaps 1 in 20), they all terminate at the same voltage (+/- .005V). The DMM reads the same down to x.xx VDC across charging stations of the same charger. You can rummage HKJ’s excellent extensive charger review database and find many that accomplish this level of consistency and accuracy.
Others rely on my lights in mission critical/dangerous environments, so I thoroughly test each cell, charger and light before sending them on… usually 2 or 3 complete charge/discharge cycles.
Features
• Optional charging voltage (1.5V Ni-Mh, 3.6V LiFePO4, 4.2V Li-ion, 4.3V Li-ion, 4.35V Li-ion)
• Optional charging current (0.1A - 0.25A - 0.5A - 1A )
• Capable of charging different chemistries at different currents at the same time
• General mode (automatic mode) only for 1.5V Ni-Mh and 4.2V Li-ion batteries, it can automatic start charging and termination.
• Professional mode (manual mode) for 1.5V Ni-Mh, 3.6V LiFePO4, 4.2V/4.3V/4.35V Li-ion batteries, Have 3 kinds short-cut operations.
• 4x bays wide enough to fit 4x 26650s at the same time
• Longer bay slots to handle 18mm - 72mm lengths
