Are those 365k tested allready? BLF m24 claimed to be 250k yet it was arround 200k…wonder what an old s4 will give in that reflector, i am quite impatient to try it out
Yes we’ve tested 2-3 at just under 360k at 6m, so 365k at 10 meters is realistic.
Maxtoch’s output claims are usually right on the money. The BLF light I got tested at about 248k from memory, so it would be very surprising to get just 200k from one of those.
Keep an eye on your meter - I’ve had to throw out two lux meters which began to read low over the years - no idea why.
Well i could be wrong about BFL M24 if i ordered just one, but i odered 4 from the original GB and 3 afterthat.
Latest samples were arround 205-210k but the first ones barely touched 200k, there was one at 185k
The price/usefulness ratio was awesom though
I will appreciate any info about the hotspot at 300 meters, and especialy its hotspot effective cover area agains M3X at 300 - 400m…i use M3X since i presume its well knows and owned in NZ
P.S
You have a great deer hunt in there
That’s odd - have tested maybe 30 in total over the years and they have always been pretty much bang on manufacturer specs for output.
I like Maxtoch head + Convoy tube crossbreed
P.S. Why is their name Max toch ? did they forget “r” (Maxto r ch) somewhere? It looks kinda stupid, everyone will think its a typo!
I think the Maxtorch name was taken at the time and they dropped the “R” when they started.
It is a lot better than the Uranusfire name though don’t ya think?
Is this confirmed for the final product? Is the driver/output regulated and the lumens output is constantly maintained and the light will go out suddenly or is there a constant decline of output over time like other unregulated lights?
Looks very interesting.
Thanks,
K.
Kusie,
Yes it will maintain full brightness until it goes off when left in high mode when the LVP kicks in around 2.9 volts.
It should be the same in any mode however , just with longer runtimes in Medium and low.
Cool thanks. I think I’ll bite
K.
A name is a name, where does anyone get the name they use? Easier to not question it and just accept it’s what they chose to call themselves. “SURE FIRE” sounds like something is guaranteed to catch on fire! But it’s popular enough with certain groups…
Robo is right, better Maxtoch than UranusFire
Really interesting to see this thread. 360kcd with XM-L2 U4 1A, with 70 minutes of run-time on high?(parallel connection?) Seems very optimistic.
I have 68mm od reflector thrower flashlight with 64mm reflector inside that does 340 kcd with fet driver, old xp-g2 s4 2b, 4.4a current draw.
I have witnessed to many pumped up numbers in flashlights. Hope this will not be the case… If everything will be like claimed expect at least 20 flashlights from me.
While I don’t have any of the Maxtoch lights, I would just like to point out the batteries are in a serious arraignment. I know it was corrected earlier but people still seem to be misunderstanding.
Yes, I corrected myself in an earlier post also.
The light is in fact wired in series.
From everything I saw on the M24 , other than what Mitko is claiming , the test showed the M24 at or around the claimed 250K lux. mudgripz and gadgetman tested those lights around that number as well as did Maxtoch.
I have never known Maxtoch to have inflated numbers on the output either as mudgripz also stated in an earlier post.
I can tell you also from the testing of this prototype and the factory model I have now , with what should be the final specs , or pretty darn close, it is absolutely the longest throwing light I have seen to date (out of the box and that I have used) with good useable spill right out of the box and NO mods or tweaks needed.
The 2X Hunter has 2 Series 18650’s and a regulated Buck circuitry. This is what allows the 4.5A current with lower draw from the 8.4V supply. And this is also responsible for the apparent long run times, high capacity cells can be used and high discharge cells won’t have any advantage.
So 3400mAh cells with about a 2.5A draw on em would indeed give over an hour of run time. It’s all in the math. lol
Mine should be here today or tomorrow, it left Chicago last week but tracking is not being precise through the USPS. I’ll get lumens output, tail cap current, and actual emitter current and forward voltage numbers, as well as some pics, weather allowing.
You probably know that Cree changed production process(“upgrade” which brings lowers lux performance) for XP-G2 emitters? But new production process could also affect even XM-L2 emitters:
This “upgrade” was not only done to XPG2s, but also to XML2s. Or at least “a” change was made. I never had any trouble with a change in tint, however the output from a single XML2 U4 bin dropped VERY significantly about 3 months ago due to a spike in the needed VF. I tested piles of LEDs from multiple sources to try and regain some ampers, but no luck.
Serious problem with XML2 current. Is this happening to you???I probly would not have even noticed accept I test custom builds like my shorty Maglites before they go out on a regular basis. Out of all the XML2s I have used since then I have found only one that tested out the way nearly all of the ones I got off RMMs first reel last year did.
I just hope when XML3 lands we recover some of that nice low VF as most of my builds use a mosfet driver.
Hope you will also test lux intensity Thanks for that.
Yea of course if you use two 3400mah 18650 that equals 6800ma running at 4.5amps so 4500mah would yield about 80mins run time.
Not exactly, since series doubles current not capacity. The driver is bucking down the 8.4V to the forward voltage required, so it pretty much comes out as a wash in that regard, less driver inefficiency.
2 3400mAh in parallel are 6800mAh and 4.2V
2 3400mAh in series are still 3400mAh but give 8.4V
The long tube of this light carries 2 18650’s in line, or in series.
