Well, I do, low mode here is quite useful and I don't need to switch to other flashlight. Besides - forward clicky+mode is useless because you can't really use it because of unintended mode changing.
Tested it against UF-980L and I got to say, it had tough company to start with...
On a shorter distance, say 100 meters, it is easy to notice that STL-V2 has tighter spot and more lux.
Then if you compare an absolute throw in meters, there´s really not THAT astonishingly big difference.
STL-V2 throws further but after 980L it does not make my jaw drop that much. Could the difference be something like 50-60 meters? Hard to say, I don´t have a lux meter to leave up there to test.
It is now 0°C and RH is at 93%, I felt like the beam itself in the air was blinding me.
At this kind if weather, I would say I saw it doing maybe 200m+, can´t say very accurately. Measured only by cars speedometer.
Well I have a Olight M3X which this light here is pretty much a clone of. I have a Crelant 7G5 coming. I'll let you know who the winner is? I say it is going to be close.
No, it won't be brighter, coz it is fully regulated. BTW, can it take such a high voltage? Had the impression that it can only take 2 cells. 1 cell also won't work.
Any real world experience of running STL-V2 on 3x16340/18340 vs. 2x18650? How's the heat generated or runtime - and what about the reliability? What brand/type of cells have you been using?
tried 3x16340s but never looked at runtime. also had 2 18500s without the extender. 2x18650s will give the most runtime due to capacity as it is in series at either 2 or 3 cells.
I've got a STL-V2 ordered from DD in November. Just wondering whether somebody is able to confirm the existence of Low Voltage protection?
I'm asking this because I was running it on unprotected batteries (Trustfire Flames 2400 also from DD) for a while and after checking the remaining voltage of the batteries I had to carry the other one out-of-doors in a hurry because the battery was hot and the voltage was just above 2V. The voltage of the other one was 3,5V at that time. On the other hand I also wonder whether this difference in voltages makes any sense because the batteries are in a series. Could there be e.g. such a huge difference in the internal resistance...
^ OK, thanks. So it seems that if the other cell is not good the LV protection did not kick in even the total voltage was less than 2x2,99V at least in this case.
I was actually running STL-V2 for a total of 120 minutes on high (12x10min, 5min break in between) and it was still going quite strong:
BTW. What budget (un?)protected 18650 cells would you recommend when taking into account the STL-V2 stock driver i.e. quite low current and the existing low voltage cut-off feature?
