Made some progress over the weekend on implementing/adding a ramping mode to Narsil. Testing it in a SupFire M6. The ramping is pretty much fully implemented, but it breaks all the other UI stuff for now, til I work it all out, like the lock-out, entering configuration modes, displaying battery voltage, toggling the locator LED, etc.
I used posts on BLF by ToyKeeper and blueb8llz as a guide for implementing how it works. I'll be providing more details.
One note is I'm currently using 64 levels spread over 3 seconds to fully ramp the range. I tried 2 seconds at first, but could not stop at moon mode. With 3 secs, it's fairly easy now, but just not sure if 3 secs is too slow. Maybe 2.5 or so is bout ideal -- not sure. Certainly it's all touchy/feely issues, probably a lot of personal preferences thrown in.
More progress this eve on ramping support in Narsil:
got lock-out working with same sequence as in non-ramping mode: 2 quick clicks followed by hold
got battery voltage check working same way also: 1 quick click followed by hold
got both modes of configuration UI working, again same or similar way as non-ramping, but for the main configuration setting, simply hold the button for 5.5 seconds, which is a full 3.5 seconds longer than a ramping sequence
changed ramp down - it stops now on moon mode instead of stopping by turning the light OFF
Still to do:
would like to get the locator LED toggling ON/OFF supported in ramping. Right now I lost that capability
need to add selection of ramping vs. mode sets to the configuration UI settings
might be on small bug to fix: after exiting lock-out, looks like 1st click is ignored, then all works fine
might see if I can clean up the LED output when in these special sequences (lock-out, batt voltage, config UI, etc.)
would like to get the ramping a little smoother look'n - right now a flicker is noticeable because it's changing PWM levels at 20 times/sec, whcih is somewhat noticeable. Would be better to adjust it closer to 100 times/sec which is possible.
might want to add in ramping a direct method to Hi/Turbo - possibly a dbl-click or triple-click
Overall liking the smooth ramping. Operation:
From OFF:
click to last level it was on
hold ramps up from moon to hi/turbo in 3 seconds, smoothly (currently 64 levels)
From ON:
click turns it OFF (this level is restored on the click from OFF)
hold ramps up, accept if it is on hi. If on hi, hold ramps down all the way to moon in 3 seconds, and stops there
It's simple and predictable, least that's my think'n... All the other special stuff is accessible by special sequences.
Thanks to blueb8llz and ToyKeeper for guidance, inspiration and support:
It would need to be single click to turn the light on and off. Hold switch while light is on, and ramps levels. Hold switch while light is off, turns on moonlight mode. Single click turns on light in last used mode including turbo.
Give me this ui, I promise to purchase at least two more units.
I’d really like to test your firmware with my current XHP50 SRK (I blew the driver past weekend so I’ll rebuild it with an attiny25)
I have an indicator LED around the switch so I can test this too.
Is it available for download somewhere?
Very nice Tom E!
I might want to go with the “old” Narsil for my DQG due to the thermal issues. Maybe a cut down High would be better for my u.i., but this is definately nice for lights with normal cooling abilities.
I’ve ran into a problem flashing the X6 driver:
“C:\AVRusb>avrdude -p t25 -c usbasp -n
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1effff
avrdude: Expected signature for ATtiny25 is 1E 91 08
Double check chip, or use -F to override this check.
avrdude done. Thank you.”
Also with the -F function it doesn’t write firmware properly. I get the same signature error.
I don’t know how to use a .bat file yet, but I guess if a direct command doesn’t work, that won’t work either.
Am I missing something or could it be a faulty Attiny25? I’ve got another driver lying aroud, but before I brick both, I thought lets ask the BLF oracle in advance
Narsil requires an 85 - won't run on a 25 because of program space requirements.
Yes, but not with the ramping features - still under development/test. Latest version posted is dated 2016-04-07, accessible here for the source code, AVRDude BAT files and manual:
Dutcheee - Are you sure you have a properly wired USB dongle? I've posted this several times - there's bad info floating around on the dongle wiring, and it didn't really effect me til I started programming 25's, 45's, and 85's.
That messaging you are getting is probably related to a bad connection of the clip/dongle - I've gotten the same message many times. Sometime the clip position is off or the pins just aren't making good contact, but if you have the GND pin wired incorrectly, you can get similar inconsistent error messages.
I'm always keeping a spare USB AVR complete w/cable and clip around now. The clips specially can start having problems with use. The first black cheaper one I used had pin problems - pins just loosened up and would back out on attempting to clip to the MCU. Became a real PIA fiddling with them all the time. Then a blue Pomona failed on me - one of the pins sprung out of the plastic tabs holding it in, and just couldn't get it to stay. This problem was probably my own fault though, abusing it to fit on MCU's in tight spaces.
I basically got the ramping mode operational in Narsil, accept for the To Do list below. There were a lot of little bugs along the way, but looks like it's operating pretty clean now, so far that is... Ramping can be chosen via the configuration settings, so you can still choose one of 12 mode sets, or ramping.
Code size is now 5496 bytes, 67.1% filled, so still lots of free space.
So the basic ops is fairly simple:
From OFF:
hold ramps up from moon to max level in 3 seconds, smoothly (currently 64 levels)
double-click to max level
From ON:
hold ramps up, accept if it is on the max level. If on max, hold ramps down all the way to moon in 3 seconds, and stops there
All the Narsil special/advanced features are now working in ramping mode:
lock-out works: From OFF, 2 quick clicks followed by hold (same as non-ramping)
battery voltage check: From OFF, 1 quick click followed by hold (same as non-ramping)
both modes of the configuration UI working - to access the main configuration setting, hold the button for 5.5 seconds, 2.5 secs longer than a ramping sequence
in ramping, locator LED is toggled by a triple click from OFF
Couple things still To Do:
turbo timeout (currently only works in normal mode sets, not ramping)
Low Voltage Protection - needs to be modified to lower levels (currently only steps down modes in a mode set)
This looks sweet Tom!
I have ordered the hardware to flash the AT85
And I already know which srk will be using the prototype Q8 driver
NICE!!!
So intuitive!
Sorry, I can't answer that in any certainty, but total guess is yes, because I don't think anything in the MCU is boosting or regulating voltage, but really dunno. Do you think it makes a difference to the FET or 7135's, because it just acts as a ON/OFF switch, not used directly as power out of the FET or 7135's?
I’m considering the limitation of the PWM signal being strong enough only to control ~32 7135 chips. I am thinking that if the PWM signal went to a fet whos output was connected to the PWM pins of the 7135’s, an unlimited number might be able to be switched.
Hhmm, don't think the waveform of the signals are the same - the gate input, and the FET output, but I could be wrong. I have a modded MtnE 7135 SRK driver with the full up 32 7135's, and 18 more piggybacked, total of 50. I got it in a Fing 5X, getting like 18A out of it, which is close or at the max. It works great, up to 8 PWM modes using PHASE PWM (I don't use FAST mode anymore), running on a 85. Not sure, but might not have tested it for LVP operation...
Nice. Yea, I was thinking a FET might be fast enough not to mess with the waveform too much but idk. Another option might be to use two MCU pins PWM’ing in parallel to a bank of 7135’s.
Got the final open issues for ramping done and pretty much tested now. I have the new Narsil installed in 3 lights:
Supfire M6 (Indicator LED, FET+1, 3 U3's, does about 5,000 lumens)
SupFire M2-Z (FET+1, C8 size side switch, modded with an XPL)
ZY-T11 clone (indicator LED, FET+1, XM-L2 T6 4C)
The timing for one full ramp was taking about 3.6 secs, so I reduced it now to ~2.8-3.0 secs, and looks much smoother now with no noticeable flicker. I increased the # of steps to 142 (was 64 steps).
