Hey,folks in BLF. Long time no see, would you guys miss me or our lights?LOL.
As you know, our newest canister dive light DIV20 only has focus head now. Because DIV20βs heads are detachable, so many divers asked for using focus and video head at the same time. Now our engineers have designed three plans, and hope to get your suggestions.
Which plan is your favorite? Do your have some ideas for the dive video head?
Plan A.
Use 3*CREE XM-L2(U4) LED, only white beam, about 3000 lumens.
Plan B.
Use 6* CREE XM-L2(U4) LED & 4*CREE XP-E2 R5 red LED, the white beam will be about 4500 lumens.
Plan C.
Use one CREE XHP-70 LED, it will be about 2000 lumens.
All Brinyte members and our company sincerely thank for your suggestions. γΎ(oβββ)οΎγΎ
Now our DIV20 focus dive light use 8*18650(3400mAh) Panasonic batteries. And you can open the battery canister just turn of the four screws, but should be careful not to make the wire inside broken.
In theory, max runtime will about 5 hours on white beam and 7 hours on red beam.But we are thinking to use 3000mAh batteries instead. You know, 3400mAh battery is so expensive that the selling price is a little high.
Make the cable removable at both ends (like it already is at the battery) also make it removable at the light head end so when it breaks we can just order a new cable instead of having to send the light back to China to be fixed!
Than we can swap different cable lengths onto different heads, depending where it is mounted or what we are using it for.
I'm sorry I misunderstood your previous meaning, cyber. Your advice βMake it detachable at the light head endβ, I will tell our engineers. Thank you.
