Astrolux S41 - presale ended
Some Pics of my unit:
(BBQ ummmmmm! :laughing: )
Where did you get those Tensai batteries?
Hey guys - I´m back from the cave playing with the Astrolux S41
( its 1:40 am - video and pix follow tomorrow)
some thoughts about my sample (nichia LED)
  • WOW - nice and small
  • good build quality, no dings and scratches
  • smaller than short BLF A6
  • head diameter is 22 mm
  • build order: bezel - Oring - AR coated thin Lens - quad optic - Oring on the head - massive copper head
  • no extra isolation disc between screws (a bit too big imho) and the copper MCPCB
  • LED wires are 22AWG
  • MCPCB has a direct thermal path
  • driver retaining ring was a bit loose and unscrewed with the tube (that was tight)
  • driver IS the BLF A6 (with 4/7 modes + discos)
  • nice tint
  • better beam than my triple A6 (XP-L HI)
  • much lower low than my triple A6
  • switch PCB is the illuminated design, but not populated
  • double springs in tailcap to reduce resistance
some quick&dirty numb3rs (as shown on the luxmeter, usually 10-15% high)
S41 2450 Lm 12 A PS 4,1 V
1520 Lm 5,6 A IMR18350
2100 Lm 9,2 A 30Q
BLF A6 3D bridged 1700 Lm 5,6 A PS 4,1 V
A6 (3x XP-L HI) bridged 3250 Lm 10,1A PS 4,1 V
Astrolux SS stock 1450 Lm 4,4 A PS 4,1 V
EC11 940 Lm 2,8 A IMR18350
Powersupply was set to 4,1V (its a 30V/20A PS)
other lights to compare (my lightbox is not good)
more asap
good night my friends! ;)
Tensai/Enercig 18350
http://eu.nkon.nl/rechargeable/l/enerpower-18350-imr-limn-700mah-flat-top-battery.html
Hi
Can u give me your order number?
it won’t cause short out.
These two screws are isolated from circuit wire which also called MCPCB board so that should not cause a shot circuit even when the screws got contact with the body.
My order shipped!
(but I didn't get an email.)
Is that as safe as what you both (Banggood & Manker) delivered to us with the UNSAFE Cometa lights?
Specifically your pill design & implementation?
I’m not much of a solderer, but can someone comment on those + and - solder joints. On a scale from 1-10?
I received an S41 Nichia today. Ordered shortly after the pre sale started with expedited shipping.
Man, this is one sweet bright little, and I mean little, light!
The optics are quite a bit tighter than a Carclo narrow quad with 219C.
Currently running it with an AW 800 mah 12A IMR 18350. I’ll try and get a tail clamp meter reading in the morning. Not as bright, of course, as my DBCustom modded Cu X5 with the quad 219C, with narrow Carclo, but that is max modded. This is stock! And, it is holding its own!
I just got a few of Richards newest FET + 1, Bistro drivers and the new quads with XP-G3’s, and both flavors of 219C’s, now how long until I have to try putting one of those in?
I’m curious if I will be able to use the stock optic with one of those MCPCB’s…
I think most people will be stoked to get these! I have an XP-G2 model coming as well. Had to try them both… :smiley:
Thank you for the info !
Are those numbers for the nichia of the cree version ? ( sorry if i didn’t follow ! )
i got the nichias
Even when? Where are they screwed in?
That’s reassuring.
Could you also, please, let us know what the difference(-s) between S41 and E14 is/are?
??? :frowning:
My shipping notice for the Astrolux S41 Nichia version came yesterday. I’ll post my report upon receipt. I am hopeful.
Hi,
what should i say? I can locate the short on the edge of the MCPCB where the screw sits with a DMM. It is not the body and the screw causing the short. The screw touches the positive trace of the MCPCB. It is not a big deal for me personally, because i often modify lights. I placed a piece of an insulator over the edge, that worked for me. A disc only didn´t.
And please remember, the light worked without shorting when i got it. But i think this could be improved in future designs for safety purposes.
+2
Today with our neighbors with watching the DFB Cup final (Bavaria Munich:Dortmund) afterwards and tomorrow with some friends again. Yummy :partying_face:
Regards
Kenjii
Sharpie, you’ve said the same thing about a million times already.
Looking forward to getting mine this monday.
