Superb fit and finish. Tough as nail as well - check out the torture test: Tool AAA Torture Test
The guy dropped it, put it in boiling water, and even set it on fire. When it stopped working, it’s only because the battery inside broke, not the light!
Hugsby is great for only four or five bucks, lots of light and a clicky switch. Lumintop Tool but fifty bucks for a AAA, crazy. Have a lot of twisties but have vowed to never buy another, get a clicky switch.
Hugsby X1? Could have been, if it weren’t for those @!%&* shoddy O-rings. They break the first time you swap batteries.
Surprise of the month? The Ultrafire AAA micro-version of the C8. It is like that girl from your high-school days: would never win any points in any competition (like playing the violin or cooking ), but was nice to be and have around.
from left to right: Olight S1 raw copper AIRAYLAND AAA brass:
pro> rear clicky switch, compatible 10440(250+ ㏐), tailstand
con> no clip, CW only AIRAYLAND AAA Phosphor bronze:
con> no clip, CW only , pricy Ultratac K18 brass:
pro>side Electronic switch, compatible 10440(250+ ㏐)
con>can’t tailstand, CW only Olight i3s-cu raw brass:
pro> tailstand, Cree XP-L 180 lm
con>twisty, Lumintop Tool Ti:
pro> rear Electronic switch, tailstand, available both Cree & Nichia LCD
con> pricy, low output 80~110 lM Blf-348 SS:
pro> rear clicky switch, cheap, nice tint, compatible 10440
con> only so so F&F no compare to all lights above, one mode only(hi) the light heat up very fast if you use 10440 cell Zebralight Sc63w
