I dig this project. Here are a few thoughts as I think of what I want in a lantern.
1) Durability/Reliability. I want to be able to hang a lantern somewhere if necessary and not worry about it breaking if it drops. I realize this may add a tiny bit of weight but really, if designed properly I think a sturdy lantern is completely within reach. I would also add being somewhat waterproof since I can see someone forgetting to put it away and it raining heavily overnight or at a water crossing or boating getting the lantern briefly submerged. I hope to see the final product made by a quality manufacturer with a proven track record.
2) Lack of glare. That’s probably my biggest complain about how most LED lanterns are designed. It seems like there is just a ton of light spilling directly out the sides and not much going down and below.
3) Run times are absolutely more important for me than extreme brightness. Obviously a good balance of both is the ideal.
4) Useful output modes with a moonlight mode.
5) Way down on the list would be the ability to charge via usb, specifically for use with small solar panels if possible. I know that some chargers won’t charge batteries unless a minimum amount of juice is being provided via the solar panel but that amount varies quite a bit depending upon the charger.
That’s about it, I really love what you’ve done so far and am looking forward to more updates!
This Prototype has all those you listed above, except the built in Charger port. Right now the prototype is very water resistant, (it can handle short submersions) its made of solid aluminum (as its SRK based) it has a great moonlight mode that would allow it to run continuously for months (with the Q-lite Rev. 105 Nanjq driver it has) output is very good with great run times, (700milliamps on high with four 18650 cells all in parallel keeps the XP-L in its most efficient output vs. Amp-draw range, and on medium mode will give you a couple weeks of run time using it 4 hours per night) and with the down-firing LED & reflector design it has the least glare out the side of all the other lanterns i have seen or tested.
A blue-print type drawing and specifications for this prototype will be posted soon, and discussed with Kronos so he can work his magic with manufacturers/brands to get this into a production model soon.
Great lamp! And now for the production model. But whatever screw-ups there will be in the chinese manufacturing process, it will still be miles better than any lantern for sale today.
for me as previously noted the number one issue is glare. i think this design has covered so many things i would never thought of.
but…
when i think of glare it is the direct line of sight. (we like car headlights becuase we sit in the shadow). imagine how fatiguing it would be to “see” the filliment (point source) of our headlights while driving.
if the design will not allow a larger brim (for lack of a better name) can an allowance be made for an aftermarket brim.
i want to be able to read by it and not have to “see” the actual point source of light. i hope my point both makes sense and gets traction.
again brilliant prototype but i dont see a brim to block the point source of light (for example when walking wih it or setting down on the picnic table).
thank you so much for taking this on.
and as far as mfg i dont think it matters as much as strict adherence to new product release processes. point being that we (the product managers) decide when the spec is frozen and production is started. as i see it ALL! the quality issues on any blf light could have been avoided if the mfg made exactly the light we approved. blf has to date caught every screwup the mfg made. as long as thoes are pre preproduction samples no blood no foul.
until they show they can produce with out screwups we need to be in control of the spec.
they will learn how to build it right the first time.
i would love to see simon and convoy be the mfg/distributor. but if we control when it is approved and when it is ok to produce then BG/manker will also do fine, provided they follow this sensable cavait.
Reducing glare was one of my goals on this. as its impossible to remove the glare completely, i did design it to reduce it quite substantially.
most all current factory lanterns have the LED facing up, or out the sides (where our eyes have it in plain view) i have placed the single LED facing down wards, inside a mildly frosted diffuser, with the LED out of eyes-view when on a table. Also have a close look at the close-up photo of the lantern in the OP, you can see roughly a 1/4 inch solid white “band” around the top of the shade, where that band blocks the point-of-view of the LED form reaching the eye even more when looking at the lantern form the side (as if its resting on a table at eye level.
while the glare is not completely eliminated, (which is impossible to do with any 360 degree area lantern or light, even with an incan bulb) it does have less glare than any of the other LED lanterns we had on the camp trip. When walking with it there was no glare as the LED is facing down. (unless you carried it upside down.
I would love to see Simon build this light under the Convoy brand name. All his products seem very solid and he seems to care about high quality craftsmanship.
