At 655 yards (600 meters roughly) here is an ATV , quad, 4 wheeler whatever you may call it , with a tan sheet thrown over it on a slightly misty night. In good clear conditions you get even better throw from the 2X.
The target is the light colored spot just to the right edge of the road at the far end of where beam is hitting , as it starts downhill just behind that.
5-25-16
I just got the OK to get the GB started. We will need 50 pieces to get the initial price of $88.50 and if we get to 80 pieces the price drops to $83.50. This includes FREE standard shipping , a nylon carry bag , extra switch , O-rings and rubber switch boot. Also if you wish to purchase a holster they will be marked down to $2.00 and the remote pressure switch marked down to $5.00 with the purchase of one of these lights (limit of 3 each of either for each light purchased) If the pressure switch is purchased you will need to be sure to get the one marked for the NEW 2X as they are marked accordingly on Aliexpress site. Maxtoch can also include 2 of the 3400 mAh cells (Panasonic protected button tops with Maxtoch wrapper) for $15.90 a pair if you need those but they must be shipped inside the light because of the new airfreight laws so a limit of 2 per light.
I have already asked about a free holster and lower price and probably anything else that could be included and what is listed is about as good as it gets for now. The cost of this light to produce is not quiet as cheap as Maxtoch would have hoped for I am sure, but even at the price we are getting I think it is still a bargain compared to anything even remotely close to it out there. Just getting U4 1A emitters over there took almost an act of foreign trades agreement and ended up costing much more than expected.
We will be able to purchase through Aliexpress site , or IF you will only use Paypal , we can go that route through Maxtoch directly, although I think the Aliexpress purchase will be easier in the end for everyone.
If you want in please let me know by posting in the thread and specify if you will use Paypal only or if you will use Aliexpress site.
If you have a Paypal credit card , it CAN be used through Aliexpress as any other credit card also.
EDIT: If you have never used Aliexpress I think there are enough people on the forum to verify that they are a reputable dealer/site to ease your mind. I have used them a number of times and never had a problem so far.
Tac Gunner, this is one of few lights out there that makes a column of light. I don’t see an apex like other lights, I don’t see the beam flare out after the crossover, like other lights. I see a tube of light, quite like a fat laser. It’s really amazing, as the Special Forces Army guys I showed it to recently saw, with much exclamation and awe stricken cursing.
I´m tempted, but how does this light compare to other throwers like the the Acebeam K70 or the Olight M3XS-UT, both range wise and beam wise? Did anybody have the chance to compare those? I don´t need neccessarily need a rifle mountable thower, but a “best bang for the buck” thrower
Thanks,
K.
The Maxtoch 2X is designed as a light weight, all-purpose beam, extreme thrower at 360-365k lux. The OLight M3XS-UT is also a lightweight but with alot less output at 250k, and has to step down to lower mode after few minutes - which Maxtoch does not. Acebeam K70 is more of a heavyweight - twice the price, twice the weight and twice the batteries of the maxtoch and about 420k. Best bang for the buck thrower is the maxtoch, but if you don’t mind a hefty bulk light you could try the Acebeam.
The GB list is at bottom of OP and if you want PS or holster it is noted beside your name , as well as preferred method of payment if you have stated that.
