I´m tempted, but how does this light compare to other throwers like the the Acebeam K70 or the Olight M3XS-UT, both range wise and beam wise? Did anybody have the chance to compare those? I don´t need neccessarily need a rifle mountable thower, but a “best bang for the buck” thrower
Thanks,
K.
The Maxtoch 2X is designed as a light weight, all-purpose beam, extreme thrower at 360-365k lux. The OLight M3XS-UT is also a lightweight but with alot less output at 250k, and has to step down to lower mode after few minutes - which Maxtoch does not. Acebeam K70 is more of a heavyweight - twice the price, twice the weight and twice the batteries of the maxtoch and about 420k. Best bang for the buck thrower is the maxtoch, but if you don’t mind a hefty bulk light you could try the Acebeam.
The GB list is at bottom of OP and if you want PS or holster it is noted beside your name , as well as preferred method of payment if you have stated that.
That would cinch on tight enough to hold that big FL? This rifle has a fair amount of recoil. You don’t think there would be a risk of damaging the scope?
I have not tried the 2X on a scope but i am pretty sure it will not cause any problems. I am sure mudgripz can give some feedback about it as that is all they do over there is hunt……lol
Ok, thanks. A guy I know has a deer management permit for a large farm. Feral hogs are doing some damage as well. I checked out a rail system for this Weatherby, but it’s $175 for the rail mount, not including new scope rings. Maybe it will be possible to mount two of those double rings for additional support.
