I should post about the XP-G3 emitter test first before posting about my slicing experiment, but this evening I had enough time to finish the throw test and way too little time for the emitter test write-up, so here you go:
The sliced led looks like below at 0.5mA, this looks similar to a sliced 3rd gen Oslon Square, or a Luxeon Q (and probably Cree XT-E looks like this too but I never had one of those). All these leds have a ‘poured over’ phosfor layer and do not throw very well. I sliced the silicon very close to the phosfor, in fact a few little flakes of phosfor were cut off with the last slice. The finish is not completely flat but I do not see how a perfectly flat shiny finish would improve throw immensely.
I made a direct drive pill for the Brinyte 158, I have another pill for it with a XP-G2 S4 2B that did 322 kcd. In the picture is on top the XP-G3 S5 3* pill, in the middle a XP-L Hi for comparison, bottom is the XP-G2 S4 2B pill. The XP-G3 die is slightly larger than the XP-G2 die, by (rough measurement) 13%
In this light the XP-G3 S5 3* draws 7.3A from a fresh 30Q battery, which is very close to its maximum output (99.2%)
The throw I get in the Brinyte with a Samsung 30Q cell, measured at 7 meter, 30 seconds after switch-on is 206 kcd, so way short of the XP-G2 S4 2B. I re-measured the throw of the old G2 S4 2B pill and it still throws well over 300 kcd with the partly drained 30Q from the first test.
I know that BLF member MEM claims some dedome magic, I hope his dedomed leds perform better than this one.
Except, that photo is not dedomed. That’s sliced, like a HI version. I completely dedomed the XP-G3—bare. The S5 3A dedomed looks just like a dedomed Nichia 219C in tint, also. Probably the two closest tint LEDs I’ve seen, dedomed.
Luminarium. I found something extremely perplexing about this entire ordeal over on my end. Now, maybe I am wrong. Maybe I compared 2 other emitters, that are not the same as your “big” and “small”. But I did compare two “new” and “old” Cree XP-G2s to find this interesting thing. What I found, is that my new Cree XP-G2 indeed had a die that looked larger than my old XP-G2. That is, until I measured them to find that they were the same size. What was actually different about them was NOT the die size, it was the anode/cathode insulator line—a package change—that had the insulator line closer to the die perimeter, leading one to believe at first glance that the die was much larger. But it wasn’t!
Has anyone confirmed this, 100%?
I too noticed the color difference just like was stated; new had more of a dull yellow phosphor color, old had more of a bright fluorescent-yellow phosphor; dedomed. But my two indeed only varied in that line around the die, not the die sizes. Another person has also said he noticed no intensity difference between them. I am starting to wonder if some of this is actually human error/perception-based, and not a die which is larger. I bet that any person would say the “new” die is larger 10 times out of 10 when I put them side-by-side on the table because of this package line change, but in reality with my two, no.
I really don’t think anyone should ever think to go after the person that sold them these LEDs. The LEDs are only “bad” in your mind, as you are the outcast user of them. I read some of that earlier about pulling money back from the supplier and I couldn’t believe someone would want to go after a supplier of something that Cree handed to them under the same specs they had always been dealing with. You can’t expect a supplier to be pulling out his caliper to gauge each LED die size, after dedoming one! That’s just not how this stuff works; only inside of our extremely small hobby-bubble on a corner of the internet does it work in die-sizes and high-kcd throw. The industry works in those very specs you see from Cree, but no where does Cree guarantee a die size, or certainly a lux value that cannot be reached.
I have 9 XP-G2 S4 2B laying around for a project. I ordered them a year ago from intl outdoor.
Can someone please confirm they are the good old production typ ones.
(Click image for full size)
He won’t make a group buy , it’s obvious because he only send with expensive shipping overseas .
All the 2B stock is from August 15 (asked welight this morning) the same as those Mitko received .
If someone from AU wants to do it it’s something i don’t know .
Ok,
I can understan everything but I simply can’t understand why he does not want to reply in this thread with macro shots of that reel so we would know for sure and risk those expensive shipping. If I am paying expensive shipping than I got to be sure I have real thing
