Boy, for the ramping level calc, I used this targeting the Q8 SRK, thinking this was about right:
--> for FET+1, 124 levels 4X LED's
level_calc.py 2 124 7135 3 0.3 160 FET 1 10 5000
PWM1 values: 3,3,4,4,5,6,8,9,11,13,15,18,21,25,28,33,37,43,48,55,61,69,77,85,94,
104,115,126,138,151,164,178,193,209,226,243,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0
PWM2 values: 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
,0,0,1,1,2,3,3,4,5,6,7,8,9,10,11,12,13,14,15,17,18,19,21,22,23,25,27,28,30,31,33
,35,37,39,41,43,45,47,49,52,54,56,59,61,64,66,69,72,75,78,80,83,87,90,93,96,100,
103,107,110,114,117,121,125,129,133,137,141,146,150,154,159,164,168,173,178,183,
188,193,198,203,209,214,220,225,231,237,243,249,255
For testing though, I'm using a M2-Z with one XPL, and it doesn't look good at all. When ramping up, it ramps quickly in the beginning, seems to pause at one level, then goes up slowly.
Of course the table was created for a 4X LED with good cells, while the M2-Z is 1 LED and running on a Pana B 3400 cell at 3.8v. But still, didn't expect this. Gotta try it in the target light (I got one modded up from a junker SRk 4X). I donn't think it will be much better based on the values in the table - too litle 7135 levels, too many FET levels - that would explain how it functions.
Anything you see here wrong, either the way I did it or the resulting values?
