Last one I paid $6.20 from BangGood. Currently $8.99. Is there a discount code available for them?
The one for $8.99 is the new driver BLF X6/X5 Driver ATTiny25V-Based.
M4D M4X has codes for both the old/new ones.
Astrolux S1 A17DD-L FET+1 2.8-4.35v 7/4 Modes Flashlight Driver
Code : f65358
BLF X6/X5 Driver ATTiny25V-Based and FET+7135 Power Channel Configuratio
Code : bistro
Too slow. :confounded:
Click on the link in the doc below or Mad Max won’t get his :money_mouth_face:
The BLF A6 driver is $6.24 and $5 if you use the link provided by M4D M4X
It’s listed here at N° 101, click on the link and use the code.
THANK YOU !!
:person_facepalming: Thanks for that…how’d I not figure dat???
Excuse me for barging in, have a question, both of this drivers have “Pin3” on the spring side, what is if for? I am sure it is explained somewhere but for the love of the god I can not find it
If you ground pin 3 it enables mode memory, that’s why it’s near the ground ring so you can just make a solder bridge.
But you can also enable mode memory by just using the on/off switch and setting it up yourself.
Thanks for the info, thought it is for something that is not achievable via UI (I know about turning on and off mode memory via UI)
I have one of the older A17DD-L FET+1 2.8-4.35v 7/4 Modes drivers in my new build, triple XP-G2 and it spits fire at 7.62A,
I will try to make one with triple XP-G3 today if I find the time and save those XP-G2s they are old stock…
Anyway, piti this driver doesn’t have “turbo only” setting…
