Impressive! Thank you.
The XP-G3 S5 3A has the same weird corona and centre tint, similar to my S5 2A.
Xpg3 looks to be somewhat a disappointment.
Personally, I like the tint to that xpg2 the best.
Are you able to get the lux and lumen measurement to each emitter?
Surprisingly the xpg2 does not look any or much less than the others.
I’m sure you can tell notice it more shined out in the open.
Thanks for this test!
Thanks MEM. Nice work.
Thanks MEM!
Nice beam comparison, that was a lot of work! I recognize the beam of the XP-G3, it looks very much like the beam of the Luxeon Q that has the same build.
The OP would however gain completeness and significance if each beam was given with the luxnumber of the hotspot. You are almost there: same host and battery configuration over all emitters and a standard set-up at 5 meter, just get yourself a (mid-quality) luxmeter and do the measurement.
+1 I was thinking this, but didn’t want to be the one who said it! Luminarium would have his direct comparison then and we’d all know how these emitters actually line up against each other!
Nice photo.
What kind of white balance setting? XP-L HI is too much blue tint than I expected.
I took a photo for stock XP-L dedome. And that is too much greenish color. So I sold it.
However your photo’s stock XP-L DD seems like nice tint.
So I wonder your white balance.
Above is my photo.
Distance about 50cm, ISO 100, White Balance Sun, 1/250s
Camera is Panasonic Lumix DMC LX5
Hi MEM. Very nice. Thanks Do you maybe have lux figures?
Edit: I see you’ve listed some figures here. I see you mention that there’s a factory DD XP-G2 version. In the current post you mention that the XP-G2 S2 1A is non-stock…
How does the stock vs non-stock XP-G2 lux figures differ? Do you know the spec, including bin, of the stock DD XP-G2?
Hey fenno. Take it easy… By the way, watch your mouth, not really acceptable in this forum
Impressive work here MEM! Now I like you even more
Of course lux results will be appreciated.
But about that XP-G2 work it is really necessary to determine weather you have old or new production process emitter cause new production process(since several month ago) had influence on all emitter bins… Not just on xp-g2 s4 2b
If I may add XP-G2 looks more intensive to my eyes.
Best Regards
LI
Hey fenno, it is not that you can demand that, is a lot of effort and MEM or anyone else over here is not payed for what they build, measure and post.
No one will stop you if you measure the luxvalues yourself, and if you do, please do post them at BLF.
:person_facepalming: :confounded:
Anyways thanks for posting MEM. I’m a little surprised by the tint circle on the G3 as well. I thought the blanket of phosphor would have the opposite effect.
Wow, what an impressive array of comparative lights and beam shots. Thank you very much for this great contribution.
Thank you for taking all these photos MEM.
Not knowing much about photography myself, could you explain why the beamshots look bluer the faster the exposure is?
Cheers
Nice work!
Looks like the DD XP-G2 is still on top for beam intensity there (and seems to be a very neutral-tint after de-doming).
The DD XP-L V6 3D looks nice as well, and probably a good mix of throw/flood. The DD XP-G3 does look a bit disappointing though. A bit too much yellow/green tint-shift and a blue/UV corona. Maybe that one was just a bad draw of the de-dome “tint lottery”?
Thanks for all your work mem!
I do have a lux meter. It’s sort of in a, not exactly permanent, but another location than where I took these. This was more of a test of tint comparison and beam profile.
The white balance was on incandescent. I thought the 1/320 images were remarkably close to what I saw—in person I didn’t think the stock XPL was so green in this test, so it looked realistic, but I agree that the XPL HI looks very blue. On the other hand, focus an XPL HI 1A behind a lens, and the surface mostly is that blue.
I said other than factory, because most people aren’t aware of my group buy I did to get a custom model. The LEDs are supposed to be S2 1A, and I did confirm this quite well.
XP-G3 has the hotspot/corona effect of the old Seoul S42180 High CRI emitters, wonder if that’s consistent across all tint bins?
Thanks MEM, great work.
Maybe you don’t know but even XP-G2 S2 1A are affected by new production process. Confirmed by several members.
By judging your pictures you may have old production process XP-G2 S2 1A.
Your pictures explains a lot and thanks to Djozz and your test here we can see that XP-G3 is not improvement at all… Well at least in de domed version.
The ones that are able to get old series of XP-G2 emitters are lucky persons… It seems that you are one of them.
