single 18650 + XHP70: nitecore TM03
129 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 5 months 3 days ago
found this:
http://flashlight.nitecore.com/product/tm03
Quote:
Max Output
2800 lumens
Max Beam Distance
289 m
Max Beam Intensity
21000 cd
Max Run time
30 h 0 m / 1.25 d
LED
CREE XHP70
Reflector
OP
Battery
TM03 18650
Special Modes
SOS
Length
159 mm / 6.26 in
Head Size
40 mm / 1.57 in
Weight
213 g / 7.51 oz
Feature
STROBE READY
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
pilotdog68
pilotdog68's picture
Last seen: 9 months 3 days ago
Interesting. That’s going to be one floody light for sure. What kind of amp draw will the boost driver be pulling from the battery to get 2800? 6amps+?
M4D M4X
M4D M4X's picture
i assume 60-100% more than emitter amps depending on cell voltage
reflector looks quite deep
PLEASE NOTE
will34
will34's picture
Last seen: 1 day 9 hours ago
21kcd from a XHP-70 in a small OP reflector!? If this is true this light has some crazy output
KawiBoy1428
KawiBoy1428's picture
Last seen: 4 days 12 hours ago
Now that’s different?
KB1428 “Live Life WOT
KawiBoy1428
So is that? Makes me want to get one just to try it!
EasyB
Last seen: 1 hour 16 min ago
This is a pretty cool light. It has similar performance to my triple XPL V6 2C (dome on) with cute-3 SS optics. Similar head size in the solar storm K2 host I have it in (40mm). Running at about 9.6A, the triple has 22kcd.
This XPH 70 light might have some advantages depending on how efficient and well regulated the boost driver is, and whether it can be modified to send more current.
keengeorge
Last seen: 11 months 2 days ago
And the body is 4.5mm thick.  smile
unknown00101
Last seen: 2 months 9 hours ago
$130? Dang. I’ll wait for reviews.
texas shooter
Last seen: 6 hours 17 min ago
Take a look at that battery. Is that a double contact head? Another specialty battery? I do like the bold steps into MEGA bright realms their taking. This also begs for a 26650 format. 4.5mm wall thickness, love that heat sinking. 231grams/7.5 ounces.
blueb8llz
Last seen: 18 hours 23 min ago
Wow very cool light that’s for sure. Didn’t expect to see that $130 price tag tho.
I’ll be in for a group buy though. I have several nitecore’s so I do not need to wait for a review, I love their lights.
Caleb
Caleb's picture
Last seen: 3 days 19 hours ago
Wow! Now they need to make a 26650 version.
antiparanoico
Last seen: 5 months 4 days ago
This is not good… but if it works with any 18650, it is good. I will wait for some review.
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
electricjelly
electricjelly's picture
Last seen: 1 day 11 hours ago
I bet that special battery was needed to make the mode switch in the tail work.
blueb8llz
No, the special battery is not what’s needed to make that mode switch in the tail to work.
I have the nitecore p20, and it has the same tail cap mode features, and any 18650 works.
I hope we would be able to use our own 18650 because I’m sure we can squeeze a bit more lumens out from a 30Q.
But anyways, I have a nitecore 16340 cell, and it was actually very close to my AW imr surprisingly.
So it’s not all too bad.
texas shooter
That part where they state that the battery can be charged in “most universal charges”. It says to me only our battery will work in this light. Streamlight does this with two contacts on one end and a contact on the opposite. In Nitecores picture it’s Bottom and top center charging. Top center and top ring for running the light. Then bottom and top center for mode changing and on/off. This so cheap #$%fire don’t explode. With the light off still going to have that parasitic drain.
zelee
zelee's picture
Last seen: 1 week 12 hours ago
$130?
Better be good
Firelight2
Firelight2's picture
Last seen: 8 hours 26 min ago
Very impressive output for a single-cell boost driver. I don’t think I’ve seen any reports of higher.
LarcKen
Last seen: 4 years 11 months ago
Wow, maybe my new EDC contender.
I’ve had EDC-ing P10 and now P20, i just love that two switch on the tailcap setup.
Lonelydad
Lonelydad's picture
Last seen: 1 week 1 day ago
Location: Formerly of Western Iowa, now Kansas City, USofA
I lean more towards the idea that the special feature if the cell is that it is a protected IMR. That would make sense since it seems this light is aimed at the LEO/Security user, who usually isn’t all that up on Li-Ion in general and the care and treatment of IMR cells in particular. With a protection circuit Nitecore is making sure that the cell is not drained to the point of damage. I know someone here or at CPF will drop a regular high drain IMR cell in to see what happens, and let us know.
You don't really need a parachute to skydive. But you DO need one if you want to skydive twice!
M4D M4X
M4D M4X's picture
code is available…
PLEASE NOTE
Andybibbville
Andybibbville's picture
Last seen: 1 year 1 week ago
Can I get the code please.
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3 And God said, “Let there be light,” and there was light.
keengeorge
+1  wink
Skull
Skull's picture
Last seen: 11 months 3 days ago
Code please
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
Looks nice, but I’ll pass due to the proprietary battery and price.
Boycott Nike
zelee
zelee's picture
Still waiting for a review
Eth90
Last seen: 2 years 8 months ago
4.5 mm wall thickness, sounds very tough.
Up
HorizontalHunter
HorizontalHunter's picture
Same here. I am waiting for some reviews and beam shots to get a better idea on real world performance. I currently have the Fenix TK 16 and I am very happy with it. I wouldn’t want to go any bigger for an EDC.
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
Robbarajas87
Last seen: 5 years 7 months ago
I get mine Monday or Tuesday I’ll post beamshots
LarcKen
g_sintornillos
g_sintornillos's picture
Last seen: 1 year 3 months ago
I wait for a real review and I want to know if it works with a generic battery, if it only works with its dedicated battery I do not want it, but if is a gift maybe I accept it
Sorry for my bad English (gogole transtorla)
