Ok. Can I change the first ramp entry from 3,0,0 to 0,0,0? and if I want to put that into a mode group, I would enter a 1 where I want it to appear. So I could change the first mode group to 1,40,0,0,0,0,0,0 and that would give me one faint glow mode and one high mode. Am I correct?
Yes, that should work. If you still want moon mode though, you should probably edit the thing which adds moon to set it to level 2 instead of 1.
Or you could just use “moon” as the “off” mode, which would only require setting the first level to 0,0,0.
If I left the moon settings as is, could I then use the moon config toggle to rather toggle the false off mode? I’m trying to think what to call a fake off mode:) have others talked about this concept for hunters or others needing an off without a click?
Yes, you could simply set moon to “off” and use it otherwise the same.
Ordered some v2 boards today .
In the bistro-tripledown.c , do i need to change something to flash it on a attiny25 ?
thanks pd for the boards and tk for the fw .
Bistro-tripledown is intended for attiny25, but after verifying the hardware works you’ll probably want to change some things in the code. It’s still configured more for testing at the moment, and less for actual use. You may also want to re-calculate the ramp, depending on how bright your host is.
Thanks tk .
I will probably need your help in modifying the code , or some tips , but i will ask when i have the drivers ready…
Any news about this?
I would like to use this driver in a dual switch light (modified Courui D01)! Control the modes with the e-switch and on off via rear switch with mode memory.
Not tested just quickly put together during lunch break.
Feel free to give it a go
Not sure which will work best.
“fixed it” also posted some code a couple pages ago that I still haven’t gotten around to testing.
Flashlights have been on the back burner for awhile now
Thanks pyro1son, I’ll give it a try.
I see that #define ALT_MODES is commented out, do I need to remove the comment?
For example, if I would like to have 5 modes I would write the following?
#define MODES 1,90,255,255,255
#define ALT_MODES 0,0,0,255,0
So I would get moon, low, single 7135 on full, single + secondary 7135s on full, FET ?
edit: mmh I think with this config I would get the Turbo mode in mode 3 already. So it would be good if I could write
#define MODES 1,90,255,255,TURBO
use ALT_MODES for the single 7135
MODES for the larger bank
put 254 in MODES for the FET turbo and 0 in the ALT_MODES
I’ve commented in ALT_MODES
Nice clean looking code! Thanks!
Ok, so I built a board and tested it with a working rear clicky firmware. All fine and working
Then I uploaded the new dual switch firmware and soldered a small cable to the outer ring.
I connected it to a battery and it starts in direct drive (=the highest mode).
If I touch the otc pad (=pin 2) with the small cable it should change modes right?
Anyway, nothing happens. I tried a few other pins on the attiny, but only the fet pin (=pin 3) did lower the output and as soon as I removed the small cable it was at direct drive again.
I tried both firmware versions and also tried it with and without the otc cap, because this is not needed in a dual switch light right? But no difference, I can’t get it to switch modes.
Here is a pictures of the driver, sorry it is a little bit dirty looking now.
Which code did you use?
I tried both, just changed the modes to
#define MODES 0,0,0,255,254
#define ALT_MODES 1,90,255,255,0
#define MODE_PWM PHASE,FAST,PHASE,PHASE,PHASE
Just make a fix in Mk2 there was a slight issue with some of the brackets. Try now.
I will try and get some time to test this myself but wont be for a while
Thanks, I’ll try the updated Mk2 version.
Ok tried it and still the same problem, the driver does not switch modes.
I also tried changing the switch_pin and fet_pin, because the switch is connected to pin 2 and the fet to pin 3 right?
#define SWITCH_PIN PB2
#define FET_PIN PB3
But also no luck with that …
Hmmmmmm,
I’ve tried something more like the current clicky switch FW HERE
Can you make sure that TK’s Ferrero_Rocher works on your driver first.
