RCR 123 Rechargeable batteries
Our Flashlights are S1 Batons . Do I need to buy only Olight batteries? What battery best suits the S1 Baton 700mAh or 650 mAh etc? Where can I order online some good priced batteries please?
You would be looking for 16340 batteries i would be guessing that most of them will fit maybe only the IMR cells may be a bit small…
I’ve tried several brands of 16340 for my S1 Baton and all of them are working fine.
My EDC is a WK21 xtar all 16340 fit but it doesn’t have double spring so some IMR are a bit small and rattle but i think the baton has double springs?
I do not carry S1 Baton at this time, but as far as I remembered, yes it has springs on both side.
I use eagletac 16340 batteries and find them acceptable for EDC and home use. for my car I keep cr123a batteries simply due to the excessive heat in phoenix.
Efest 16340 V2. 650mAh tested capacity and up to 5.2A direct drive a XP-L HI. Best 16340 out there…
IF you want to use unprotected IMR cells they are. If you want a protection circuit then maybe not.
For my s1 baton i bought olight batteries i thought why not ? but u dont have to ofc. Good brands are otherwise Nitecore batteries. Buy them from amazon maybe ? not sure how shipping to Sydney would be a problem or not…
I’m using Efest IMR’s in my S1 no problem
I just put IMR inside my WK21 and now it doesn’t want to work proper maybe to much current! They fit okay but they do move around a little more then the soshines and the soshines are a bit fatter and longer!
I shake my Olight S1 Baton with the Efest 700mAh IMR and I get no intermittent connection, nor rattle. I’m not familiar with the WK21. All I know is it works perfect in the S1
Yea double springs? Because my light is a twist to change modes so you cant use springs at the front its a bit different i don’t have an S1 i was thinking about getting one.
I think you’ll love it.
BTW, I like your youtube channel
Thanks mate.
Anytime my friend :slight_smile:
Here are some cheap RCR123…http://www.banggood.com/1PCS-SKILHUNT-3_7v-650mah-Protected-16340-Li-ion-Battery-p-986616.html
I just bought some fandyfire IMR 16340s from fasttech they tested out to have 550Mah one charge they had almost 600Mah i paid about $5 for two.
https://www.fasttech.com/product/1658601-fandyfire-imr16340-3-7v-700mah-rechargeable-li
Or the protected soshines are going cheap now. $3 each they have about 700Mah capacity
https://www.fasttech.com/products/0/10002177/1157000-soshine-protected-rcr123-16340-37v-700mah-recharg
