Used Kiriba’s triple pill for a red convoy S2+ build today.
-Triple 219C on noctigon, soldered directly to the pill of course
–8x7135 guppydrv Qlite driver
Everything fits nicely and the driver was easy to solder to the retaining walls. Much better than using the stock brass pill converted to triple pill with a 16mm mcpcb for filling.
Now that I found a quad optic to fit, convoy M1 is fast becoming my favorite host. Spacers is the same type of design as X6, 26mm and a bit taller. Great host. More pocketable than X6 with lots of cooling fins on the head.
35mm Khatod. It’s the same as the 25mm khatod but with a 10mm apron around it. I use a dremel and sand it down to 30mm for the M1. It’s also twice the hight of a 24mm Carlco quad. A very useful and adaptable optic.
This ain’t China. If you want a quad that fits from 25mm to 35mm, that’s it. I’m installing one in an S3/X5 right now. Fits right into the bezel after sanding to 26-27mm. The lenses are 7.3mm taller than a Carlco quad. I had to cut off the legs to fit into the small S3/X5 head. Should have it up and running on Saturday…
