I have experimented with the Miller ML-202 recently, and it does work well except for one condition… when the batteries are depleted and the unit cuts off (as a battery protection measure), then it wont cut back on when line power returns without user intervention. In my case I had to pull both batteries and line power to reset the charger. Then the batteries will charge back up so long as the load doesn’t trigger the battery protection again…
The newest xiaomi QC power bank has this function…and your plan seems okay but the problem might be the 3A, if the router really needs 3A for a longer period this is probably to much for the most pass through power banks…
HKJ has some reviews and since a while he marks the item as UPS if it has this function.
I must not have notifications set up properly, I didn’t know anyone had replied. Thanks for all of the responses. I definitely need a hands off solution, so I am glad to know about details like the battery protection cutoff that netprince mentioned.
I agree that 3A is a pretty high requirement. Since this group of experts doesn’t know of an off the shelf solution, I think I am better off buying the smallest UPS I can find.
The first thing you can do, today, is to use a fixed IP address for your Router (and any other infrastructure equipment you have).
If you can’t do that, see if you can get some sensible IP address Reserved in the DHCP Server for your Router (by MAC address, but you can see that from the DHCP server while everything’s working).
Then you’ll only have to deal with the howling silence coming from whatever’s on the other side of that Router when it’s down.
Then you can take your time digging up a wee UPS. Like this maybe
I wish I could use a static IP but that is cost prohibitive. Both devices behind the router are static.
Nice find on the APC 70. I found this 400w that might fit. It is cheaper and offers more run time. I will have to get the dimensions of the enclosure itself to see if there will be room for either.
The brick wall and the metal door are both tough. Wifi is used to get the new public IP so Wifi is enabled. It’s range is only actually good directly in front of the door.
Worse, this is on Frontier who bought out Verizon in this service area. They have done such a bad job with the transition that they are getting sued for it. This router doesn’t update the DDNS address I got from dyndns after a power outage. I don’t have a Windows/Mac/Linux device that can run their DDNS update client. A UPS seems to be the better choice over configuring a RPi to run the update client.
Why not just pay the good folks over at DigitalOcean $5/mo for your very own VPS server? Then you don’t need all that… stuff.
They bill by the hour, so you can leave anytime.
Yeah, the Router would have to support it, and I can’t really tell from your picture which Router you had, so I took a shot.
Have you monitored your mains supply to see how long & how frequently it goes down? If it’s not a big problem, maybe this Portable Phone Charger could be adapted to plug in to your Router.
EDIT: Knowing how much your Router actually draws (the wall wart spec is for extreme conditions) would help compute the capacity you’d need for the expected downtime.
The only reason I can think of for DNS mattering is you must be running a home server. I was suggesting running it ‘in the cloud’ instead. Then all you need is basic internet access like the rest of their customers, so DNS and DDNS doesn’t matter.
“The cloud” is just a euphemism for “The Internet”. He stated he has deployed 2 cameras & that’s all that’s behind the quite ignorant Router. It wakes up lost in the woods & no way for anyone in the cloud to know how to find it until it reaches out, which it probably cannot be made to do.
The cameras are, essentially, Servers, but they’re quite ignorant too, in that all they can do is be HTTP Servers & don’t know how to detect their WAN IP address & send an update to DDNS.
However, comma, if they could be configured to push their content, the IP address wouldn’t matter… ?? Or have either the cameras or the router save their log files on your end, which would show up when a power-cycle triggers their logging to start… Or have either of them “simply” (yeah, right) try to connect to your end via some weird port, which you could set a Firewall Rule on your end to raise an alarm on access to that port…
Grasping at straws here. What’s your longest Outage to date?
I guess my reading comprehension was kinda low yesterday when he said cameras. In that case, my advice is to maximize the UPS runtime by only powering the modem during the outage, the other equipment is not needed to hold on to your IP. Also, some routers have no-ip functionality built in.
I couldn’t reproduce your problem in the last 2 days of testing. My ML-202 V4.0 starts up without hesitation every time. The only issue I can image is when using protected cells (but ML-202 doesn’t have room for protected cells!?)
