I also tweaked the method of Rudeness points expiration:
Originally it would expire a rudeness point 24 hours after it was given. This would make it so that if the user created a rude post and then disappeared for more than 24 hours, (s)he could come back and potentially find a clean 0 rating for rudeness with no indication of how offensive it was.
So I changed it so that now, the overall rudeness score will tick down by 1 every day. This change has been reflected in the OP.
I just tried marking one of my old posts as rude, but got a “website has encountered an unexpected error message”, maybe it was just from the load of people trying it, but fyi.
However, the reason I was trying it was to see if there was a way to easily see which posts were marked rude and which ones I’ve marked rude so corrections can be made in case it was updated by the poster?
It is also important to note that all of these labels like “rude” and “troll” are used to silence those who choose to dissent from majority opinion. So if you think differently, you must be rude or a troll.
Oops, sorry, looks like I broke it. Should be working now.
This would be a lot more difficult to implement on a technical level, but it’s definitely not a bad idea.
Now, ah, could the button appear on the ads as well?
I’d like to tag the whatchacallit MilitaryMonster700 ads….
I think I’m just joking, but these days with smart coders I can never tell in advance whether I’m joking or wishing in the presence of a wizard, and I’m often surprised by what can be made to work.
This is an important point. One of the major instigating factors of fights here is when people start throwing around insults and labels like that. So the original post in this thread tries to be very clear; if you feel somebody is out of line, be it “normal” rudeness or “trollish” rudeness, please refrain from calling them out, and don’t have any interaction whatsoever with the person. Instead, hit the Rude! button and contact me if it’s an extreme case or becoming a pattern and I don’t notice it.
But please also keep in mind this recent addition I made to the original post:
sb56637 wrote:
Also, please remember that BLF is not Reddit or Slashshot, and I don’t want it to turn into that either. So please do not use the Rude! button just because you don’t like or don’t agree with the post or the poster. It is intended exclusively for use on rude, lewd, or conflictive posts.
Well actually yes, you are in the presence of the Google wizardry, which usually targets relevant ads, but occasionally gets them dead wrong. Sorry about that, those are ads that Google personalizes for you, and no two people get the exact same set of Google ads, and I don’t have any real control over what they serve up for you. With that being said, if you continue to see a really annoying or really inappropriate Google ad on this site please let me know and I can block that advertiser. The emphasis being on “really”, because I’d prefer not to be deluged with more administrative tasks.
PS: how do I discover which of my posts were “ruded” ?
Sorry that’s not possible at the moment. In retrospect I guess this is a fairly important feature for this system to work better. I’ll see what I can do.
I wonder if TK’s ‘killfile’ could also be implemented as a button.
Because I think there’s, for most of us, some sort of comment that (while not ‘rude’) hits a hot button.
And some folks do enjoy banging on their favorite buttons to see who gets upset, vs. who applauds.
“… this flashlight fries the craven illiberal hearts of lotus eaters…..
That sort of thing. It means nothing but it incorporates a few buttons that might touch tender spots in someone who sees a buzzword.
Those are the sorts of posts where a “don’t want to see this ever again” button would be most helpful.
Yeah, I can edit the CSS in TK’s “after dark” to enable the feature now. I do. Works great.
But how many among us who see something that pisses us off react by immediately wanting to go copy and paste a bit of code so we don’t have to get pissed off?
Backing away is, you know, the right thing to do. It’s also the difficult thing to do.
First, I hope this doesn’t make a lot of extra work for you as admin, people playing with something that is meant very seriously.
Second, I already see people playing with the button, raking up big numbers like it’s a matter of pride, when in fact, rule number one clearly states that rude behavior will get your membership revoked. So maybe I’m just thinking too literally but I saw the Rude! button as a 1-10 scale of how close you are to getting banned. Going to 12 or 20 or 50 just seems like someone asking to no longer be a member on BLF, according to Rule #1.
And lastly, how do you establish this difference, between playful running up of the numbers only to watch them fall over ensuing days versus real actual rude comments made that should have someone ejected from the forum? If the “ticks” count down daily, then it’s easy for anyone to intentionally be rude and get away with it on a regular basis.
I was a member of Photography on the Net (POTN) for years, they used to use this type of system and it became so problematic they did away with it.
I have seen members here blatantly break rules, in ways that should have banned them according to the rules, and yet they are still here. Thankfully, TK gave some options and I am using those options where BLF protocol has failed.
Seems like this is going to be more work for you SB as opposed to less work. It would appear that there are going to multiple cases of members being ostracized for their dissenting views in any given thread. Hence, you will likely have to go back and analyze the true nature of the individuals “rude” total as opposed to simply banning them. My dissenting opinion here alone would likely get high “rude” totals in a GB setting for example, as there always seems to be two opposing factions in each GB.
I understand that users are playing with the button right now, because it’s new. Once I make sure the bugs are worked out of the system I’ll tell users to only use it seriously, and I’ll probably eliminate the ability to “rude” one’s own posts.
Sometimes the user has actually been banned, I just don’t make a public announcement so as to not give more glory to users that are trying to get attention by being rude. And sometimes I simply don’t notice rude behavior and/or major violations of the rules. So I would appreciate a PM in cases where you feel somebody is showing a pattern of major rudeness.
We’ll see how it works. Of course everybody has a right to express their opinions and even dissenting views, which is the whole purpose of a forum. But the problem is that a few people are being extremely rude while expressing their disagreement. I do want to reiterate yet again that the Rude! button is not meant for disagreeing with an opinion, but rather for flagging posts that are inappropriate.
I have my own opinions as to what constitutes rudeness, but if a significant number of people agree with me by marking a given post as Rude!, and if the poster is a repeat offender, I will ban them, just as I’ve always done. I’ve always had to look into scattered cases of trolling and extreme rudeness, so nothing changes there for me. Now I just have more opinions to take into account when making the decision, and not all of them necessarily have to flood my PM inbox with complaints about an individual.
Judgement was called for in the past and is still called for. The rude button is merely a tool to help people become more aware of how they are perceived by others including those who have declined to respond to the rude posts in the past. Hopefully with the benefit of reducing rude responses by those who do respond. There have been a number of insults tossed off in a variety of threads where the poster took for granted it was ok to do so and though they were not trolling were most definitely rude. “Aggression unchallenged is aggression unleashed” Phaedrus(15BC-50AD) so thank you SB for providing an acceptable form of challenge. This shouldn’t be viewed as some license to go on witch hunts though. Undoubtedly, some will take offense at having their behavior challenged viewing it as a challenge to their freedom as it’s a rare bird that can accept criticism and take it to heart with humility. Most seem to snooze after a wake up call.
Very nice! but what if a users start to abuse the Rude! button and reports a large numbers of posts from the same user? Is there a limit of how many rude reports can someone submit in a day?
Maybe implement a “rude validity” rule, X amount of rude reports to score a rude point?
I’ve seen a lot of rudeness towards people selling things, especially and ironically Chinese vendors, when someone doesn’t like the prices they see. I’d say it’s a defining characteristic of BLF. Saw a vendor thread recently where the 1st reply was dogging on the price, which was no surprise at all to me.
^ This is the idea.
I would also add that we’ve seen a lot of cases where normally friendly users speak up when a fight breaks out to defend who they perceive to be the “innocent victim” or to reprimand rude users. But by doing so, they often get dragged into the fight, their post bumps the thread up in the recent posts, and if there is a malicious poster there (s)he will use that as additional fodder to inflame the argument even more. But now the Rude! button is available so that those who just sincerely want to help don’t feel tempted to intervene in an argument.
I agree with Will34.
I have a feeling that the same people that the rude button was created to deal with are going to be the same people who use it the most.
Glad you brought up this important issue. It’s important to note that the BLF Rules against rudeness and fighting do not have any conditions whatsoever relating to country of origin or seller/customer status. Please remember that non-spam posts by foreign sellers should be treated with the same courtesy that any other BLF member deserves. There is a real person sitting behind the keyboard that made that post, and they have feelings too, whether they understand English well or not. Of course you are welcome to try to ask for a better deal or haggle on the price. But if you don’t like the seller or you’re not interested in the deal, just step away. If it’s a terrible deal or otherwise unwanted (but not spammy) vendor, they will naturally sink into the background if users simply don’t respond. Responding with personal insults to poor marketing will only bump up the thread and give them more attention.
Science has learned recently that contempt and indignation are addictive mental states. I mean physically and chemically addictive. Literally! People who are self-righteous a lot are apparently doping themselves rhythmically with auto-secreted surges of dopamine, endorphins and enkephalins. Didn’t you ever ask yourself why indignation feels so good?…
… Can we step back to see that this emotional need to feel superior runs deeper than any of our superficial differences over politics and ideology? It makes you far more like your opponents than you would ever like to admit….
Thou shalt not offend others.
Thou shalt not allow thyself to be offended too easily.
Sometimes you don’t know till you try, if this works out then great, if not then it can be removed or tweaked.
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
I prefer to keep it simple for now. The Rude! counter automatically ticks back down, and a single user clicking multiple posts won’t get them removed. So even an attack like that wouldn’t have any permanent effect. Of course I will be carefully watching for abuse against the system, and abusers will be punished by permanent banning depending on how they respond to my PMs.
It’s certainly an interesting topic. It will be interesting to see what others deem constitutes rudeness. There will be debate which will also present samples of some of the different types. I hope this works, getting people to excercise control isn’t easy and most don’t even realize that habits of speach can carry built in insults.
I honestly think this is great. It creates a ‘level playing field’, so to speak; for all involved… new to old.
No more inequality, whether real or only perceived.
I do find it somewhat hilarious that the OP in this thread was last night, 11 June 2016 at 22:00 hrs. ; I have made exactly one post since that time thanking 2 people for sharing beam shots. [ This post will be the second one]
Yet when I actually found this thread a couple of hours ago, my Rudeness Score was already a 4 of 10.
And while I was reading this thread it actually advance to a 5 of 10.
I assumed this was for posts moving forward and not going back through old posts???
But you would be able to “see” that behavior I imagine… if anyone chose to do it.
Either way, no worries: this move is a great one Sb as far as I am concerned!
And I know the kinks, if there are any; will work themselves out over the next few days.
I bet this will help us all ….. think before we post, as AheadWeMove.
Sincerely………..
.................................. "Slow is Smooth, Smooth is Fast" ...................................
This ‘rude’ button is a nice antidote to rude posts by rude ‘members’ !
Kudos to our admin for being so patient and reasonable….let’s all hope they all get the message and not abuse the patience of SB.
KuoH
No smoke without fire.
You’re definitely not alone, I even notice some being unnecessarily rude to you and they’ll get the button when it’s justified.
It’s a good deterrent.
I talk too much, and here I go again…
I love this forum very nice and kind people here
Scott
^ This is the idea.
— David Brin
The Journal of Alternative Facts TM
Scott
I deleted my Grammar Nazi post , can .
Didn’t want to be Rude!
Edit :
What I do
Sincerely………..
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
Where does one find their “score”?
Here are a few places:
http://www.consumerfinance.gov/askcfpb/316/where-can-i-get-my-credit-sco...
https://collegereadiness.collegeboard.org/sat/scores
I’m glad there is no sarcasm button, i’d be banned already
