They’ve already lied that they manufacture cells - they don’t - it is cell made in Taiwan and not by Thorfire.
Protected cells are much longer you can compare them.
5000mAh bare cell is longer then smaller capacity cells even without protection.
Quick check for brave guys :
Piece of wire
Short the cell for 1 sec
See if DMM reads zero volts after you shorted your cell(that means that protection kicked in and circuit is open)
With protection cell will not have time to heat up so no risk of some damages.
If it reads zero volts place it in your charger it should have “soft” start, and circuit will close again. All good.
I am not arguing with you & am only stating what Thorfire advertise & backed up by email when I specifically asked them about the cell.
I did mention in a previous post that I was surprised how short the cell was considering it was claimed to be protected.
However the cells tested well against my Keeppower, Basen & Liitokala 26650”s (all unprotected) on my analysing charger in terms of capacity & IR & perform fine in the flash light (which has lots of protection/warnings built in) so I am really not concerned.
Thorfire had a 1 day sale on Amazon UK.
If you bought one of their 18650 motion sensing head lamps you could buy any pair of their 14500, 18650 or 26650 cells half price, that is how I got them so cheap.
I use these thorfire cells in my s70 and plan on using them in the l6 when it lands this week. Haven’t had any issues with them and honestly I’ll probably by more of them next time im shopping on Amazon. Takes awhile to charge back up but I’m using xtar vc2. But I’d rather slow charge my cells and get more useful life. I have another set to switch them out with and like 16 18650s. The lg hg2 work well in the s70 but with 3000 mah it goes in turbo. Panasonic 18650b is a really bad fit light ran but had to keep adjusting tailcap hg2, and 30q had no problems
I can vouch for these batteries, using them in my L6 right now with no problems. Tested capacity at 5148 and 5276 @ 4.21v. Better than my AWT 26650 “4500mah”, i tested these at around 3700 to 3800mah @ 4.21v (I think there are same as efest re wraps). I like these Thorfire guys, they warrantied a light I bought of Amazon after the 30day period (it was actually 3 months after I bought it) and it came from a West coast warehouse in 4 days. They asked me to do a amazon review, I refused but still got the light!
I have received 2 examples of Thorfire 26650 5000mAh for testing from a member of German TLF.
I will post discharge curves for 1/3/5/7/10A (maybe 15A too) this weeekend.
But I can say one thing for sure already: they are NOT PROTECTED
I discharged them with up to 30A (my equipment’s limit). The cell voltage at this current rapidly goes below 2,0V, but the battery does not switch off.
Apparently there is neither any overcurrent nor any undervoltage cutoff.
There is also no visible sign of a protection circuit on the negative or positive pole.
So no matter what “Thorfire” writes on the wrapper: these are unprotected cells! IMHO this puts them in line with other infamous “brands” doing the same thing.
But at least the capacity rating is not inflated.
And the 10A rating is also ok.
The truth is: they are unprotected, as many have suspected already because the batteries are too short to carry a PCB.
And they can’t stand more than 10 amps, show very rapid voltage decay at 15 amps, probably a PTC kicking in (so it wouldn’t be totally unprotected).
This confusion may be why flashlight manufacturers are beginning to use proprietary batteries in high output flashlights as a hedge against product liability.
We need certain amount of regulation to restrict misinformation being used in product advertising and promotion.
Damn, i just ordered a coupple of these…I’ll have to return them then if this is true, I do not want unprotected batteries…
I guess it was too good to be true.
LW , I hope you’re not thinking that I was implying that you don’t know what you are saying. Not the case at all !
I’m just looking for more verifications to the cells being not protected as they are advertised !—This meaning the
second , third and so on , other opinions about the veracity of their stated protection.
You’re correct . In that Amazon ad “Protected” is stated in the main heading of the ThorFire advertisement.
Also in the body of the ad , it’s stated that there’s “protection recharge integrated circuitry built in” ! Now,
read a little further in that ad and notice their slick , somewhat backhanded way of MAYBE denying protection.
It reads: (ThorFire Protected button top 26650 battery is a bit LONGER than “other” NON-Protected alternatives.
Other NON-Protected ! How do we figure it out ? What’s your interpretation ? It appears to me that the ad has
some false advertising attributes !
202bigmike, I did say earlier in this thread that I was not 100% sure whether these cells were protected due to their length but that Thorfire had stated in an email to me that they were.
From what light-wolff has posted it would seem that my suspicions were correct.
What I can say (& is confirmed by several other users of these cells in this & other threads) is that they are the claimed capacity, have low IR & certainly perform fine in lights drawing up to around 6.5A.
Personally nearly all my cells are non protected & I am personally content to use non protected cells.
If you need protected 26650 cells then the easy answer is to purchase some Keeppower 5200 mah protected IMR”s as these are confirmed as a good cell with protection.
I have a pair of KP”s & they are good cells but are 2-3 times the cost of the Thorfire, Basen & Liitokala 26650”s I have & do not have any more capacity than the Thorfire or Liitokala”s (a little more than the 4500mah Basens but not much) & do not have lower IR than any of them.
At the price they cost me, $5 a piece I am happy with the Thorfires, but if you really need protected cells then they are obviously not the cells for you.
If you could live with non protected cells then the non protected Liitokala 5000 mah at about $5 a piece have got rave reviews on this forum & would seem to offer the best “bang for buck” at the moment & would also seem to offer higher drain than other 26650”s available at the moment.
If they call PTC protection but are vague if the parts we consider to make a cell a protected one are installed and now confirmed have not on these tested cells I personally think that is not good.
I will email Barry about this topic and strongly recommend him to have Thorfire give an explanation here. He probably won’t read it till Monday though.
