Dereelight DBS Aspheric throw figures (with new EZ900 0.9mm x 0.9mm WD pure cool white tint 1.5A 3SM pill)
Imagine what would that pill do in Solarforce MPP-1 reflector. The Solarforce is much better host than DBS V3.
Do you have a beam comparison comparing that light to the Crelant 7G5? That's what I would like to see at say 100yds.
I have both the Solarforce MPP-1 (and body tubes in the whole Solarforce lineup) and CL1H V4 and DBS V3 body tubes. In my opinion the Dereelights are quite a bit better.
Square threads for the Dereelights, not so for Solarforce.
The MPP-1 head cutting is quite sharp as well...the Dereelight is just a joy to hold.
I have both Solarforce and Dereelight clips, i like the Dereelight better (not that it matters, coz i don't really like clips anyway LOL!)
The HA in the Solarforce tends to chip off too. In fact one local flashaholic was so outraged with Solarforce with the L2P, the thread is both in here and CPF. Mine has minor chipping too.
The Solarforce S8 is crazy though. No chipping. It seems that the L2P/L2X do chip.
Body tube thickness, at least from the tail end, is like 2X thicker for the Dereelight than the Solarforce.
Dereelight has no chips in the HA.
Dereelight has double O-rings.
Nice throw going on there with the DBS however a bit pricey for my blood.
I thought that is what i did for the above beamshot.
Aww shucks, forgot to take a picture with the Solarforce MPP-1! But trust me, it makes the Solarforce MPP-1 look like child's play in terms of intensity. The hotspot of the DBS Aspheric is actually like 10% larger.
MPP-1 full HA setup would be $60 with registered shipping? 1 mode, so no such thing as PWM. This is 79.8 w registered shipping. 3 modes, no PWM. And you can swap it out with a XM-L pill for 50k cd performance and 600 lumens OTF. (I have the T6 3C, from the CL1H V4, now only 54 bucks shipped)
This thing visibly out-throws my TK70 at a 600m target. Actually i can barely make out the TK70 spot even with binos, but Dereelight DBS no issue at all.
I think the lux @ 1m only tells part of the story. Coz the TK70 got just 5% lower figures at the exact same spot which i measured the Dereelight DBS. And mind you i measure at 45-50 metres. This is because this is an aspheric....the focus is key.
Part of the reason could be that the TK70 throws out a huge cone of light. Hence through the air, the beam is quite visible as it is quite thick. This lowers the visibility of the hotspot at target. This phenomenon can be seen here.
DBS aspheric and then TK70 (last one is Sanmak 5200)
At 100k throw it would stomp the MPP-1 for sure. One light I still lack is a pure thrower, mainly because I really dont have a need for one. It would basically just be a toy for me. However, I wonder what kind of numbers my HID with 55W bulb with the 100W ballast/8.5" reflector would do in the throw category.
Ok I guess I am lost. I don't see the Crelant 7G5 shot.
And one more question. If this light is such a great thrower, then why is it only about 250 lumens or so? I guess I don't undertand how it can be brighter than the TK70 as for lux reading at 1 meter. Please explain if you will.
See my above video, everything is there! LOL! :D
If you get 4 DBS V3 aspherics, it would be 1000 lumens and have a hotspot that is only twice in diameter than the original one. It doesn't take much to reach 2200 lumens, just another 4 more DBS aspherics, but only increase of what 33% in diameter? (someone do the math pls)
Also, aspherics are a bit different from reflector setups. As you can see, the hotspot is even a wee wee bit bigger than the Solarforce MPP-1, but lux figure is twice as much.
In fact on a reflected ceiling bounce, the Solarforce MPP-1 registers 22.1 lux. The DBS aspheric registers a paltry 15.9 lux. Sealed Actually the DBS aspheric is like ~ 160 lumens OTF only. Thing is, nobody is going to do ceiling bounce or light up a big room with this. This is for outdoors use only.
Short arcs can be in the 2000 lumens range, but do 12 million cd and throw for several miles.
It's above the DBS. You can't really see it because it's too much ambient light.
However this BDS is an aspheric with an XR-E R2 (EZ900 die) and of course the 7G5 is no match for it.
7G5 is slightly superior compared to all other XM-L throwers.
As you can see, the hotspot of the 800 lumens OTF Crelant 7G5 isn't that much bigger than the 160 lumens OTF of the DBS aspheric.
My 65W Ebay metal tube HID flashlight smokes this though (and so will the 75W and 85W versions).
This is what I said:
You can see the corona lighting up some parts beside the Crelant 7G5 hotspot. Also there is the spill light, but of course for such comparisons it does nothing.
Ok so what you guys are telling me is who needs a Crelant 7G5! Laughing
Nothing to do with Crelant 7G5, add there all the xm-l throwers you know. :)
Not really, that one is one sexy light as well.
Who needs 60 Solarforces as well anyway.... (I think it's old4570?)
Shoot. I think that this thread has convinced me that I need one. I have yet to get a good aspheric thrower so I may as well pull the trigger (ohhh my college student bank account :()
