hmm. ok so are they created when i build the hex? excuse my ignorance!
or are you saying they should be part of my avr software package? sounds like i should just build the file and give it a try then…
Yes, they should come installed with the compiler. You won’t be able to compile most firmware without them. They’re official atmel stuff: http://www.atmel.com/webdoc/AVRLibcReferenceManual/group\_*avr*\_eeprom.html
What are you using to compile? On which OS?
I’m on Windows 10. I’ve only flashed four drivers so far. I asked about these files because I compiled a different firmware with errors caused from missing files. I fumbled through fixing that so when I came to this firmware and saw it referenced some files I went looking for them. Thanks for you help. I’ll get to try it out tonight if my day goes well:)
In C, any include with <> symbols is assumed to be provided by the host system. Includes with quotes come from the specific project being built.
So, all those mentioned should be available by default if the AVR toolchain is installed correctly.
i have been preparing myself for using the triple down drivers for some lights to spot game at night. So I was thrown off a bit when I was asked to build some lights with red emitters. Anyway, I searched for some code for 7135 drivers that could be modified with an “off” mode as well as battery check mode. Ironically, the code I now have working is tk’s s7 firmware which is designed for advanced flashy modes. It now has five modes, off-low-med-high-battcheck, and memory is disabled. So from any mode I can turn the light off and then back on again without a “click”. I’ve found the click from a tailcap switch to carry quite far in the still of the night. I will be curious to see if this is helpful or not.
Thanks to tk and the other firmware builders!
I’m after a bit of help. I have a MTG2 light which is causing me a bit of a headache. The LVP kicks in really early, I have the right voltage dividers and I’ve tired getting the readings with TK’s firmware but they just don’t seem to be right. I suspect its down to the voltage drop when the light is pulling high currents. Is there anyway that I can get these readings while there is the voltage drop?
Thanks
Does the firmware you use have some sort of voltage readout ability?
I did some testing with storing the voltage value under load in the no init area and then retrieving it on readouts. It worked ok but I found it rather useless for my purposes. Now I have it so that when boost mode is active the LVP step down kicks in at critical voltage level, not low voltage level.
No I don’t have a readout on the firmware I’m using but willing to look into those that do as it is driving me mad. It makes the light unusable as it just steps down as soon as it get into a high mode.
What MCU are you using? If it’s 13a based I can’t help much with code, I haven’t touched that little thing in a long time and have no code for it left.
Another thing that might be affecting your readings: The internal 1.1v reference voltage is different on each MCU. Datasheet specifies it can be between 1.0v and 1.2v. Normally it’s very close to 1.1v and nothing needs to be done, but I have had the odd MCU where it has been at the very limits. This caused readings to be off enough that I wrote a calibration routine.
May I ask what driver you have, and what the values of the voltage divider resistors are?
I have some 85s that I can use. Currently using 13 on Wights 22mm DD+single
I can’t remember the values I’m using off the top of my head, I can look later.
Thanks
If you have a working 85 firmware that has some sort of readout function it could be modified to write the voltage value to EEPROM or no init area. I can give small tips on how to do that but I won’t make a whole flashable firmware as my hands are full with getting my own firmware ready.
I have no experience with Toykeepers firmware so I can’t really help with those readings that appear wrong either.
Did you actually measure the resistors of the divider? What are the values? If you’re unlucky and they’re both 5% off in the wrong direction, you’ll get a reading about 10% off. That’s over 0.3V.
Also, what is the LVP set to in the firmware? I mean the actual ADC value (something around 100-120), not what the comments claim the voltage to be.
Which firmware are you running?
I’ve always had trouble with LVP on my 2S lights, to the point I don’t even bother anymore. I figured out the correct resistors to use (don’t have those values in front of me right now), then hooked up my power supply (which works great for 1S LVP) at 6v and recorded the values to put in the FW. The values were were right in the middle of the usable range, but without fail as soon as I assembled the light, the LVP would kick in at like 8v instead of 6v.
I suspected my cheap power supply was causing me problems so I bought a 6v lantern battery which I slightly discharged till it was exactly 6v, and used that to calibrate the values. It made no difference at all. I had this problem with 3 different drivers, different pcb designs, different value resistors, it never worked.
Its most frustrating. I don’t want to be running an MTG2 on a FET without LVP
OK so I haven’t used this torch for a while and last time I powered it with 2x NCR18650B for long run time. This time I’m using 2x 30Q and I’m not suffering LVP problems, managed a whole 120 seconds turbo time (never happened before). So I guess the high discharge batteries don’t voltage sag anywhere near as much and that was the cause of my issue.
Scrap that. Its defiantly better but they just got to 7.9v and now LVP is cutting in. I think I’m just going to have to do this on by eye.
Using the 2x 30Q has caused me another issue, the springs aren’t long enough now.
P.S. My ADC critical is 120
If I actually used those lights for any real purpose it’d be a major problem, but since most of my lights are just to show off from time to time, I rarely let the cells go below 3.8v anyways. Still frustrating though.
Yes, open up battcheck.c and look for this part near the bottom:
while(1) {
PWM_LVL = 0;
This sets the output level it uses during measurement. Change that 0 to something higher, and you should be able to measure voltage under load.
Or you could turn off LVP entirely.
Or perhaps add a battcheck mode to whatever firmware you’re using, so you can check voltage without opening the light. It’ll probably be a little awkward at higher voltage though, since all the code assumes a voltage range of 2.5V to 4.4V. The easiest method is probably using the “4bar” or “8bar” style, with voltages measured from the actual light but cut in half for what the code sees. Like, if you measure an ADC value of 200 at 8.4V, you’d need to tell it that 200 is actually 4.2V to make it fit into the expected range. The relative full-ness meter should still work though.
I just got a thing which can measure current and voltage simultaneously, and tested it with a 2.8A Convoy light. My 20R cell measured at about 3.9V on moon mode but on turbo it said the voltage had sagged to about 3.4V. I’d imagine that a low-amp cell probably sags even more, but at the moment I can’t test it. Need to build a custom kernel for the thing before it’s working again.
Thanks. I didn’t know Batt check worked at higher outputs. I will be giving this a go later
The drawback to calibrating under load is that it could potentially make LVP useless. I mean, let’s say it’s calibrated for a 0.5V sag, with step-down or shutoff at 2.8V. The turbo mode would step down at a real (sagged) voltage of 2.3V, which might be okay. But after it steps down all the way, it wouldn’t shut off until the voltage gets down to 2.3V again, too low to be useful. So, it’d step down at an appropriate time on turbo, but it might try to stay on low mode until long after the battery is drained.
I haven’t tried it though. I’m not really sure what to expect. Be sure to test it before depending on it.
