For 1 single mode in max output (ie "tactical usage") and be able to use 2 cells (2 x 18350/16340/18650) it would be 1SM. Pls confirm with Alan of Dereelight.
The extension is EXT650, that makes it able to use 2 x 18650. It is usd12 additional, and is hard anodized.
With a 3SM multi voltage pill....and using a 4.08V TF Flames, i got 7.8 lux reflected.
With 2 x 18350, i got 9.7 lux reflected. So with a single 18650 it is still pretty bright.
You'd not want the 1.2A pill, the last one i got was about 60k. Also due to bigger die. This is 90k. That's not a minor/invisible difference.
The single cell pill, after stabilising for heat, would slowly lower in output in just minutes albeit very slowly. You need to ask yourself whether you want to pay 80 bucks for this kind of performance? Makes no sense. I already made that mistake, luckily the new smaller die came along (not expensive also) so that mistake can be written off.
Just get the BIO IMRs, they are usable for many other stuff. Safe too, they are no Li Co. On this light you still get like 80 minutes of run time. Seriously i don't see why people wanna get 2 x 18650, this is not a XM-L flashlight like the Sunwayman T40CS in which the tail draw is 1.5A.
Is lux like lumens? For example, do you need four times the lux for the spot to appear twice as bright to the eyes?
Oh, I didn't realize that IMRs used a safe chemistry! That's fantastic! I'd be comfortable experimenting with some multi-cell lights using these batteries.
If I got some, I would probably go with AW IMRs from lighthound, since I've heard that website provides fantastic service.
However, there is a note stating that IMRs have a lower internal resistance, and thus, if left to charge in a standard charger, may surpass the regular 4.2 Volts. I don't own a multimeter to test batteries...do you think this would be a major issue/safety concern? I guess that I will eventually need to invest in a quality multimeter...but not yet.
Not too big an issue with overcharging with IMRs. I mean i have overcharged many cells to like 4.24V and nothing happens, most chargers out there stop at that point more or less. Of course do not do that often as it's somewhat bad for the cell lifetime.
It is when you approach 4.30V then you need to start to be really concerned. What charger are you using?
You need slightly more than 4X the lux for it to double the throw distance.
Why not get protected 16340s then, if you are afraid. One of the cells go flat at 0.8 amps and the protection circuit cuts in immediately, no danger of reverse charging. Pill fails, also cut in immediately. IMRs are a good idea, but protected works better. These have reasonable capacity, nearly 700mAh in a capacity test.
Of course, with this charger, I wouldn't be able to charge either the IMR 18350s or Protected 16430s. I'm not quite sure if I understand what you're saying. Do you mean to say that protected 16430s are entirely safe? Or just that they are as safe as protected 18650s with a LiCo chemistry?
However, when I said that I could experiment with multi-cell lights after being exposed to IMRs, I meant that I could try out some multi-18650 lights that I've had my eyes on for a while, y'know? I mean, 90000 lux is incredible, but it's not as practical as, say, 60000 lux with a reasonable amount of spill for less money.
There is no inherent bigger danger with multi-cell flashlights. It's just that people use those blue Ultrafires cells (one might be 900mAh and the other 1600mAh, reclaimed notebook pack cells etc) that come with Ebay deals. You see them with stuff like Trustfire triple XM-L even. That's crazy. A single cell flashlight with a driver failing (which will happen quite often) is even more dangerous than multi-cell usage. The protection is there for a reason and with good cells you get better PCBs.
There is no way you can be safe with 1-cell/2-cell without a DMM. That is part of the hobby. Same as RC, same as a lot of other hobbies.
For those who are adamant that mult-cell = absolutely dangerous, then they are missing out a lot of the action.
I mentioned quite a number of times before, multi-cell operation is not dangerous. Firing a 1.3G fireworks cake is more dangerous.
When I said earlier that MPP-1 is better host, I meant in terms of "reflector design". Not the manufacturing quality. As I remember, older DBS V3 with reflector and old pill (EZ1000 with 1A current) did something around 30K lux/1m. MPP-1 uses also EZ1000 and moderate drive level (~1A) and it's doing over 50K lux/1m. If it could use deree pill with EZ900@1.5A that would be interesting.
So... Can you screw the deree pill to the MPP-1 and take the results "reflector Vs. reflector" ?
Sorry, i think someone else said as well that Solarforce P60s is better (CL1H V4 is P60). hehe... Well yeah, the DBS reflector version is only 48mm head diameter anyway, and the MPP-1 is 56mm. The DBS aspheric head is bigger than the DBS reflector head, not the same. I'll see what the MPP-1 holds inside the head.
Actually i just re-measured, the DBS aspheric head is 52mm. It's definitely smaller than the MPP-1.
PS. The Solarforce MPP-1 is probably not driving the LED at 1A. I am measuring 0.817A at the tail with the 2 batteries. With the same pair of batteries i am getting 0.760A for the DBS aspheric 1.5A pill.
Exactly - a more extreme example would be a LASER- the Lumens might be very low relative to a White LED but the "Lumens per square inch" could easily be 20 times higher in the LASER- a more concentrated spot of light.
I think the throw from the emitter will depend on two parameters, one is as you said the surface emitting area, and the second is the angle the dome is designed to throw the light.
"The brightest part of the beam controls throw because that's all that's left at that point."
I do not agree 100% with that, if it was true, the lens diameter would not be important, but it is.
The bigger the diameter, the more amount of light it can get to throw it.
Of course. Emitter surface brightness and lens/optic diameter are what throw is all about. However the question I was answering had to do with how could a XR-E throw further than a higher output XM-L so I was pointing out that the brightest part of the beam is all that’s left at distance.
As in… after a certain distance the less bright part of the beam will not be there and the brightest part is ultimately all that is left at that distance.
2 floors is wide? I think that's very narrow already. The distance is correct, 134m to be exact on the map but i am shooting downwards so it's ~ 150m away.
There is a misconception that an aspheric throws a laser-like spot with no spill, ie useless or just a flashaholic's fun toy nothing too useful in real life. That is absolutely untrue. Remember, the very best high-end rhodoium reflectors do lose at least 85%, and the spill is not "reflectored". In an aspheric, literally everything is projected forwards, the lens cuts 10% approx? This a lot of this light gets to the hotspot. In a ceiling bounce or integrating sphere, the spill light plus corona from a reflectored setup do account for quite a bit.
You can ask Saabluster the seller who does DEFT/DEFT EDC (his latest LED incarnation nets him 700k cd), he would tell you the same thing. If you compare apples-to-apples, the Solarforce Masterpiece Pro-1 has a a very slightly smaller hotspot (10% smaller?), but gets about half of that candlepower figure. Some may not believe it, but it's true.
