Recived my X6 spacers today, very nice quality and a perfect fit in my X6.
Thanks Kiriba :+1:
Thanks Kiriba :+1:
nice pills/spacers.
Received and well packaged and only 8 days from Russia to the UK.
ive just got to learn how to put it all together!lol oh and waiting for MTN electronics parts to arrive too
Hi
I need a quad spacer cooper for a BLF Kronos 14500 light.
Possible ?
Regards Xandre
Seems that russian post works much better last weeks, hope this isn`t temporary event.
S2 and S2+ spacers, S2+ triple and single pills, X6 alu and copper spacers and several B158 pills are still in stock.
More of X5 quad sets (waiting feedback about first batch) and P60 quad/triple drop-ins are comming.
Thinking about ZY-T08 pill, Convoy M1 and M2 quad spacers, Manker U11 quad set.
Received spacers today , about 12 days from Russia to Greece .
I will try the X5 spacer today and report back .
Thanks kiriba-ru
I received my X5 spacer today and put it together with a dsche quad mcpcb/xpl hi/H17F driver combo. The spacer fits like a glove.
I received my super set of everything. Yes, Russian Post does seem to be working very well. Very satisfied. Everything was even organized for use. Many thanks again!!
Just got the X5 spacers, nice quick shipping.
Cant wait to try them out. i’ll try and post some pics of the end result.
Hi,
the X5 spacer and more came in yesterday. The spacer fits perfect. I love it! All parts as described and pretty fast shipping.
Regards
Kenjii
Very nice Kenji, those Nichias must be drawing serious amps…
@Kiriba: can you make X5 spacers to fit the khatod optic? If you look at the spec sheet you will see the exact dimensions, and able to adjust the heatsink to the correct height.
However the optic is not a direct fit into the X5, part of the body must be filed to fit the legs. Ouchyfoot has done it…
As for wether this optic is several times better than a carclo, Dale has done a comparison between the two and the khatod was more efficient, and gave a much better beam.
1. This host fits 24mm optics perfectly. If somebody like to use 25.4mm optics under 24mm bezel hole, this is not me. And I dont think lots of you want to put o-ring away and have non-waterproof flashlight.
2. I hate semi-ready (there should be better word. How do you call all this food that need just to be heated up and it came full ready?) decisions. Not long time ago I had made first X6 triple, and what can I say, it was awfull! I was ready to pay any extra money to have noctigon pcb already sanded to 31.5mm. I can’t understand why nobody offer such deals, it is not very smart when hundreds of members use hand/dremel and waist lots of time in work when somebody can make lots of this pcbs ready for use with machinary very fast.
3. I still havent seen any measurements, except of those which had made dsche several years ago. And he said that carclo is better.
If you have made lots of reviews, have luxmeter and other tools, contact me and I will add one khatod quad optics to your order for free to make tests.
I have 2 question regarding the X5 quad…
The Astrolux Sc host from banggood , does it have a switch pcb ?
And , kiriba , where you got the Khatod optics from ?
The copper x5’s from banggood do not come with the switch at the end, a 16mm switch from a convoy S2+/S3 will work.
I just received my triple pill and triple spacer for the s2+, that pill is serious chunk of copper and sure will do nice heatsinking job.
Thanks Kirill
Thanks Kirill
I received my X5 spacers and optics today. Very nice packaging indeed.
I could probably order a few more things from you, but, it looks like we’re headed for a postal strike, so I better wait.
Got my x6 spacers today. Can’t wait to get building
Ordered 4 copper pills for S2+ single emitter. All items were protected very well in the package.
I personally do not mind the dark rings. Just for experimentation i tried goo gone with a brush and was able to remove the dark rings.
The threads are good no issue at all :+1:
B158 pills received. Very nice - thank you!
I`m still not sure that Khatod quad optics may work better with big leds than Carclo one, but seems that nobody wants to test them and lots of NA members want to use Khatod.
X5 is not good choise for it, but Convoy M2 looks like something very suitable.
Conv. kit for M2 will look similar to X5 for Carclo, with rim for pcb centering, and will consist from two parts (still haven`t designed upper one cause I think that stock 28x26x1mm o-ring should be changed to the thicker one).
On the other side, M2 spacer for Carclo will be taller and can weight about 60gr.
Which one would you prefer? Price will be about $10.
