Hi Sharpie
Yes,We have some standard products,as 20mm XML 20mm XHP70 20mm XPG,16mm XML 16mm XHP70,10mm XML 10mm XPG,But because we are manufacturer,most of
order was according customer Engineering drawing to make.
Regards,
Sundy
Hi Sharpie
Regards,
Sundy
Hi Sharpie
Thank you.
Sometimes we can supply small quantities, economically,to Western customers,But For Western customers If was small quantities,
maybe not economically,because they need pay for the shipment.I am honest to say.
Best wishes
Sundy
There must be various configurations of stars to mount LEDs that are not available from Noctigon or SinkPAD. For instance, there was a thread about how to deal with Nichia LEDs that have only two pads.
There are also drivers that would benefit from metal PCBs. High current buck drivers such as those that Richard McDougal, aka. RMM and Mountain Electronics, sells, and regulating drivers that use FETs in linear mode to control current rather than pulse width modulation come to mind. I believe that is how led4power’s drivers work (For sale : LD-2 and LD-M2 driver (Updated)). PWM FET drivers might be improved by larger gate resistors to make the FETs work in a linear mode for the lower modes if the cooling would take it.
If have interesting,you can learn more.
best wishes
Just a question on the quad TPAD MCPCB. Do you own the rights to this particular MCPCB?
Yes,we have Invention patent certificate in Chinese.
Sundy
Thanks! I was wondering about those too! I’m so glad you decided to come here to our forum and offer your services and I’m really looking forward to seeing what custom MCPCBs we can come up with. As was mentioned, there have already been some designs proposed around these pages, but no movement to get them produced.
say what?, this is my design and you have stolen the images? and the board is not made by you!!!
Mark
There seems to be a post missing here. A shame really as the truth came out with no response from them except a deleted post.
Hi every one
Maybe this is your design,But you doubt I stolen the images is a shame,Do you sent this picture?
we are manufacturer,This technology have many years in China.We before called Direct Thermal Exchang technology,that was our
company patent of invention,Why we cannot make this board,I delect this picture is respect every one.
Thank you
Sundy
Hi every one
Thank you
Sundy
I have no doubt you can make this PCB, but the design is my design and we have a factory which makes the PCB, so I dont need you to make it. There are many factories claiming to make DTP pcb, and many can however we make ours with very specific quality requirements and we are not looking to change
Cheers
Mark
Hi
Thanks your explain,I repects you,we cannot make it,But the direct thermal change was our company patent of invention at 2008 is fact,
we also have our quality requirements.And now this technology is very popular in China.China’s patent awareness is not very strong,
Thanks
Sundy
Guys most of China sellers will do OEM or ODM orders for you.
Of course there is MOQ for such desires and that cost serious $…
They are obliged to protect that seller… So yes I agree that even single photo of ODM request should not leak into public because that is between seller and designer (another seller).
So he did not meant nothing wrong by posting that photo… Don’t be mad on leo ou please…
My suggestion:
If there are experienced members that would want to suggest or give their working ideas for wellbeing of BLF community you could listen to them and make us lets say BLF DTP boards .
That way you’ll not brake any ODM rule cause we all participated in design…
Hope that this thread will stay alive and that something good will be born from it
Hi
we also have our quality requirements.And now this technology is very popular in China.China’s patent awareness is not very strong,Thanks
Sundy
While it refers to older Epistar type leds it is still dtp.
Direct thermal path patent
A heat dissipater (<HIL><b>30</b></HIL>) of a metallic or metal material is disposed in parallel relationship to a circuit board (<HIL><b>12</b></HIL>). The assembly is characterized by the circuit bo
Dated 2000
Cheers David
If I am not mistaken, that patent refers to a different technology where a hole is actually cut into the PCB.
That differs from building up a copper pad on a copper (or aluminum) core PCB. Subtle, but different.
There were a lot of related but different solutions in the early days of LEDs and PCBs including inserting copper slugs into a whole in the PCB, direct PCB onto heatsink, etc.
This is one of the early patents on the PCB: US6711812B1 - Method of making metal core substrate printed circuit wiring board enabling thermally enhanced ball grid array (BGA) packages - Google Patents This particular one using bias, which is pretty narrowly written which would allow easy ways around it.
You are right, in that one the led slug goes down to the heat sink, on a modern one the heat sink is built up to the slug, in other words there is a hole cut in the dielectric layer just the same as there was a hole cut in the pcb
I know that as far as patents are concerned that could be enough to give out a new patent, however this company is making claims that they developed direct thermal transfer and patented it in 2008, the patent I linked to shows that dtp was developed well before that.
Snipped from the OP
DTP technology exists for many years in China.We called it Direct Thermal Exchange technology which was our company patent of invention at 2008.
If they had just come onto the forum saying as a manufacturer they are willing to sell small numbers to us directly with proper info on their products not just saying “Email us and we will tell you”, no data, no prices :confounded: I would of been at the least curious, but when someone wants to sell something without showing it, it is called buying a pig in a poke.
Cheers David
Explanation,in medieval times a poke was a bag and “buying a pig in a poke” means buying unseen, many a person got home to find that they had bought a cat/dog when they opened the bag
Since they manufacture to order maybe they are just showing the kinds of things they can do rather than things they have done. They really should only post advertising pictures of their own work though, don’t know which is which now. I like the wide traces.
HI all,
I’m not really sure of anything that happened with the picture of marks MCPCB, but here is my 2 cents.
I have contacted Sundy via email to inquire about getting samples. When I did I asked about all the sizes we typically use here 20mm 16mm etc. I also asked if they made a triple XML board ( like Sinkpad, Cutter electronics and sevral other makers do), and linked Marks website as an example. I was told they did not stock this size board but would be glad to manufacture one. I’m not sure if that has anything to do with the picture that was posted, but I thought it might so I mentioned it. Perhaps they were offering to make this “type” of MCPCB?
As I said I am working on order a sample pack of several boards offered by the company. If they turn out to be true DTP boards, and the prices are reasonable I may do either a GB or a bulk purchase on my own.
My 2 cents
