Maybe this is your design,But you doubt I stolen the images is a shame,Do you sent this picture?
we are manufacturer,This technology have many years in China.We before called Direct Thermal Exchang technology,that was our
company patent of invention,Why we cannot make this board,I delect this picture is respect every one.
I have no doubt you can make this PCB, but the design is my design and we have a factory which makes the PCB, so I dont need you to make it. There are many factories claiming to make DTP pcb, and many can however we make ours with very specific quality requirements and we are not looking to change
Cheers
Mark
Thanks your explain,I repects you,we cannot make it,But the direct thermal change was our company patent of invention at 2008 is fact,
we also have our quality requirements.And now this technology is very popular in China.China’s patent awareness is not very strong,
Guys most of China sellers will do OEM or ODM orders for you.
Of course there is MOQ for such desires and that cost serious $…
They are obliged to protect that seller… So yes I agree that even single photo of ODM request should not leak into public because that is between seller and designer (another seller).
So he did not meant nothing wrong by posting that photo… Don’t be mad on leo ou please…
My suggestion:
If there are experienced members that would want to suggest or give their working ideas for wellbeing of BLF community you could listen to them and make us lets say BLF DTP boards .
That way you’ll not brake any ODM rule cause we all participated in design…
Hope that this thread will stay alive and that something good will be born from it
If I am not mistaken, that patent refers to a different technology where a hole is actually cut into the PCB.
That differs from building up a copper pad on a copper (or aluminum) core PCB. Subtle, but different.
There were a lot of related but different solutions in the early days of LEDs and PCBs including inserting copper slugs into a whole in the PCB, direct PCB onto heatsink, etc.
You are right, in that one the led slug goes down to the heat sink, on a modern one the heat sink is built up to the slug, in other words there is a hole cut in the dielectric layer just the same as there was a hole cut in the pcb
I know that as far as patents are concerned that could be enough to give out a new patent, however this company is making claims that they developed direct thermal transfer and patented it in 2008, the patent I linked to shows that dtp was developed well before that.
Snipped from the OP
If they had just come onto the forum saying as a manufacturer they are willing to sell small numbers to us directly with proper info on their products not just saying “Email us and we will tell you”, no data, no prices :confounded: I would of been at the least curious, but when someone wants to sell something without showing it, it is called buying a pig in a poke.
Cheers David
Explanation,in medieval times a poke was a bag and “buying a pig in a poke” means buying unseen, many a person got home to find that they had bought a cat/dog when they opened the bag
Since they manufacture to order maybe they are just showing the kinds of things they can do rather than things they have done. They really should only post advertising pictures of their own work though, don’t know which is which now. I like the wide traces.
I’m not really sure of anything that happened with the picture of marks MCPCB, but here is my 2 cents.
I have contacted Sundy via email to inquire about getting samples. When I did I asked about all the sizes we typically use here 20mm 16mm etc. I also asked if they made a triple XML board ( like Sinkpad, Cutter electronics and sevral other makers do), and linked Marks website as an example. I was told they did not stock this size board but would be glad to manufacture one. I’m not sure if that has anything to do with the picture that was posted, but I thought it might so I mentioned it. Perhaps they were offering to make this “type” of MCPCB?
As I said I am working on order a sample pack of several boards offered by the company. If they turn out to be true DTP boards, and the prices are reasonable I may do either a GB or a bulk purchase on my own.
Our company many Direct Thermal Path copper mcpcb orders according customs engineering drawing to make,
sometimes,we also put forward our opinion about drawing,if customs have need,we also can design DTP mcpcb
MCPCB according to customer requirements.
If they said this they are 100% cheaters.
All layers of boards are making in one big flat area and cutting (milling) small pcbs from it is the last operation.
There is no way to have 16-20mm preparated washers and then make DTP MCPCB from them with custom design by request.
I think you misunderstood. I don’t see anywhere that they said they had prepared boards or blanks to make DTP MCPCB from them. They claimed to be able to manufacture any size or shape of MCPCB, because they are a PCB manufacturer.
Yes, seem that I am wrong.
But anyway we need to see real photos. Those that are posted here are stolen from various websites and shows pbs made within different technologies.
I am trying ATM to have them make a limited number of boards for Nichia 119, which are non-DTP btw. But if the order goes through, they will send a few DTP-XP board with the order to try them out.
How about the Nichia 119 copper mcpcb, if you also have any problem please tell me?yes if the orders goes through,
we will send a few free DTP copper for you testing.
ShenZhen KeRui Electronic Industrial Co., LTD
Copper substrate performance parameters form
Copper Substrate Model KR-CU-350W Product name Copper radiator panel
Performance parameter Unit Test value Test Method
Peel strength N/mm 2.2 GJB1651 - 4010
Surface resistance MΩ 1×(10^6) GJB1651 - 5020
Volume resistance MΩ.m 3.2×(10^7) GJB1651 - 5020
Breakdown voltage KV/min 1.0 GJB1651 - 5040
Dielectric constant - 3.0 (40℃,93%,96h)
Dip soldering of resistance ℃
260℃ 3min
No bubble, no
stratification
GJB1651 - 4010
Flammability - FV-0 GB/T4722 - 17
LED Solid crystal area with
the substrate conduction of
thermal conductivity
W/m.k- ≥350
Long-term use temperature ℃ ≤110 (40℃,93%,1Y)
The thermal conductivity of
the metal matrix W/m.k- ≥350
