On The Road i3
They put in a wrong picture on 18650 battery.
I don’t think I’ve seen a 16340 zoomie before. Well, gotta throw that one onto the wishlist.
Nebo makes a couple CR123 size zoomies. I have a really tiny one that I modded with a FET driver and Nichia 219C. Unfortunately the clicky Guppydrv driver I used was defective so it only gets the first mode of any selected mode group (driver isn’t bypassed since I can enter programming mode and choose groups, I just can’t change modes within a group).
Here’s a Nebo that’s probably using a 16340. Looks to be similar size to an Olight S10, complete with sideswitch and charging cradle:Nebo zoomie
I’m also very interested in that “On The Road i3”. Nebo - never heard about it, but…also looks nice! However too expensive to try.
So if I want something for brightness / clarity and seeing detail the 1A would be better
For clarity, go with a neutral tint. The cool tints tend to wash out the colors and subtle details of what you’re looking at.
Sorry … my complete ignorance but does that mean the 5C or 1A may be better ???
Going back to the Lumens query as well, I have other torches that are a genuine 220 and 270 lumens and makes you realise the quoted 300 lumens for a SK 68 (whilst they’re brilliant little torches) is totally exaggerated …… does anyone happen to know if the quoted numbers for this may possibly be realistic …… especially for the mid 250 lms
I would consider 5C the “better” tint, because it’s the neutral white tint where you can see better details.
Here’s a comparison of various tints lighting up some vegetation. You can really see the tint difference between 5B (which is close to 5C) and 1A.
In your SK68, did you use a 14500 battery, or an AA? I’m not sure if the 300 lumens for the SK68 is legitimate or exaggerated. It could be legitimate if it meant running on a 14500, and it meant the amount of lumens coming off the LED itself, not the lumens coming out of the front. And if it referred to a Cree LED, not a Lattice Bright LED.
I don’t have an answer to your original lumens question, since I currently don’t have the i3.
Yes am using a 14500 but if you put it next to a Led Lenser T7.2 which is 220 lumen the Lenser is massively brighter … a very noticeable difference so the SK 68 whilst it’s a great little pocket torch the power’s hugely over estimated.
Definitely much more mod friendly
Mine arrived today … 620 lm … or don’t they understand where the decimal point goes …… 62 lm … if you carry a handbag and want something “convenient” to put in it great but anything else seriously save your money.
That sucks. I wanted this until I saw a Youtube video. Looked dim as heck and the guy must have had the 1a because the tint was awful blue
What battery where you using? And did you take any tailcap amp readings? They will tell you a lot on how many lumens it might be making.
Also, this is a floody LED. So will not throw very well, be it a zoomy or reflector light of this size. Assuming you go the XM-L2 version, or did you go for the XP-G2?
The light looks rather mod friendly. A driver swap will make it much more powerful.
Yeah, is anyone brave and foolish enough to approach them about selling us a batch of hosts?
It is indeed mod-friendly, xref to the what did you mod today thread 2 weeks ago:
I had the XP-G2 version, and on a 16340 Efest IMR, the high setting was certainly not 62 lumen, I did not measure it before modding but it could well be over 400 lumen. The tailboard can be swapped by the standard board+small Omten switch, if one prefers that.
Any white wall beam shots for this light?
Out camping, no white walls within miles. No unmodded i3 either…
Mail carrier just delivered mine a minute ago — 5C version.
More when I know more …
