Very sorry to hear of your health problems. Possibly a simple build. Once you go looking through all of the older contests, you might see something that is not expensive to do. As far as modders being mentors, we are just people like everyone else and most likely the onus should be on the one who wants to learn, to PM some of the promiment modders and ask for help. Watching the builds is many times, just as fufilling as doing them.
Anyhow, good luck to everyone and I hope you find something you might try to make, you never know till you try. If a person has some common sense, they can go far. If not, they can still be Blonde and proud of it.
I tell everyone who would like to try, give it a go. If it works, it works and if it fails, at least you tried. Failure is never as bad as never even trying. Failure is just more infamous.
I would suggest everyone to ask open questions in their build thread. This will not only allow more than one person to help, but also is more entertaining & educational for everyone watching the build thread! Also, remember that documenting the obstacles and asking help from community will give you extra points. :)
PM'ing other modders is of course allowed, but not as fun for readers & judges (=> no points).
Others may not donate you extra time ( :D ), but you may try asking for small donations (missing parts, etc.) in your build thread. I would bet there are many persons near you that are willing to help!
On the both challenges question, I would say no. My reasoning is based in large part on something mapache has touched on, as well as The Miller… skill set. For someone used to operating the machines, they’ve developed a skill set that is a serious advantage even when building with simpler tools. This can be intimidating for someone that hasn’t built a light before at all, and has limited tools and knowledge to work with. By not putting a rookie up against a lathe master, the rookie has a much better chance of “winning” (that’s in quotes because anyone that tries, wins, purely based on accomplishment)
When I built the .50 Browning Machine Gun light, I may very well not have even tried if going up against the likes of Hoop or MRsDNF. Having built that light though, the confidence one gains in the successful attempt is largely why I’m still here today. So for those out there that are straddling the fence, I strongly encourage you to saddle up, take the ride… you’ll be glad you did!
Each time I’ve been a part of it I’ve learned a lot of new things, mostly from figuring out how to overcome an unforeseen challenge or from watching others do the same. The “borrowed threads” Dale used in the .50 cal is a staple of my home made builds now but there are other ways to skin the cat as well if you just look around and notice how things are put together.
To save the looking up time, I cut brass pipe fittings to steal the threaded ends off of them, both male and female, to rejoin the .50 cal shell after cutting it to get the flashlight parts inside. I didn’t have a way to do threads, the shell case wasn’t thick enough to cut threads if I had the tools, so I soldered in/epoxied in these “borrowed” threads. I used epoxy on one so it would be locked out from ground, enabling a twisty action.
Necessity is the mother of invention. That’s the fun part. Getting the idea what you want to do, then finding the necessary bits and pieces to bring it to fruition. The big difference between thinking you can and knowing you can is this bit of priceless experience that gives confidence.
Compression fitting come in machine threaded instead of tapered pipe thread and lots of different sizes that work for 10440, 14500, and 18650. You can even get bits with knurling.
For what it's Worth, which is less than 2 centavos any more, I would keep the classes separate, because definitely anyone in the machine category has a big advantage over a lay person who has no knowledge. I think it would be unfair due to the skills a machine made person has, (or should have, you have to believe they do, even if they say they don't). Machine made people have the common sense, the basic skills, plus a whole set of advanced skills, even for hand tools. It is just not fair to the newbies who might or will not enter, due to the inequality of skill sets.
