I hope you can't. I don't want it vandalised you see. See the PM I just sent though. You are welcome to copy it and do what you like with it for any non-commercial use. I may make it more open once I've got all the data collated and in one place - and backed up...
I can always copy it in excel and apply autofilter and sort ... but I have to do it every time you add a new light. Would be nice to have it online on a user basis ... I certainly don't want to mess up your list. Would be nice to filter for example 1xAA and then sort by output. I am very familiar with excel vba macros, but never worked with that google docs api.
I took a look, but it is an editing operation unfortunately. It will not let me save it in that configuration without making it globally writeable.
The Publish HTML I tried didn't work here, it didn't update when I changed it immediately afterwards. And it and Drupal seemed to be fighting over the formatting.
What I have done is made a copy of the master sheet that it editable by anyone. Since I can revert it in seconds as it is a copy of the main sheet, feel free to play with it.
Effectively it is, as with my Webkit browser (If it'll work with another browser please let me know) there is no way to save it in that configuration which means I can't publish it that way or produce a link to it. It would have helped if I'd checked this while not logged in.
Except I'm speaking rubbish - it seems that anyone can look at it and use list view. I thought I had to enable it as the owner of the spreadsheet. If you use the recent link I posted, you have access to an editable sheet that anyone can do anything they want with. Since it is a copy of a protected sheet, it is no big deal for me to reset it.
You don't need to save it in that config. Any user can put it into list view. The sheet is also accessible via its "lv" url:
for example if you decide to change the "default" view for sort, click on the column header, and http param "sortcolid" will change ("sort column id") in the url (to, say, 2 for battery type), and you can copy paste it into your sig.
Ah OK, you have to have a Google docs account to use 'autofilter and sort'... had to create one ... then the 'list view' function worked. A pity that you can't use it without one. That is totally not intuitive, that I have to log in to sort someone else's documents.That should be in cell A1 of your table Don. Thanks for all the work BTW.
Might be better to just give the ListView url by default. It's quite a bit cleaner and more useful anyway.
Filtering by battery type is pretty cool, but perhaps a bit of work to make that all consistent. I wonder if there are "category" types that can be useful to filter on, like "mode", so for each light, the mode it's in is a seperate column.
