That Lumzo angle light looks so bizarre and interesting, sadly it doesn't come with grooves for using as a headlamp so I guess it is more of a work lamp.
It says 1.1hr runtime on turbo which probably means no step down!
Should I order now or there will be better price with the coupon?
Edit: what I have read so far about the GH10 in a chinese forum:
-Shortest 18650 flashlight in the world at just 80mm
If you don´t already have one of this kind of thingies, I could recommend.
Very easy little thing to get Rough estimates for example how much Your several different cellphone chargers put out Amps in reality
…and at what point of the charging procedure…
You can also easily get a rough estimate, of how much your cell takes in. Cannot say anything about losses and science & stuff but at least you get a ballpark reference
They say an Optimist sees the glass half empty, and the Pessimist as half full.
I consider myself a Realist - I figure that sooner or later, I’m going to get stuck washing the glass.
Martin, I think you are an Optimist.
I sent the note, as you suggested, and got the following reply:
I have replied that my account SHOULD NOT BE a wholesale account. I think perhaps the next thing I’ll try is to demand a “wholesale” discount. Perhaps I can get an idea of how many of a thing you need to order to trigger the wholesale flag. It may have been the (30) 30x70 mm printed circuit boards I bought to teach soldering to some middle and high school students.
That went well (my account became normal) and they answered:
“Dear (xx)
Your account was already unsign. But you are not interested in joinning wholesale program? Besides discount, we are able to offer you different service.
Please consider it.
Best regards
Ben”
I’ve been digging around and found a little more info about the Lumzoo GH10:
After some delays in the production they seem to finally pulled off the world’s shortest 18650 light measuring just 80mm long, and so far it has received some praise in the Chinese forum for its performance and anodizing quality. Made from a single piece aluminium, it comes with a OP reflector, AR glass and press-fit bezel. According to a Russian review the standby drain is quite high at ~1.2mA, which defeats the purpose of turning it off because moon level is at just 1.6mA, luckily it can be tailcap locked for extended storage. The driver is a 8x7135 and uses an Atiny25 in a 18.5mm driver, pushing 2.9A into the XP-L V6 1A mounted on copper DTP MCPCB. It does NOT have a timed stepdown but rather a voltage controlled drop like any other 7135 based driver does, so expect it to get very hot after a few minutes. UI operation is fairly simple: quick click turns the light on/off and hold for modes. There is a red led on top to indicate battery level and it has LVP at 2.8V. Note that it only supports unprotected cells.
The current price at EOSLAMP store at taobao is 206RMB which is about the same as the USD $30 preorder price. It could probably go down after some time with a GB code but I believe $30 is a good deal assuming everything said about this light is true.
The translation came out a bit sketchy but I hope I got the above info right. Anyways, expect a more detailed review from me when I receive it. This is one of the flashlights that truly got my attention this year. I love seeing fresh and unique designs.
