I think TomE found (as did Richard) that a high value resistor on the positive input stabilized it and made it work smoothly. Like a 40,000 ohm or something like that.
Limb broke, waah!
Dude, it was a low hanging one, you’ll be fine, you’re lucky it was over the pool.
That’s a freaking great idea! Thanks! I also have a triple xp-l x6 that does the same thing, and I’ve always wondered how many amps it was drawing. I just couldn’t tell due to the driver bumping down.
So I measured 8.6 9.4 amps on turbo. How cool that I can measure it now. Thanks DBCustom!
I often use measuring LED current draw when everything is in pieces, disassembled but I just went straight to putting this thing together, used thick, very short wires, hard to solder so I kinda wanted to avoid dissasembling it. I did try it out with only protected cell I had (NCR18650B) and it seams it works, but It was a short test, cell was mostly depleted. Next one that I will make will be triple XP-L, will measure that one for sure
You’re welcome. I like that it’s real amperage up top, at the emitter, after any driver losses.
I make sure to use the negative lead because if it manages to touch the walls of the head while testing it will only bypass the driver and go direct drive off the cell. If using the red positive lead and it shorts, sparks and smoke and damage done in that same split second your heart and stomach meet jumping out your ……
Thanks for the tip DB, and yes, those “ups I reversed the polarity” moments can be “interesting”, I fried my tablet like that (internal battery life diminished rapidly so I tosed it out and left just two leads for external battery pack) along with several step up converters that I often use for different things like driving 12V COB leds or 12V fans etc…
Spontaneous headlamp mod…
So I was walking down the isle of my local “home depot” style shop and saw a cheapo $8 3xAAA headlamp that looked like it could fit a triple, and as I have dual headlamp project ongoing I though I’d have a shot at making a prototype triple headlamp to see if it’s worth pursuing.
I ripped out the LED, resistor and small switch, and stuffed some triple optics to see if it would fit nicely. It fits but not perfect, the hole is a little too large so I slopped on some glue:
I stuck a S2 spacer on the back with artic aluminia adhesive:
I didn’t want to glue everything in place and at the same time didn’t want the hole thing to fall part with flashing new firmware versions so I kept the original battery case and put a hole in it for the spacer and wires, and stuffed in one of my G-16 programmable constant current / PWM hybrid drivers. I didn’t want to use my FET based F8, it would probably melt the plastic a little too quickly. It’s just an initial trial so 6 amps from 16 x 380mA 7135s is enough:
With my ongoing dual LED headlamp project I’ve gotten annoyed with the wires sticking out. So when I was just walking down the isle of the shop I happened to see this:
It says max 10 amps on the description and is long enough for two projects. I chopped it in half, took a 18650 case from another cheapo headlamp, soldered it in and it was good to go! Funny I didn’t think of this before, it’s a pretty simple solution and more than enough for a prototype:
I couldn’t use the original crappy small switch so I installed my own. I squeezed it in using the existing plastic as support:
The downside was that the rubber switch cover wouldn’t fit under. As this is just a prototype test I slopped on some epoxy and stuck it on the outside. I don’t expect it to stay there for long, but it should last long enough for me to evaluate if I want a headlamp with a triple in it:
So here it is, my triple XLP-HI headlamp prototype… spontaneously made within two days of simply seeing a cheapo headlamp in the store:
Those are the most fun mods because there isn’t anything to lose. If it fails, no big loss, but when it works…it’s that feeling of accomplishment.
I’d have to agree, fun indeed. First time I’ve done this kind of “quicky”. Everything except glued optics can be re-used again.
Very nice mod Mike !
Another impressive one .
How it handles heat ?
Nice, Mike now go do something constructive. Oh yeah, forgot this is a hobby and this is what hobby’s are about.
Seriously this really is a sweet mod.
Thanks. I haven’t had it long enough to melt plastic yet, but as it’s a plastic host I can’t feel how hot it is. Once the copper spacer heats up it might melt it’s way out
Because of the driver position I don’t expect the temp sensor of the 85 will be much help. Doesn’t matter though, the idea is to make a alu casing for my headlamp project once I find out what kind of configuration I want. It’s leaning toward the dual LED config though, will be updating that thread with new progress next week or so.
So we end up with the strap left from the original light? :person_facepalming: :laughing:
A while ago I bought this lightcasltle then later sold it to a mate. He asked me recently to make it one mode. I considered just running DD but I figured he might let it run hot enough to desolder one of the leds. So I installed a single mode 9a driver The output may have dropped marginally but can’t really tell.
I added rollers to my lathe steady tonight. Drilled and tapped the points. Made small washers to space the bearings off. Installed :sunglasses:
Cool, at first I thought you were going to notch the points and put the bearings there instead.
Hey that’s a good idea. It never occurred to me since I was just mimicking what I had seen on the web. I’ll check if the material is thick enough to slot the bearing in. Thanks
