Iâm really sorry to hear that and sorry insurance wonât cover it. It sounds like the power steering leak must have been pretty severe and being sprayed at just the wrong angle. Lots of cars leak all kinds of fluids. To me it sounds like the fluid some how may have being sprayed or flung onto the headers or header depending on the engine size. And those run around 1000 degrees. Iâd have a hard time believing the heads would be hot enough to ignite it to flame, smoke yes. Only thing hot enough would be the header (exhaust manifold connected directly to the block) thatâs just my speculation.
Your in good spirits about it though, which is good it could have always been worse lucky you were able to get out and not suffer burns. Iâd say the interior if engulfed in flames was much hotter then 200 degrees. Flame is much higher, and a regular car fire can char a person behind recognition to where dental records are needed. So Iâd say it seems very safe for the lithium batteries if it took 8 minutes in a car fire to explode. There is another thread on here where a guy is trying to make them vent and explode and the cells wonât do it. He is using imr cells I believe. at least you got your tools, maybe dashcam and your life. A new c8 is cheap. Glad your ok and not in a critical burn unit somewhere. And kudos to you for carrying a fire extinguisher. I donât know of anyone who does. I keep a couple gallons of mixed coolant with me. Thatâs about all the firefighting Iâd have
This is what can happen if an e-cigarette blows up while youâre using it
It was an injury unlike any Dr.
