Effectively it is, as with my Webkit browser (If it'll work with another browser please let me know) there is no way to save it in that configuration which means I can't publish it that way or produce a link to it. It would have helped if I'd checked this while not logged in.
Except I'm speaking rubbish - it seems that anyone can look at it and use list view. I thought I had to enable it as the owner of the spreadsheet. If you use the recent link I posted, you have access to an editable sheet that anyone can do anything they want with. Since it is a copy of a protected sheet, it is no big deal for me to reset it.
You don't need to save it in that config. Any user can put it into list view. The sheet is also accessible via its "lv" url:
for example if you decide to change the "default" view for sort, click on the column header, and http param "sortcolid" will change ("sort column id") in the url (to, say, 2 for battery type), and you can copy paste it into your sig.
Ah OK, you have to have a Google docs account to use 'autofilter and sort'... had to create one ... then the 'list view' function worked. A pity that you can't use it without one. That is totally not intuitive, that I have to log in to sort someone else's documents.That should be in cell A1 of your table Don. Thanks for all the work BTW.
Might be better to just give the ListView url by default. It's quite a bit cleaner and more useful anyway.
Filtering by battery type is pretty cool, but perhaps a bit of work to make that all consistent. I wonder if there are "category" types that can be useful to filter on, like "mode", so for each light, the mode it's in is a seperate column.
Their example spreadsheet is pretty tiny, but it doesn't look like it is set up to let you sort the information by the headings like the sortable wiki table is. I like having the ability to sort the table, but in order to make the table fit the page I had to leave out a lot of infomation in the spreadsheet (like the product links). If you want all of the information it is best to go to the source. I can add some explanation about that.
Don, I have a proposition for a new column in your spreadsheets. I found some interesting numbers trying to calculate overall efficiency for a light.
In all simplicity you just divide the calculated Lumen value with the current draw and the voltage of the strained battery (I used a typical voltage value).
My numbers fall between 16 and 64 Lumen pr. Watt and give a new comparison viewpoint.
I've added some NiZn results to the spreadsheet. Now recharging them so they all start on a level playing field.
I don't think the Powerlight can really handle the voltage, it was getting awfully blue but there appears to have been no permanent harm done.
Do NOT try these in an EastwardYJ J09 - mine was drawing over 4.3A with a freshly charged NiZn and would not have lasted long at that current draw - they really mean it about 1.5V maximum which is why it is so bright with NiMH/alkalines.
