4th Annual BLF/OL Scratch Made Light Contest- Hand Made 10/31 finished
266 posts / 0 new
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 4 days ago
10/31 Finished in post #227
Some numbers in post #3 and more pics in post #4
Tail cap current measured at 4.3A with a 4.1V cell(Sanyo NCR 18650 BF)
Build posts have been daisy chained for continuous boredom
Placed a few orders and did some shopping at the salvage yard, bulk brass is $4/lb, copper $6/lb. didn’t buy any copper but also noticed they have big fat Alu rod stock(3-6” dia.) if anybody wants me to put a chunk in a medium flat rate box.
I’ll be using one end of the larger (7/8”) compression fitting for the male and female bezel fittings. From there back to the tube I’ll have to cobble together some fins on the outside and threading for the pill on the inside. P60 pills have 20 × 1.0mm threads and I was able to get a tap and die last year so I can make a threaded copper pill and tap it inside the fins. Figuring out how to keep all the fins centered will be tricky.
Does anyone have a few inches of Type K 3/4” copper? No local stores carry it. The ID of type K is just right for tapping 20 mm threads.
7/19
Later that same day …
I don’t have one of those builtlikeabattleship motorized hacksaws but I do have a reciprocating saw and that and a vice made this cut in short order.
Then I screwed the threads and comp nut together and went to the drill press where I loaded up a hole saw with tape and 180 grit w/d. After a few hours and many additions of 2“tape(several feet in all in 1 1/4” increments).
I had increased the ID from 22.4 mm to 25.5 mm lightening it considerably though the real reason for doing it has to do with how it all goes together.
7/20
Now to start building back from the threads. I need a strip of brass cut, bent into a circle, and brazed into the threads. It needs to be very round and very snug. After annealing it I rolled it around my 3/4” pipe sleeve stock which is ~24mm OD. Getting the ends to round is difficult but if you roll the strip inside another snug fitting tube it works pretty well. The ID of the thread piece was chosen partly to make this work out but only partly. I work with several different tube and pipe sizes that don’t all sleeve together tightly. In this case I was able to take advantage of the gap between the OD of 3/4” repair sleeve and the ID of 1” copper pipe to get a nice shape to the strip.
7/21
I lost some time after work as I had trouble finding my pieces. Angry Once they were found I set about cleaning them up and brazing them together. All gooped up and wired. Don’t touch, it’s hot! After a hot bath in Fuze Clean FS flux dissolver. Heat brings copper to the surface of the brass but buffing removes it quickly enough. For what it’s worth, it ended up within .1mm of round, that’s ~4 thousandths. Still plenty of hand sanding to clean up the ragged saw cut end and to get it true on the ends.
I’ll need to make more parts before the next assembly step.
7/22
Earlier this year I acquired some stuff from a member including a cigar tube and remembered it just in time to save me a bunch more reaming and grinding on the seat post I had been going to use. It is sealed at one end and has an o-ring at the other so to preserve those I cut a section for what I need from the middle and sanded both ends square. I also marked the hole centers of some discs I’ll cut from a 1.5mm X 33 mm strip of aluminum. I’ll also need another piece of wood from that whateveritis root ball. This is what it looks like au naturel.
7/24
The bezel is too thick. I could sand it thinner from the outside but I’d rather cut from the inside instead with a Dremel bit. I also cut an 11mm slab from the piece of burl just above. And after a bit of sanding saturated it with epoxy sealer to minimize chipping when it gets smaller. I won’t be able to work on this much for awhile so it will have plenty of time to cure properly.
7/26
Just time enough today to set up and punch out a few loose fins. Oops, one slipped! I’ll need to cob up a jig for the spacer rings as I want them to end up the same 1.5mm thickness as the disc fins. For now I ended with taking the plunge and mistreating some wood in a similar fashion. I learned the trick of gluing a small piece to a larger one separated by paper to allow for clamping the small piece way back in 8th grade wood shop. Tune back in this weekend to see whether it survived two separate hole saw attacks.
7/27
Can’t do any physical work on the light but need to figure out the details of moving the switch from B- to B+. To that end I’ve made a rough sketch to get started and improve the picture in my head. The button cover has a rectangular apron bent into a curve to fit inside/outside a tube but I need to create the space for it in the layers of brass tubing, hopefully under the wood and outside the innermost tube that is the switch module. I might need to add another layer or two of tube to account for it since it would be stronger to have just the button hole itself in the outer brass layer where the wood is dimpled around the button.
7/30
I started by squaring up both ends and marking and knifing a start in each. I’ve intentionally marked slightly off center to maximize clean length. Then I used a small bit to get started, once in awhile allowing the wood to spin slowly and adjusting in the direction of the wobble to correct it. Perfection isn’t likely nor necessary at this point but good is definitely better than bad. Then I switched to a 1/8” bit and after again noting the high point off the wobble angled slightly in that direction. This bit is still too short to get all the way through but I have another for that. Bingo. From here until I hit 1/2” or so it’s just a matter of stepping up the bit size gradually so as not to explode the burl with pressure from within. Here it is at 3/8. Once I reach that point I’ll switch to sandpaper wrapped spindles to increase the ID with even less outward pressure. When I get to 5/8” or so I’ll start saturating the wood with epoxy sealer from inside the tube to strengthen it for the next session. I won’t turn the outside of it until the brass sleeve tube is ready to be epoxied into it to act as a structural core.
Link to continuation
Scott
Edited by: Rufusbduck on 10/31/2016 - 18:57
Rufusbduck
Scott
Rufusbduck
By the numbers…
There are:
25 separate pieces of brass. 6 in the head, 13 in the tube/switch, and 6 in the tail
(Not including pieces used for jig)
12 pieces of aluminum in the fins and spacers
5 pieces of copper all in the head
3 pieces of wood
Bought flashlight parts:
Lens – as is
Reflector- modded outside surface to fit
Butterfly spacer – minor mod for wire clearance
219 C led reflowed onto 16mm Sinkpad with butane torch
(Wire slots widened and mcpcb filed to center emitter)
Mtn 17DD driver purchased with wires and spring bypass
MtnE short heavy springs -as is
.5A push button reverse clicky switch modded for high current
3 used pcb’s modded into contact boards and led backlight board
2-0805 blue LEDs soldered to backlight board with 10k R current control
(On when light is on)
4 trits, 1 green on backlight board and 1 each green, yellow, and blue under tail cap cabochon
(Always on)
2 moonstone cabochons, 1-9mm at switch and 1-17.5 mm sanded to 16.5mm in tail
Length:
Head 42.8 mm
Tube 100 mm
Overall 142 mm
Width:
Head 29.8 mm
Tube 25.7 mm(varies from 25.5-25.8mm)
Turbo current is 4.3A @4.1V
Moon mode current is 2.8mA with leakage though 10k R ~.4 mA
Weight (will add this data tomorrow as I have no scale)
Scott
Rufusbduck
Mine three
A few more shots Grain matched Trit lit cabochon is actually quite visible to dark adjusted eyes though not in any way bright.
Scott
Rufusbduck
Maybe I’ll share this one.
Scott
MRsDNF
MRsDNF's picture
This build is going to be the ducks guts. Love your builds RBD. While your helping others here can I have that piece of wood?
DBSAR
DBSAR's picture
Last seen: 22 hours 27 min ago
looking forward to this Big Smile
FrontPorchCarver
Last seen: 4 years 2 months ago
That’s a beautiful chunk of wood you’ve got there. Amboyna burl? Or perhaps Redwood?
Rufusbduck
Bushwood. Seriously it’s from some unknown root ball I found on the beach. I’d like to find out. You can buy resin impregnated wood blanks for turning but I haven’t seen one like this. I don’t know if I’ll use this one or not but I like how it finishes.
Scott
_the_
_the_'s picture
Last seen: 6 days 23 hours ago
Looks very interesting. Good luck in the comp!
Hand made?
=the=
Rufusbduck
Yes
Scott
MRsDNF
MRsDNF's picture
So I cant have it? The piece of wood that is. Crying
FmC
FmC's picture
Last seen: 7 months 4 weeks ago
I’ve got wood too… Innocent
Good luck with the build! Smile
MRsDNF
MRsDNF's picture
We all have wood. Facepalm
I went and got my own. I dont think RBD wants to give his away. Looks good for something that came of the beach. The grain looks amazing.
OrcaTorch
OrcaTorch's picture
Last seen: 4 years 5 months ago
Aha, people all pay attention to the wood.wink Looks great. Look forward to the  finished product.
☆☆☆ Personal lighting solutions provider for safe diving ☆☆☆
FrontPorchCarver
Cool! “Found” wood is always the best — it’s wood with a story Smile
ImA4Wheelr
Last seen: 1 month 1 week ago
Man, that is a real beautiful piece of wood there (not trying to pun). If anyone can do it justice, it’s RBD. Best wishes.
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 10 months ago
Too many wooden one liners here, waiting for someone to use them.
As always, I look forward especially, to your builds, as I know just how much labor of love you put into them.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Rufusbduck
I’m sure SB appreciates our restraint. Besides, in this high tech age, hardware sees more action than good ole’ wood. Facepalm
Scott
Rufusbduck
New stuff in op.
Scott
MRsDNF
MRsDNF's picture
Your one up on me with a reciprocating saw. its good to see you make a start RBD. No doubt I’ll be lost with the next instalment. Silly
Rufusbduck
I’m the one that got lost.
Scott
Rufusbduck
Minimal update.
Scott
Rufusbduck
A few more minims.
Scott
MRsDNF
MRsDNF's picture
That is better looking than anything I have. Thumbs Up
Rufusbduck
Dumb luck I’m sure. Of the box of odd shapes I picked up at the beach I think this is the only one with really good burl.
Scott
Rufusbduck
I have a fair amount of small parts making before much more in the way of assembly takes place but I’ll try to keep adding a few interesting tidbits.
Scott
Rufusbduck
Sketch bump.
Scott
DBSAR
DBSAR's picture
Looking good so far RBD. Thumbs Up
MRsDNF
MRsDNF's picture
Looking good. I have seen a switch done like that before. Now where could that of been. Wink
fritz15
fritz15's picture
Last seen: 2 months 11 hours ago
How awesome that there is so much wood in the contest this year. I am looking very much forwards to your build!
